[postgis-users] How do PostGIS&SQL Server 2008 with geospatialsupport compare ?
Obe, Regina
robe.dnd at cityofboston.gov
Tue Nov 20 05:12:43 PST 2007
Just to add. From what I have heard. You will not be able to reproject
your data within SQL Server 2008. So this means if you have your data
in geodetic, you can't then convert it to planar without a third party
tool such as FME or Manifold.
Within planar you will not be able to transform from one Spatial ref to
another without a third party tool. I presume this will change over
time and not sure if it will change before release.
Of course the November CTP I don't think has been released yet or I
haven't got my hands on it yet to confirm this. This will be the first
CTP to have spatial support in it.
Anyrate - I'll be trying it out when it comes out for due diligence
since I run big SQL Server 2005 shops and I'll try to report back what I
find.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Guido Lemoine
Sent: Tuesday, November 20, 2007 3:03 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] How do PostGIS&SQL Server 2008 with
Plus Postgis available also on other than the SQL Server-specific OS
and at (near) zero cost. What is big about geodetic support, by the
way?
GL
Paul Ramsey wrote:
> Too soon. Probably comparable, with PostGIS having a smattering of
> features that SQL Server does not, and SQL Server having one big
> feature (geodetic support) that PostGIS does not.
> Steven De Vriendt wrote:
>> Hi list,
>> Maybe my question comes a bit soon, still I wonder how the two
>> compare. For now we use PostGIS and SQL Server 2005 next
>> to each other in our organization.Spatial support looks promising
>> but I don't know if it's worth to take the SQL 2008-spatial support
>> in account.
>> (read: if the price tag will justify SQL server above PostGIS).
>> Cheers
>> Steven
Guido Lemoine
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Support to External Security
Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent
the views of the European Commission
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
