[postgis-users] error in extent command
Paul Ramsey pramsey at refractions.net
Mon May 21 07:30:05 PDT 2007
Wrap your extent() in a setsrid() function (or drop your srid
constraint).
This points up what I think is a bug (or at least bad behavior) in
that the output of extent should reflect the srid of the geometries
that go into it.
On 21-May-07, at 1:16 PM, temiz wrote:
> I created spatial db as:
> bzk2=# select addgeometrycolumn('exp1','geom',32767,'GEOMETRY',2);
> then I wanted to insert  this value to spatial db. But I received
> this message:
> update exp1 set geom=(select extent(wkb_geometry) from shey6  where
> shey6.cat=2);
> ERROR:  new row for relation "exp1" violates check constraint
> "enforce_srid_geom"
> what can I do ?
> regards
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> postgis-users mailing list
