[postgis-users] How to load Invalid Geometries PostGIS
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 20 10:29:06 PDT 2007
Nicolas Ribot wrote:
> On 5/18/07, Orlando Giovanny Solarte Delgado <orsolarte at gmail.com> wrote:
>> Hi list.
>> I am developing geodatabase with PostGIS 1.2. I am tryin load shapefile
>> using shp2psql method from postgis. However, when I load shapefile
>> using sql. It say: "NOTICE: Ring Self-intersection", "violates check
>> constraint "geometry_valid_check".
>> Before to load shapefile, I test using chek_geomatry tool from
>> ArcTools from
>> ArcGIS 9.2, it say: "Valid geometries", but postgis say "violates check
>> So. How I can repair may shapefile before load postgis??. There is
>> some tool
>> different Check and repair Geometrias from ArcGIS?
>> Thanks.
> try using Jump (http://www.vividsolutions.com/jump/) or OpenJump
> (http://openjump.org/) to load the shapefile and check it.
> You will be able to visualize invalid geometries and repair them
You can remove the isvalid() constraint and load them, or create a
temporary table without the isvalid() constraint. Then try running
buffer(the_geom, 0.0) and recheck them.
-Steve W
