[postgis-users] Query performanace against huge point table
Santosh Gaikwad
Santosh.Gaikwad at saama.com
Tue Nov 20 22:02:53 PST 2007
Hi Kevin,
Thank you very much for your help. I created now the functional index of
"transform(the_geom,2163)" on my geometry column. It is faster now. I
would like to know whether clustering of indices helps in speeding up
the query.
Thanks & Regards,
Santosh Gaikwad
Senior Software Developer
Saama Technologies (India) Pvt. Ltd.,
Unit No.101-102, First floor,
Weikfield IT CITI INFO PARK,
Weikfield estates,
Pune Nagar Road,
Pune - 411 014. India
Phone : +91 20 66071397
Mobile: +91-9422005927
E-mail :Santosh.Gaikwad at saama.com
http://www.saama.com
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Wednesday, November 21, 2007 2:23 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Query performanace against huge point table
ST_DWithin(...) is a simple sql wrapper around the following sql string:
"SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND
ST_Distance($1, $2) < $3"
where $1,$2,and $3 are your parameters.
So, unless you have a GIST functional index of "transform(the_geom,
2163)" on your geometry column, your query won't use any indexes.
I suggest to either create the mentioned function index or create a new
geometry column of your points in the 2163 projection and do something
like this:
SELECT *
FROM table a,
(SELECT transform(GeomFromText('POINT(-122.0527
37.323)',4326),2163) AS the_geom) b
WHERE ST_DWithIn(a.the_geom, b.the_geom, 1000);
Cheers,
Kevin
Santosh Gaikwad wrote:
> Hi,
> I have a point table which contains 300 millions of records. I am
> using following query to fetch the records from the table within
> certain radius.
> Select *
> from table
> where
> st_dwithin(
> transform(the_geom,2163),
> transform(GeomFromText('POINT(-122.0527 37.323)',4326),2163),
> 1000
> But it takes long time to get the result. I am seeking help.
> Thanks & Regards,
> Santosh Gaikwad
> Weikfield estates,
> Pune Nagar Road,
> postgis-users mailing list
Name: Santosh Gaikwad.vcf
Type: text/x-vcard
Desc: Santosh Gaikwad.vcf
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071121/631bdefd/attachment.vcf>
