[postgis-users] Shortest Distance from Every Point
David William Bitner
david.bitner at gmail.com
Sat Nov 3 08:55:10 PDT 2007
Absolutely anything to the left of the where statement has to either be
wrapped in an aggregate function or also in the group by clause when using
grouping.
On 11/3/07, Matthew Pulis <mpulis at gmail.com> wrote:
> Hi,
> I am trying to make a query so it parses through all the 16 cities i have
> in a table called city, and for each city, picks the nearest city, and gives
> me the distance between both cities.
> This is the query I made :
> select
> c.city_name, astext(c.the_geom), distance(c.the_geom, d.the_geom) AS
> Distance, d.city_name, astext(d.the_geom)
> from city c, city d
> where
> c.city_name = (
> select c.city_name order by c.city_name ASC
> and
> d.city_name = (
> select d.city_name order by d.city_name DESC
> group by c.city_name
> order by Distance DESC
> LIMIT 1;
> But I am getting this error : ERROR: column "c.the_geom " must appear in
> the GROUP BY clause or be used in an aggregate function
> I am seeing no reason why I should add c.the_geom, anyone can enlighten me
> more on why I should group by the_geom and after all if it does make sense?
> Thanks
> Matthew Pulis
> www.solutions-lab.net // www.mepa-clan.info
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071103/55782f14/attachment.html>
