[postgis-users] Buffering with JDBC
Leticia
lgomez at itba.edu.ar
Fri May 11 08:49:05 PDT 2007
Hi, I dont know if it is the best way, but I implement this class:
import java.sql.*;
import org.postgis.PGgeometry;
import com.vividsolutions.jts.geom.*;
import com.vividsolutions.jts.io.*;
public class GeometryReader
static int SRID= 0;
static GeometryFactory fact= new GeometryFactory(new
PrecisionModel(1E10), SRID);
static public Geometry getGeometry(Object obj) throws SQLException,
ParseException
return getGeometry(((PGgeometry)obj).toString());
static public Geometry getGeometry(String geometryStr) throws
SQLException, ParseException
WKTReader r= new WKTReader( fact );
Geometry geom;
// ADD SRID
if (geometryStr.indexOf(';') != -1)
String []temp= PGgeometry.splitSRID(geometryStr);
int srid= Integer.parseInt(temp[0].substring(5));
geom= (Geometry) r.read(temp[1]);
geom.setSRID(SRID);
else
geom= (Geometry) r.read(geometryStr);
return geom;
And in every place where I need to recover a geometry (Polygon, Linestring,
etc) I invoke GeometryReader.getGeometry( );.
i.e:
public class Rta
public static void main(String[] args) throws ClassNotFoundException,
Class.forName("org.postgresql.Driver");
Connection conn= DriverManager.getConnection(
"jdbc:postgresql://localhost:5432/proof", "postgres", "postgres" );
String queryDML= "SELECT geometryColumn FROM region LIMIT 10";
Statement stmt= conn.createStatement();
ResultSet rs= stmt.executeQuery(queryDML);
while ( rs.next() )
Geometry geometryRead=
GeometryReader.getGeometry(rs.getObject(1));
System.out.println(geometryRead.getArea());
Then I obtain a Geometry reference.
Leticia
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
shojka at web.de
Sent: Friday, May 11, 2007 11:45 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Buffering with JDBC
import java.sql.*; import java.util.*; import java.lang.*; import
org.postgis.*;
public class JavaGIS { public static void main(String[] args)
java.sql.Connection conn;
try
String url = "jdbc:postgresql://localhost:5432/database"; conn =
DriverManager.getConnection(url, "postgres", "");
((org.postgresql.jdbc2.Jdbc2Connection)conn).addDataType("Geometry","org.pos
tgis.PGgeometry");
pe("box3d","org.postgis.PGbox3d");
Statement s = conn.createStatement();
ResultSet r = s.executeQuery("SELECT
Buffer(GeometryFromText('POINT(10000 20000)',-1),20)");
while( r.next() )
PGgeometry geom= (PGgeometry)r.getObject(1);
if( geom.getType() = Geometry.POLYGON )
Polygon pl = (Polygon)geom.getGeometry();
for( int r = 0; r < pl.numRings(); r++ )
LinearRing rng = pl.ge tRing(r);
System.out.println("Ring: " + r);
for( int p = 0; p < rng.numPoints(); p++ )
Point pt = rng.getPoint(p);
System.out.println("Point: " + p);
System.out.println(pt.toString());
s.close();
conn.close();
catch( Exception e )
e.printStackTrace();
Dear PostGis users,
I want to use buf fer function from POSTGIS but I simply cannot convert the
result of query in a PGgeometry object. The line:
results always in:
java.lang.ClassCastException: org.postgresql.util.PGobject
I got result as a strine when i insert in qery function Astext(), but when I
want to work with geometry I am helpless. Has anyone an idea how this
problem could be solved?
Thanking in advance
<https://img.web.de/p.gif>
Erweitern Sie FreeMail zu einem noch leistungsstärkeren E-Mail-Postfach!
Mehr Infos unter <http://produkte.web.de/club/?mc=021131>
http://produkte.web.de/club/?mc=021131& nbsp;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070511/041c79d6/attachment.html>
