[postgis-users] GEOS union() error
Lee Keel
lee.keel at uai.com
Thu Nov 8 07:56:04 PST 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
> Sent: Wednesday, November 07, 2007 7:38 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] GEOS union() error
> On a linux system you would need to adjust your SHMMAX and SHMMIN
> settings.
> http://www.postgresql.org/docs/8.2/static/kernel-resources.html#SYSVIPC
> I'm not sure on a Windows box...
> -- Kevin
[Lee Keel]
I read that earlier, but also saw where it said "(For the Windows port,
PostgreSQL provides its own replacement implementation of these
facilities.)" and assumed that meant there was no such configuration setting
in Windows.
-LK
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
