[postgis-users] geomunion revisited....
Lee Keel
lee.keel at uai.com
Tue Nov 13 08:44:00 PST 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Martin Davis
> Sent: Tuesday, November 13, 2007 10:28 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] geomunion revisited....
> buffer may or may not be faster than geomunion. For "small" cases it
> almost certainly is. However, for very large inputs it may bog down,
> because it loads and processes all geometries at once (and thus doesn't
> have a chance to eliminate linework which would be eliminated in the
> resulting union). Geomunion, while inefficient as Kevin points out, at
> least has the chance to simplify the result geometry as it goes along.
> *However*, geomunion is "dumb" in that it doesn't try to union adjacent
> polygons first - so it doesn't simplify anywhere nearly as much as it
> could.
> A better tool would be to use the new cascaded union operation in JTS
> (which hopefully can get ported to GEOS & PostGIS soon).
> @Lee: are you positive about your ArcGIS result? It's using exactly the
> same dataset?
[Lee Keel]
I am not sure how much the 'cascaded union' will help until it gets ported
to PostGIS.
As for the ArcGIS results, well.... I am as certain as I can be base on my
client. I have not actually performed this operation for them, but
according to my contact there those are accurate numbers for the same
dataset.
-Lee
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
