[postgis-users] Help with  Geography's Coordinates
    Chris Hermansen
    chris.hermansen at timberline.ca
    Wed Nov 14 22:11:27 PST 2007
Estimado Marco;
You may be able to use ogr2ogr to convert from your longitude and
latitude into some type of projected coordinate system like UTM.
What exactly does your data look like?  Is it ASCII points, or...?
I find the documentation for ogr2ogr to be a bit challenging.  You will
need to read it carefully and you will also need a basic understanding
of spatial data formats and geographic projections.
Since this isn't really about PostGIS - I think :-) - if you want to
write directly to me I can try to help you out a bit more, en inglés o
castellano.
Marco Aurelio (Skull Leader) wrote:
> I have some Coordinates with Lenght and Latitude, but i have the
> problem when i try to convert it in X and Y Coordinates, i want to
> make a graph with SVG, someone know how i can do it?
> Thanks.
> Marco
> ¡Capacidad ilimitada de almacenamiento en tu correo!
> No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
> http://correo.yahoo.com.mx/
> postgis-users mailing list
Regards,
Chris Hermansen · mailto:clh at timberline.ca
tel:+1.604.714.2878 · fax:+1.604.733.0631
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
C'est ma façon de parler.
