Re: [postgis-users] problems with dumpin postgis data to shapefiles
Stefan Zweig
stefanzweig1881 at web.de
Thu May 24 05:21:08 PDT 2007
sorry @ list for bothering you,
i could just work out by myself what the problem was. anyway i am going to report the solution just in case anybody else will have this problem:
allright what you have to do in this case is:
1. open mc (midnight commander or comparable fileexplorer)
2. search for the file libpq.so.4
3. add the path where you could find libpq.so.4 file to /etc/ld.so.conf
4. run ldconfig
5. try again.
stefan
> Hi @ all
> i have just had a problem with dumping postgis data to a shapefile...
> i got the following error message:
> /usr/local/pgsql/bin/pgsql2shp -f demo.shp -g the_geom_005 -b mapdata public._g1
> /usr/local/pgsql/bin/pgsql2shp: error while loading shared libraries: libpq.so.4: cannot open shared object file: No such file or directory
> i would appreciate any help
> thanks in advance, stefan
> _______________________________________________________________
> SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
> kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
> postgis-users mailing list
