[postgis-users] Write out KML for each database record?
Dane Springmeyer blake at hailmail.net
Thu Nov 8 13:57:30 PST 2007
Hi Marc,
Exactly. You are perceptive- immediately after I got things working I
realized that the way the Php FOR LOOP worked it would make it
impossible to write out KML for records returned by a dynamically
changing query.
As such I worked with the example here (http://code.google.com/
support/bin/answer.py?answer=69906&topic=11364) and modified the
mysql functions to work for postgres and arrived essentially at the
exact example you just sent. Thanks!
This approach is cool because it allows kml to be written for any
number of rows returned by a query as long as some column in the
database contains a numeric or string unique id.
I've posted the generalized form of the script below. There are two
noteworthy additions for those interested:
One is the use of "askml(centroid(the_geom))" to grab the center
point of each polygon, which is used in the while loop to create kml
labels.
The other is the use of only a single postgis query. PHP loops
through the results as an array and writes each kml to the local file
system. I'm currently testing the speed of this method vs. using the
COPY command. If you have any opinions about speed or shortfalls of
having php write to the filesystem I would be interested to hear.
Also, if anyone is interested in playing with the full script just
let me know and I'll send it along.
Cheers,
Dane
<?php
$conn= pg_connect($cstring);
//Form up KML Header and Styles
$kml_header .= 'lots of XML HERE if you like styling';
// Select all the rows in a table that match given criteria.
$sql = "SELECT *,  askml(the_geom) as poly_geometry,  askml(centroid
(the_geom)) as poly_centroid from table where = any_value";
$result =  pg_exec($sql);
while ($row = pg_fetch_array($result)) {
	//KML Header
	$kml = $kml_header
	//Key Variable
	$name = $row['id'] //where id is some unique in selected table id
whether text or number
	//Form up KML polygon
	$kml .= '<Placemark>';
	$kml .= '<name>' . $name . '</name>';
	$kml .= '<styleUrl>#transbluePoly</styleUrl>';
	$kml .= $row['poly_geometry'] ;
	$kml .= '</Placemark>';
	//Form up KML label at centroid of polygon
	$kml .= '<styleUrl>#label_map</styleUrl>';
	$kml .= $row['poly_centroid'] ;
	//KML Footer
	$kml .= '</Document></kml>';
	//Use PHP to write each kml to the local filesystem with respective
id number
	$filepath = '/Users/Shared/kml/' . $name . '.kml';
	file_put_contents("$filepath", "$kml");
> $sql="SELECT Id FROM your_table";
> $rs=pg_exec($sql);
> while ($row=pg_fetch_array($rs)) {
> $query = pg_query("Copy (Select '$header' || askml(the_geom) ||
> '$footer' From YOUR_TABLE Where id=".$row["Id"].") TO 'DATA_PATH/
> record_".$row["Id"].".kml'; ");
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071108/73472e0c/attachment.html>
