[postgis-users] Overlaps query
Thorsten Kraus Thorsten.Kraus at ptv.de
Fri May 25 00:41:05 PDT 2007
I want to query a geometry column using the PostGIS function 'overlaps'. The
query shoult return the number of overlapping geometries in a table.
Here is the query I tried:
SELECT COUNT(a.id) FROM tbl1 a, tbl1 b WHERE OVERLAPS(a.geom, b.geom) AND
a.id <> b.id
When I run the query, it takes a long time (96528ms) until PostGIS returns
the result although my table only contains 10 rows. Is there a possibility
to increase the performance of this query?
Regards,
Thorsten
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070525/75d4f9aa/attachment.html>
