[postgis-users] create a point fom lat/lon
Obe, Regina robe.dnd at cityofboston.gov
Wed May 30 16:08:09 PDT 2007
You have the lon and lat as part of your string so it wan't read the values.  Also POINT needs to be in upper case.
Try instead
update iter_rco_2005g
set
the_geom=geomfromtext('POINT(' || long || ' ' || lat || ')', 4326);
hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Nahum Castro
Sent: Wed 5/30/2007 6:50 PM
To: PostGIS Users Discussion
Subject: [postgis-users] create a point fom lat/lon
Hello all:
I have two columns lat and lon, from these columns I
want to create a point on the_geom column.
this is how i did
set
the_geom=geomfromtext('point(lon lat)', 4326);
and
set
the_geom=geomfromtext('point(lon, lat)', 4326);
lat an lon are in dd.
I get
ERROR:  Invalid OGC WKT (does not start with P,L,M or
G)
here is a sample data
 mun | loc  |       lat        |       lon
 020 | 0001 | 21.1197222222222 | 101.680555555556
 020 | 0261 | 21.0405555555556 | 101.503888888889
 020 | 0262 | 21.0241666666667 | 101.714444444444
 020 | 0263 |            21.15 | 101.607777777778
 020 | 0264 | 21.1944444444444 | 101.530555555556
 020 | 0266 | 20.9416666666667 | 101.613888888889
 020 | 0267 | 21.0494444444444 |         101.6875
 020 | 0271 | 20.9941666666667 | 101.589722222222
Thanks.
Nahum Castro
Leon, Guanajuato, Mexico
http://www.leon-linux.com <http://www.leon-linux.com/>
e-mail: pedro1_72 [en] yahoo [punto] com
___________________________________________________________
Do You Yahoo!?
La mejor conexión a Internet y <b >2GB</b> extra a tu correo por $100 al mes. http://net.yahoo.com.mx <http://net.yahoo.com.mx/>
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070530/892d6db1/attachment.html>
