[postgis-users] data extract
    Andre Schoonbee
    andresch at iway.na
    Tue Nov 13 03:46:44 PST 2007
Thanks!
Now the next question.
I now want to export (dump) the data I have selected.
Andre
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of George
Pavlov
Sent: Tuesday, November 13, 2007 9:27 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] data extract
select *
from your_table
where unique_id in (
  select max(unique_id)
  from your_table
  group by structure_type
> Behalf Of Andre Schoonbee
> Sent: Monday, November 12, 2007 11:20 PM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] data extract
> Importance: High
> I have various tables in my POSTGIS database. Each table
> contains a type field (column) that define the type of
> structure, such as the type of road eg. I want to extract a
> few sample data from each table, but should contain at least
> one of each type so that a developer can test this data
> against a mapserver mapfile. I do not want to dump the entire
> database (to big).That should the sql command looks like
> Regards
> Andre
> ________________________________
> Behalf Of Zedler, Doug
> Sent: Wednesday, October 03, 2007 5:03 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Installation Error
> I'm trying to install PostgreSQL and PostGIS to play with it
> and learn about it.  I installed PostgreSQL 8.2.4 just fine.
> I am able to connect using pgAdmin III and such.  When I run
> the PostGIS 1.3.1 installation executable, I get the following error:
> createdb: could not connect to database postgres: FATAL:
> password authentication failed for user "postgres"
> I am able to connect to the postgres database using pgAdmin
> III under the postgres role using the same password I'm
> putting into the installation wizard, and I'm not mixing up
> the password for the database role with the password for the
> local account on my machine.  Any suggestions are appreciated.
> Thanks,
> Douglas B. Zedler
> IT Programmer/Analyst
> Fort Worth Fire Department
> 817.392.8463
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
