[postgis-users] Re: [postgis-devel] Moving towards a 1.2.2 release?
TECHER David
davidtecher at yahoo.fr
Thu May 17 10:36:46 PDT 2007
Hi Michael
I've tried again your patch on a new computer
But the regression tests failed any way.
for example I've attached the diff I've got for ./runtest regress (file
test.diff) and my messages from PostgreSQL reports (file: pg.log)
I hope this could help
cvs -d :pserver:anoncvs at anoncvs.postgresql.org:/projects/cvsroot login
cvs -z3 -d :pserver:anoncvs at anoncvs.postgresql.org:/projects/cvsroot co
-P pgsql
cd psql
./configure
make
make install
+ geos 3.0.0 SVN
+ postgis svn + patch
+ proj 4.5.0
TECHER David a écrit :
> Hi Michael,
> I don't update my pg cvs
> I did
> co -P pgsql
> I will send you others messages later.
> thanks.
> Michael Fuhr a écrit :
>> On Wed, May 16, 2007 at 04:06:52PM +0200, TECHER David wrote:
>>> I apply the patch you give us but without any succeed on
>>> - postgresql 8.3 dev from cvs
>> How recently did you update your 8.3 source tree?
>>> - postgis from svn patched with your patch
>>> - geos from svn OR geos-3.0.0-rc4
>>> and proj 4.5.0
>>> All my regression tests failed :(.
>> Hmmm...I get all tests passed with the latest PostGIS from SVN and
>> the latest PostgreSQL 8.3devel from CVS.
>> postgis=> select postgis_full_version();
>> POSTGIS="1.2.2SVN" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22
>> Oct 2006" USE_STATS
>> (1 row)
>> postgis=> select version();
>> version
>> PostgreSQL 8.3devel on sparc-sun-solaris2.9, compiled by GCC gcc
>> (GCC) 3.4.2
>> (1 row)
>> How exactly did you build, install, and test PostgreSQL and PostGIS?
>> Do you have multiple versions of either installed on the same system?
>>> The regression test for loader (shp2pgsql --> make -C regress)
>>> implies that my server restarts! Why? I don't know
>> What errors appear in the PostgreSQL logs? Did you get a core dump?
>>> For example for the tiny SQL instruction
>>> testgis=# select postgis_full_version();
>>> Oct 2006" USE_STATS
>>> (1 ligne)
>>> testgis=# select 'LINESTRING(1 1, 2 2)'::GEOMETRY ~= 'LINESTRING(2
>>> 2, 1 1)'::GEOMETRY;
>>> NOTICE: compute_serialized_box3d called on unknown type 0
>>> ERROR: Unknown geometry type: 0
>> Works here:
>> postgis=> select 'LINESTRING(1 1,2 2)'::GEOMETRY ~= 'LINESTRING(2 2,1
>> 1)'::GEOMETRY;
>> ?column? ----------
>> f
>> (1 row)
>> Has anybody else tested the patch I sent against 8.3devel?
> ___________________________________________________________________________
> Yahoo! Mail r�invente le mail ! D�couvrez le nouveau Yahoo! Mail et
> son interface r�volutionnaire.
> http://fr.mail.yahoo.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070517/749c677f/attachment.ksh>
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070517/749c677f/attachment.bin>
