[postgis-users] Postgis 2.0 wishlist
Willy-Bas Loos willybas at gmail.com
Tue May 15 14:21:09 PDT 2007
>This is doable now, the main problem for newbies seems to be setting
>the search_path every single time so they have access to them.
That doesn´t seem logical to me: it´s also a problem for the same newbies to
restore their PostGIS databases.
It should be a default search_path, just like pg_catalog and public.
I dont need to set the search_path to use "select int2('25'::text)" either.
Or would that conflict with PostgreSQL policies?
WBL
On 5/15/07, Paul Ramsey <pramsey at refractions.net> wrote:
> On 15-May-07, at 4:33 AM, Willy-Bas Loos wrote:
> > If you're changing alle the function names, maybe it's time to make
> > system objects of them, stored in a seperate system schema (along
> > with the types, operators, etc)?
> > Other than that it would be nice to add descriptions to the
> > functions and operators in SQL, e.g. to indicate what the input for
> > each function should be when the number of arguments varies for
> > functions with equal names.
> How does one recover those descriptions at the commandline? Does \d
> functionname work?
> P
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070515/50c37c06/attachment.html>
