[postgis-users] UML Profile using PostGIS geometrytypesandSQL-MMtopology functions
Fonseca Hespanha de Oliveira, Joao da
J.P.daFonsecaHespanhadeOliveira at tudelft.nl
Wed Nov 14 07:42:28 PST 2007
As promised in a previous Email in this topic, I prepared a new version
of the SQL/MM and Simple Features compliant geometry data types, as
implemented in PostGIS. This new UML Class Diagram shows all the methods
relevant to each of the spatial types, their parameters and return
types. This Diagram has just an informative value into building the
actual UML Profile.
Any comments/suggestions/corrections will be appreciated.
PS: I am using Enterprise Architect in order to produce the UML Profile.
Regards,
Joao
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sent: Monday, November 12, 2007 6:10 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] UML Profile using PostGIS
An Open Source project using EMF and Hibernate for a Model to Text and
ORM type of job certainly looks very interesting to my research. I will
visit the Hibernatespatial page for sure, although the specific
environment I am thinking of is not the same.
Thanks for the precious help,
Regards,
Joao
karel
Sent: Friday, November 09, 2007 9:07 PM
Subject: Re: [postgis-users] UML Profile using PostGIS geometry
I've some experience with EMF using Hibernate in the context of spatial
data.
We used EMF + teneo + OWL to generate a database + java binding from an
OWL file. We wrote a tool that generated an Ecore model from the OWL
file. This Ecore model than was used to generate the Java code (EMF),
Hibernate mapping file (Teneo). The spatial data types were handled by
an extension to Hibernate. This extension is now an independent open
source project. You can find it here: http:// www.hibernatespatial.org/.
There is a comparable project for JPOX persistence. See:
http://www.jpox.org/docs/1_1/spatial.html. JPOX is another ORM solution.
Regards,
Karel Maesen
On 09 Nov 2007, at 15:25, Fonseca Hespanha de Oliveira, Joao da wrote:
> Norman:
> Thanks for all the usefull advices concerning possible implementations
> to follow in my tool development.
> The UML Profile I intend to develop is just a piece of the whole
> process, but an important one. I believe a good profile for spatial
> features is required to get UML to (spatial) database transformations,
> and currently EA has none.
> Also, the current schema transformation templates do not take into
> account the processing of OCL constraints. Even the XMI generated from
> the UML tool does not have it in the UML2 namespace, just in its own
> extended namespace (in the EA case, at least).
> There is also the possibility to specify queries (most will be
> validation ones) from the model itself.
> I agree the full potential of such a tool could only be unleashed if
> there will be an object model generated in between. I am currently
> considering using the Eclipse EMF for that purpose, namely because it
> offers UML and also OCL parsing in an Open Source environment.
> Hibernate came into consideration just recently (I am a newbie
> concerning Java technologies; was used to the MS platform :-) ), just
> got a copy of the "Java Persistence with Hibernate". From a first
> look, it seams it has indeed a lot of features, in fact it could
> supply much of the functionality I have in mind.
> Returning to the UML Profile for PostGIS geometry types, I am not
> being able to get a full description of the methods which apply to
> each geometry type, at least in the same way they are expressed on the
> Simple Features Access or the SQL/MM standards. Is there any document
> on these matters?
> Consideration of PostGIS specific geometry types, constraints and
> methods would make this a "UML PostGIS Profile", and not anymore a
> generic SQL/MM Profile, but this serves well my immediate research
> objectives.
> Joao
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Norman Barker
> Sent: donderdag 8 november 2007 21:19
> Subject: RE: [postgis-users] UML Profile using PostGIS geometry types
> Hi,
> I am not sure that UML to database is going to achieve that much in
> terms of mapping, but certainly UML to object (so ejb3 or
> geodjango) and hence database might be interesting. To this end
> hibernate tools is useful (and generates schematics) and just changing
> the free marker templates allows geometry mappings.
> Most of the work in this area has been in UML to xml schema mapping,
> and to this end the models (including EA Architect) from
> http://www.isotc211.org/ might be of use.
> If I were doing this work, then the tool I would use would be the new
> eclipse UML tools, just because these are publicly available to
> everyone, and the XMI they output would be useful in a lot of
> projects.
> ERD tools such as dbdesigner for mysql already support spatial
> functions, hence why I am struggling to see the benefit of your
> approach - can you explain some more?
> Thanks,
> Norman
> users-bounces at postgis.refractions.net] On Behalf Of Fonseca
> Sent: Thursday, November 08, 2007 11:12 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] UML Profile using PostGIS geometry types
> and SQL-MMtopology functions
> Hello all!
> As part of my current PhD research, I am trying to specify a new
> UML Profile to apply to UML Class diagrams representing spatial
> features, that is, using geometry types.
> I am using PostgreSQL's PostGIS extension as reference for the
> actual geometry types, but I think it could be applied to any
> spatial database system which complies to the Simple Features
> Access for SQL specification.
> Currently, also geometry types from SQL/MM ISO/IEC standard are
> also being supported by such databases, and at least some will be
> added to the Profile.
> I would like to receive any suggestions this forum members might
> have, I am currently using Enterprise Architect (EA) as UML
> Modeling Tool and I plan to present (attach) PDF files with the
> class diagrams and the final Profile. Maybe the profile could be
> added to the EA add ons later on, otherwise it could be transposed
> to other UML Tools.
> If somebody has a suggestion on any other way to interact, with or
> without EA software, ideas are also most welcome.
> The final aim of this research component is to define a CASE tool
> which can use a UML model with the mentioned profile to generate a
> PostGIS schema through an automatic generated SQL script (a process
> generally known as Model-to-Text transformation).
> Looking forward to hear from you,
> Joao Paulo Hespanha
> PhD Student, OTB Research Institute,
> TUDelft
> The Netherlands
> postgis-users mailing list
Type: application/octet-stream
Desc: SQLMMGeometryTypes.pdf
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071114/b5f371f0/attachment.obj>
