[postgis-users] GEOS union() error
Martin Davis mbdavis at refractions.net
Fri Nov 9 11:33:22 PST 2007
Buffer always returns a polygonal answer (either a Polygon or a
MultiPolygon).
Buffer will accept all inputs, including GeometryCollections.  The doc
should be changed to reflect this.
Martin
Obe, Regina wrote:
> >From my experience it always returns a multipolygon giving a geometry
> collection of multipolygons.
> Actually collect doesn't always return geometry collections anyway.  If
> you say collect a bunch of polygons and they are not overlapping, then
> from my experience that returns a multipolygon.  If you start with
> multipolygons,then it returns a geometry collection, but if you then
> buffer that geometry collection, its seems to result in a multipolygon
> for me - never had it return a geometry collection.  I think its
> something about the process of buffering that strips out the geometries
> from the geometry collection - since if you feed it a single polygon
> encased in a multipolygon structure, it returns a polygon.
> I don't know too much of the details of why that is.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Lee
> Keel
> Sent: Wednesday, November 07, 2007 9:33 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] GEOS union() error
>> bounces at postgis.refractions.net] On Behalf Of Obe, Regina
>> Sent: Wednesday, November 07, 2007 8:22 AM
>> Lee,
>> Did you try the collect buffer?
>> I'm not sure why we have that explicit in the documentation - could be
>> left over from another time? Should we remove that from the
>> documentation.
>> I've done it and it works fine except when I had some invalid
> geometries
>> I think it created some strange results but never errored out.
>> Hope that helps,
>> Regina
> [Lee Keel]
> I didn't try it, but I will if you say it will return reliable results.
> I
> was just unsure what the result set would be when using buffer on a
> geometry
> collection; will it return a geometry collection of polygons, or return
> one
> large multipolygon (which is what I am looking for)?
> I agree that if buffer() will accept a geometrycollection, then it
> should be
> removed from the documentation.  The same warning is in the
> documentation in
> a few places, is this the only place that it is valid now?
> -LK
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this email in error please notify the
> sender. This message contains confidential information and is intended
> only for the individual named. If you are not the named addressee you
> should not disseminate, distribute or copy this e-mail.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
