[postgis-users] where to register to submit bug?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Nov 21 14:21:16 PST 2007
On Mon, 2007-11-19 at 22:40 +0100, Ivan Mincik wrote:
> thanks a lot. these wrong are coming from some special format of
> cadastral data in my country.  data where first saved to ESRI
> shapefile by OGR, then imported to postgis by shp2pgsgl. I think that
> they are invalid also for the shapefile. can it be similar issue?
> again thank you very much
> ivan  mincik
Hi Ivan,
I'm not sure exactly what the validity rules are for shapefiles, however
in your case it would be OGR that would determine how invalid polygons
would appear in the shapefile. Regardless of whether the source data is
at fault, or OGR's method of handling invalid geometries, PostGIS is
still wrong in accepting them in (E)WKB format.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
