[postgis-users] A simple GeomFromText
Amrita p amritaprasad1 at rediffmail.com
Wed Nov 14 00:51:19 PST 2007
Because in ur table the constraint is 2 dimension.  U cant store point into ur table. To store point delete the constraint for two dim.
On Thu, 01 Nov 2007 mcompte at sigte.udg.es wrote :
>Hi,
>I might have missed something, but I keep looking at it and can't
>understand why the following keeps throwing an 'invalid geometry' error :(
>Here's the table:
>CREATE TABLE asistentes
>   gid int8 NOT NULL,
>   nombre varchar(150),
>   longitud float8,
>   latitud float8,
>   the_geom geometry,
>   geometria geometry,
>   CONSTRAINT asistentes_pkey PRIMARY KEY (gid),
>   CONSTRAINT enforce_dims_geometria CHECK (ndims(geometria) = 2),
>   CONSTRAINT enforce_geotype_geometria CHECK (geometrytype(geometria) =
>'POINT'::text OR geometria IS NULL),
>   CONSTRAINT enforce_srid_geometria CHECK (srid(geometria) = 4326)
>WITHOUT OIDS;
>ALTER TABLE asistentes OWNER TO postgres;
>The table is already populated and then I try updating one of the
>geometries with:
>UPDATE asistentes SET geometria=GeometryFromText('POINT(1,1)', 4326) WHERE
>gid=3;
>And I get the following Explain comment?
>La consulta insertó una fila con OID 0.
>ERROR:  parse error - invalid geometry
>The spanish line says something like 'the query added one row with OID 0'.
>If anyone could shed some light on this I'd very much appreciate it :)
>Marc
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071114/cf888fe3/attachment.html>
