[postgis-users] Moving database to another tablespace
Kevin Neufeld
kneufeld at refractions.net
Wed Nov 21 08:51:58 PST 2007
Unfortunately, PostgreSQL does not yet have the command "ALTER DATABASE
SET TABLESPACE new_tablespace" (I don't see it in v.8.3 either).
The easiest solution I think is to simply create a new database using
your current database as a template in your new tablespace.
From the command line:
createdb -T my_db -D new_tablespace
Alternatively, you can move individual tables or indexes to your new
tablespace. I often do this to increase I/O - split the most heavily
used tables/indexes over separate raid stacks.
ALTER TABLE <tbl> SET TABLESPACE <new_tablespace>;
You would have to do this for every table/index you plan on moving, but
this can be easily accomplished by using SQL to generate a SQL script.
ie.
-- send query results to a file.
/o script.sql
/t
SELECT 'ALTER TABLE ' || schemaname || '.' || tablename || ' SET
TABLESPACE new_tablespace;'
FROM pg_tables
WHERE schemaname = 'foo';
\o
\i script.sql
\t
Cheers,
Kevin
Thorsten Kraus wrote:
> Hi,
> I have installed a database on the standard tablespace, but the
> database grows fast and there's no more space on the partition available.
> So I've created another tablespace on another partition. Is it
> possible to move my existing database to this new tablespace? If yes,
> what steps have to be done?
> Bye Thorsten
> postgis-users mailing list
