[postgis-users] Intersection() error
Gustavo Martinez gumartin at mecon.gov.ar
Fri Nov 23 06:12:01 PST 2007
I am trying to calculate the area of the intersection of several polygons with
the following query:
select idrectangulos, nro_rct, area(geom)/1000000 as total,
area(st_intersection(geom,(select geom from zonas where cat=9)))/1000000 as
rio,
area(st_intersection(geom,(select geom from zonas where cat=1)))/1000000 as
zcp,
area(st_intersection(geom,(select geom from zonas where cat=3)))/1000000 as
zee,
area(st_intersection(geom,(select geom from zonas where cat=2)))/1000000 as
pcia
from rectangulos
However, I got the following error:
NOTICE:  TopologyException: no outgoing dirEdge found
(-68.3024,-52.6125,-52.6125)
ERROR:  GEOS Intersection() threw an error!
How can I handle this?
Thanks
Gustavo
Lic. Gustavo Martínez
Gestión de Pesquerías
Sub Secretaría de Pesca de la Nación
Paseo Colón 982, Anexo Jardín Pesca
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
