[postgis-users] multipolygons to polygons
Nicolas Ribot
nicky666 at gmail.com
Tue May 29 00:28:21 PDT 2007
> Hi,
> I'm trying to run shp2pgsql with a polygon file but I'm getting the
> folloing error:
> "We have a multipolygon with 2 parts, can't use -S switch!"
> I know there is:
> -Multipolygons with holes.
> -Multipolygons with 2 external rings (originally one polygon cut into 2
> polygons).
> Is anything of this the reason why I cant use the -S switch?
Yes, the second one prevents shp2pgsql to convert from multipg to polygon.
> Is there a way around this to change the multipolygons to polygons?
Load your table with multipolygons in it, then dump them into simple
polygons, with the dump() function.
Nicolas
