[postgis-users] GEOS union() error
Lee Keel lee.keel at uai.com
Wed Nov 7 06:32:49 PST 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Obe, Regina
> Sent: Wednesday, November 07, 2007 8:22 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] GEOS union() error
> Lee,
> Did you try the collect buffer?
> I'm not sure why we have that explicit in the documentation - could be
> left over from another time? Should we remove that from the
> documentation.
> I've done it and it works fine except when I had some invalid geometries
> I think it created some strange results but never errored out.
> Hope that helps,
> Regina
[Lee Keel]
I didn't try it, but I will if you say it will return reliable results.  I
was just unsure what the result set would be when using buffer on a geometry
collection; will it return a geometry collection of polygons, or return one
large multipolygon (which is what I am looking for)?
I agree that if buffer() will accept a geometrycollection, then it should be
removed from the documentation.  The same warning is in the documentation in
a few places, is this the only place that it is valid now?
-LK
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
