[postgis-users] pgsql2shp and prj support
Dane Springmeyer
blake at hailmail.net
Wed Nov 14 14:12:12 PST 2007
It appears that the pgsql2shp tool does not write out .prj files
alongside shp output?
After I dump out shapefiles I like to view them in Qgis or Udig and
both like/require .prj files for projection of shapefiles. I know
that you can assign them inside inside either of these apps but it
would be nice to have them created automatically.
Since I am using php to batch dump a number of shapefiles, and I've
been able to nest these two SQL statements within the script to be
able to get the "SRTEXT" and write it to a .prj file that corresponds
to each shapefile:
SELECT ST_SRID(the_geom) from MyTable limit 1;
SELECT srtext from spatial_ref_sys WHERE srid = 2964 // Alaska Albers...
It seems like this would be a useful thing to have as part of the
pgsql2shp utility. Does it already do this and I a missing something,
or is this a feature request?
I noted this discussion (http://postgis.refractions.net/pipermail/
postgis-users/2004-October/005958.html) from '04 that notes the
ability to use the srtext entry in the spatial_ref_sys. Has this been
discussed since?
Cheers,
Dane
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071114/9edb3b46/attachment.html>
