[postgis-users] data extract
Andre Schoonbee andresch at iway.na
Mon Nov 12 23:19:57 PST 2007
I have various tables in my POSTGIS database. Each table contains a type
field (column) that define the type of structure, such as the type of road
eg. I want to extract a few sample data from each table, but should contain
at least one of each type so that a developer can test this data against a
mapserver mapfile. I do not want to dump the entire database (to big).That
should the sql command looks like
Regards
Andre
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Zedler,
Doug
Sent: Wednesday, October 03, 2007 5:03 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Installation Error
I'm trying to install PostgreSQL and PostGIS to play with it and learn about
it.  I installed PostgreSQL 8.2.4 just fine.  I am able to connect using
pgAdmin III and such.  When I run the PostGIS 1.3.1 installation executable,
I get the following error:
createdb: could not connect to database postgres: FATAL:  password
authentication failed for user "postgres"
I am able to connect to the postgres database using pgAdmin III under the
postgres role using the same password I'm putting into the installation
wizard, and I'm not mixing up the password for the database role with the
password for the local account on my machine.  Any suggestions are
appreciated.
Thanks,
Douglas B. Zedler
IT Programmer/Analyst
Fort Worth Fire Department
817.392.8463
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071113/19b1af3c/attachment.html>
