[postgis-users] Intersection() error
Gustavo Martinez
gumartin at mecon.gov.ar
Mon Nov 26 09:54:56 PST 2007
As you can see in the select clause, I use different polygons. The one that
causes the error is the last one. I paste the WKT def.
Gustavo
El Monday 26 November 2007 14:25:32 escribió:
> Are your input geometries valid?
> We're going to need more information if we're to help you. Perhaps
> isolate the two geometries that are causing the error and if they are
> small enough, post the WKT representation here.
> -- Kevin
> Gustavo Martinez wrote:
> > Hi,
> > I am trying to calculate the area of the intersection of several polygons
> > with the following query:
> > select idrectangulos, nro_rct, area(geom)/1000000 as total,
> > area(st_intersection(geom,(select geom from zonas where cat=9)))/1000000
> > as rio,
> > area(st_intersection(geom,(select geom from zonas where cat=1)))/1000000
> > as zcp,
> > area(st_intersection(geom,(select geom from zonas where cat=3)))/1000000
> > as zee,
> > area(st_intersection(geom,(select geom from zonas where cat=2)))/1000000
> > as pcia
> > from rectangulos
> > However, I got the following error:
> > NOTICE: TopologyException: no outgoing dirEdge found
> > (-68.3024,-52.6125,-52.6125)
> > ERROR: GEOS Intersection() threw an error!
> > How can I handle this?
> > Thanks
> > Gustavo
POLYGON ((
-68.3024156681654 -52.6124604217674,
-68.2995863690719 -52.6147948586398,
-68.2993019657741 -52.614454327381,
-68.2882169323626 -52.62371227354,
-68.2737487954298 -52.6367865890656,
-68.2653612069653 -52.6449825869654,
-68.2589340258631 -52.6496191775952,
-68.2288368517834 -52.6751760276361,
-68.2179158543504 -52.6860458056634,
-68.2046822397846 -52.6949681761997,
-68.1964750414356 -52.7015259792658,
-68.1692965522726 -52.7194109148382,
-68.1536944944803 -52.7321250130399,
-68.1248890592601 -52.7609642512155,
-68.1229979627267 -52.7625801182996,
-68.1040539898501 -52.7798911539469,
-68.063624726859 -52.8273716103989,
-68.0518676492153 -52.8453045245878,
-68.0352861481673 -52.8747649280093,
-68.0261991173958 -52.8938199694848,
-68.0132050044443 -52.9320530514387,
-68.003442476045 -52.95668345806,
-68.0009403522209 -52.964480438497,
-67.9999774520746 -52.9692470796531,
-67.9785248055801 -53.0020129979631,
-67.9714626916364 -53.0196358813931,
-67.9671459436232 -53.0275010694885,
-67.9534982551533 -53.0665326770591,
-67.9464707697995 -53.1072799498477,
-67.9458448427986 -53.1143749626582,
-67.9461813046316 -53.1581191046234,
-67.9359925425241 -53.1688884843902,
-67.9255175943166 -53.1813095093476,
-67.9155719380714 -53.1953829008551,
-67.9018600440974 -53.2084051222607,
-67.8891040531438 -53.2231221516614,
-67.8662877027752 -53.2539349977965,
-67.8554767324516 -53.2711548551011,
-67.8326009634992 -53.317713767025,
-67.8198265388677 -53.36799146745,
-67.8171854481099 -53.386093868825,
-67.803423552163 -53.4145258961433,
-67.8031302362801 -53.4152467420835,
-67.8012871017033 -53.4171922003767,
-67.781226071736 -53.4276105202901,
-67.7449350956251 -53.4559808635468,
-67.7434353177379 -53.4576813408903,
-67.7260690296941 -53.4700321588391,
-67.7106802312013 -53.4794962152886,
-67.6966786956732 -53.4887693108216,
-67.6847034231894 -53.4972925846626,
-67.6764521605278 -53.5025943665448,
-67.6695158549575 -53.5051342617636,
-67.6695158549575 -53.5051342617637,
-67.6346737762207 -53.5210152906873,
-67.6214427643037 -53.5283178767259,
-67.6118293790507 -53.5329613990894,
-67.5747919624378 -53.5549745928251,
-67.5739621718626 -53.5555701661698,
-67.5616890706415 -53.5638397182992,
-67.5590553837632 -53.5660960866217,
-67.5590511285035 -53.5660977123913,
-67.548835754905 -53.572223168343,
-67.5445898904238 -53.5735011667033,
-67.533038756141 -53.5774191951381,
-67.5023876802576 -53.5910499173587,
-67.4997007991429 -53.5920582559854,
-67.4843319569292 -53.5984168520372,
-67.4650759006519 -53.607144802077,
-67.447295493384 -53.6160731497428,
