[postgis-users] Problem with syntax in function
Ludovico Bianchini
metlud at yahoo.it
Tue May 22 14:20:20 PDT 2007
I'm using PostgreSQL 8.1. Trying this
CREATE OR REPLACE FUNCTION
myschema.sel_by_pos(varchar, varchar, varchar,
varchar)
RETURNS SETOF myschema.mytable AS
$BODY$
select * from myschema.mytable where (geom_column
SetSRID('BOX3D(' || $1 || ' ' || $2 || ', ' || $3 ||
' ' || $4 || ')'::box3d, 26591))
$BODY$> LANGUAGE 'sql' VOLATILE;
I get: ERROR: BOX3D parser - doesnt start with BOX3D(
CONTEXT: SQL function "sel_by_pos"
I'm in very trouble with this behaviour...
--- "Obe, Regina" <robe.dnd at cityofboston.gov> ha
scritto:
> If you are using 8.0 and above - you can use $
> quoting syntax. $ quoting is much saner to read and
> write than trying to escape out quotes. So your
> function would look something like
> varchar)
> $BODY$
> $BODY$
> LANGUAGE 'sql'
> I may have screwed up with the above so check my
> logic, but hopefully you get the idea.
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> on behalf of Ludovico Bianchini
> Sent: Tue 5/22/2007 10:21 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Problem with syntax in
> function
> Hi,
> I've a table with a geometry column (POINT).
> I've this working query to extract data:
> select * from myschema.mytable where (geom_column &&
> SetSRID('BOX3D(1754642 5059039, 1754644
> 5059041)'::box3d, 26591))
> I've tried to create a function from this query but
> I
> don't understand the use of quote to concat the
> string
> arguments. I've tried this
> varchar)
> 'select * from myschema.mytable where (geom_column
> SetSRID(''BOX3D(' || $1 || ' ' || $2 || ', ' || $3
> ' ' || $4 || ')''::box3d, 26591))'
> and I get ERROR: syntax error at or near "||" at
> character 223
> I don't understand where is the problem...
> ___________________________________
> L'email della prossima generazione? Puoi averla con
> la nuova Yahoo! Mail:
> http://it.docs.yahoo.com/nowyoucan.html
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
> The substance of this message, including any
> attachments, may be
> confidential, legally privileged and/or exempt from
> disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in
> error, please
> contact the sender and delete the material from any
computer.>
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail:
