[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
William Kyngesburye
woklist at kyngchaos.com
Sun Nov 25 13:49:03 PST 2007
Well, for me at least, it appears that PostGIS built on Leopard is
crashing Postgres. Happens in both 32bit and 64bit modes. I'm going
to try my old PostGIS build (built on Tiger) with my new Postgres
build, to help narrow it down (see if it's Postgres problem).
Here's what I get in the Postgres log:
STATEMENT: SELECT AsKML(GeomFromEWKT('POINT(1 1)'));
LOG: server process (PID 19619) was terminated by signal 10
LOG: terminating any other active server processes
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted at 2007-11-25 15:29:20 CST
LOG: checkpoint record is at 0/C99D88
LOG: redo record is at 0/C99D88; undo record is at 0/0; shutdown TRUE
LOG: next transaction ID: 0/3788; next OID: 32768
LOG: next MultiXactId: 1; next MultiXactOffset: 0
LOG: database system was not properly shut down; automatic recovery
in progress
LOG: record with zero length at 0/C99DD0
LOG: redo is not required
LOG: database system is ready
And in the Postgres crashlog:
Application Specific Information:
*** single-threaded process forked ***
Thread 0 Crashed:
0 libSystem.B.dylib 0x900e1831 get_uint32 + 32
1 liblwgeom.so 0x0062ff6d lwcurve_deserialize + 125
2 liblwgeom.so 0x0061acfe parse_WKT_lwgeom + 142
3 postgres 0x000d6e75 ExecMakeFunctionResult +
874
4 postgres 0x000d6a75 ExecEvalFuncArgs + 91
5 postgres 0x000d6b7b ExecMakeFunctionResult +
112
6 postgres 0x000d76e8 ExecProject + 441
7 postgres 0x000e4553 ExecResult + 175
8 postgres 0x000d3e1c ExecProcNode + 216
9 postgres 0x000d269d ExecutorRun + 471
10 postgres 0x00160117 PortalRunSelect + 153
11 postgres 0x00161563 PortalRun + 625
12 postgres 0x0015c6b8 exec_simple_query + 1047
13 postgres 0x0015e5d1 PostgresMain + 6102
14 postgres 0x00135e91 ServerLoop + 3329
15 postgres 0x001375c7 PostmasterMain + 5061
16 postgres 0x000f461d main + 1378
17 postgres 0x000026ec _start + 210
18 postgres 0x00002619 start + 41
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000009 ebx: 0x0062ff01 ecx: 0x0085ba75 edx: 0x00000005
edi: 0x00000004 esi: 0x0085ba75 ebp: 0xbfffde18 esp: 0xbfffde18
ss: 0x0000001f efl: 0x00010207 eip: 0x900e1831 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000005
Fro 64bit mode, the thread state is:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000006 rbx: 0x000000010082ba31 rcx:
0x0000000000000020 rdx: 0x0000000000000002
rdi: 0x000000010082ba31 rsi: 0x0000000000001790 rbp:
0x00007fff5fbfdb10 rsp: 0x00007fff5fbfdb10
r8: 0x0000000000000002 r9: 0x0000000000000001 r10:
0x0000000100504220 r11: 0x00000001001c5627
r12: 0x0000000000000000 r13: 0x000000010082ba30 r14:
0x000000010082ba80 r15: 0x00000000000382fc
rip: 0x00007fff8269ceea rfl: 0x0000000000010283 cr2:
0x0000000000000002
On Nov 25, 2007, at 2:19 PM, William Kyngesburye wrote:
> Possibly a permissions problem? I just ran the tests on my new
> Leopard build, using GEOS 3, and got 36/37 fails.
> Look in that /var/folders/... loader.err. I got:
> BEGIN
> psql:/var/folders/sR/[snip]/-Tmp-/loader:2: NOTICE: CREATE TABLE
> will create implicit sequence "loadedshp_gid_seq" for serial column
> "loadedshp.gid"
> psql:/var/folders/sR/[snip]/-Tmp-/loader:2: NOTICE: CREATE TABLE /
> PRIMARY KEY will create implicit index "loadedshp_pkey" for table
> "loadedshp"
> CREATE TABLE
> psql:/var/folders/sR/[snip]/-Tmp-/loader:3: ERROR: permission
> denied for relation geometry_columns
> CONTEXT: SQL statement "DELETE FROM geometry_columns WHERE
> f_table_catalog = '' AND f_table_schema = 'public' AND
> f_table_name = 'loadedshp' AND f_geometry_column = 'the_geom'"
> PL/pgSQL function "addgeometrycolumn" line 94 at execute statement
> SQL statement "SELECT AddGeometryColumn('', $1 , $2 , $3 , $4 , $5 ,
> $6 )"
> PL/pgSQL function "addgeometrycolumn" line 4 at SQL statement
> Even though I made my user role the owner of the postgis_reg
> database, the lwpostgis.sql must be run as th postgres role, and it
> gets ownership of the geometry_columns table. And one big annoyance
> I've had with postgres is that it doesn't inherit privileges like
> you'd think.
> After setting up the postgis_reg DB for postgis, grant yourself all
> privileges on the geometry_columns table. After doing this, I now
> get 32/37 fails - still a lot, but it's a start.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