-67.436507581676 -53.622039170488,
-67.391124614029 -53.6542097535077,
-67.3539791665526 -53.6956196061525,
-67.3269104203995 -53.7442184039358,
-67.3253764063913 -53.7478803233193,
-67.3230523312484 -53.7555562481503,
-67.3222849491288 -53.7560467365923,
-67.3114169472498 -53.7652131285388,
-67.2829162778731 -53.776139751567,
-67.2697403032793 -53.7830068185208,
-67.2593818011438 -53.7887211099061,
-67.226811770619 -53.8077071515548,
-67.1944353065779 -53.830175720462,
-67.1804584411364 -53.8416076892276,
-67.1738263559239 -53.8479973600795,
-67.1558678465074 -53.8543228228446,
-67.1320104834376 -53.8608150115307,
-67.1114925580368 -53.8679280169637,
-67.0857009806772 -53.8751754838534,
-67.0833999850276 -53.8760564200139,
-67.0729090898164 -53.879286082971,
-67.056746585425 -53.8837666923825,
-67.0567057401561 -53.8837689432361,
-67.0194011197279 -53.8916302958941,
-67.0116110040697 -53.8939042978416,
-66.9807272722611 -53.9051712317834,
-66.9790697518249 -53.9059027262234,
-66.9771968031349 -53.9064903247746,
-66.9448814794437 -53.9191536483998,
-66.9382426406133 -53.9223030240757,
-66.9186437023921 -53.9304689803056,
-66.9107510622998 -53.9341669257053,
-66.9007751213243 -53.9379954193804,
-66.8668693867652 -53.9540203316301,
-66.8613831140118 -53.9571367570918,
-66.8389458766535 -53.9673212002601,
-66.8205655168754 -53.9776058767395,
-66.8043250495811 -53.9791846788518,
-66.7603658055432 -53.987479441013,
-66.718588649212 -54.0034759226439,
-66.7157426597099 -54.0048692327631,
-66.7029310434875 -54.0101332709114,
-66.6782486237332 -54.0218909877224,
-66.6424896394749 -54.0413920637931,
-66.6394751063195 -54.043480010479,
-66.6348811789417 -54.0449663444745,
-66.6054240615248 -54.0578524141835,
-66.5946400302369 -54.0628789354727,
-66.5804801040302 -54.0698938591984,
-66.5566996294795 -54.0833406514908,
-66.5357956742756 -54.0967186970062,
-66.5049181473348 -54.1200343286495,
-66.481225442974 -54.1445113288172,
-66.4773005001434 -54.1484635364063,
-66.4695235667624 -54.1561450690638,
-66.4613200880061 -54.1624299291242,
-66.4444558781123 -54.1714889340916,
-66.4346288594015 -54.1775308194424,
-66.4271291539996 -54.1832647125286,
-66.4246038145745 -54.1840579530422,
-66.4155438719534 -54.1859120702,
-66.3589671222333 -54.2047494462783,
-66.3471331174773 -54.212176985986,
-66.3110673393223 -54.2172586559968,
-66.2623790787948 -54.2348925351504,
-66.2471838079125 -54.2422558643229,
-66.2384127396227 -54.2461423666905,
-66.2037176695331 -54.2649205485414,
-66.1969369891405 -54.2701187863829,
-66.1943045351973 -54.2712922583402,
-66.1905761538209 -54.2729541637584,
-66.1625317348447 -54.2889374471336,
-66.1508720742776 -54.2922392126796,
-66.1461083663114 -54.2938468695361,
-66.1297898249448 -54.2981442025349,
-66.1102691207024 -54.3042755089518,
-66.1041385099629 -54.3061849898434,
-66.0980542875608 -54.3074591980937,
-66.0623553125365 -54.3205072996413,
-66.062083546903 -54.3196754161541,
-66.0335334603735 -54.32900236214,
-66.0131568029566 -54.3383963354836,
-65.9776465773706 -54.350932274664,
-65.9432072267554 -54.3663414255753,
-65.9300472155873 -54.3720866760116,
-65.927876349357 -54.3724751412392,
-65.9244896107667 -54.3733228398125,
-65.9113067638724 -54.3737322767455,
-65.8705295396427 -54.3783689338853,
-65.8557030280067 -54.3813033725149,
-65.8293073204585 -54.3837791476866,
-65.7727656332466 -54.3957944435512,
-65.7636027378695 -54.3988844740635,
-65.7368096255518 -54.4112949206306,
-65.7311675906606 -54.4115521473359,
-65.70899098124 -54.413555867705,
-65.6935570225157 -54.4156468088873,
-65.6669689015127 -54.4223712891531,
-65.6618366699422 -54.4220013293274,
-65.6350347492895 -54.4156864030588,
-65.6239284182466 -54.4145393945308,
-65.6187004778215 -54.412976217549,
-65.6046245131389 -54.4107252742171,
-65.5686252860504 -54.4076129345238,
-65.5477743128565 -54.4073228536189,
-65.5141170862172 -54.4094540076723,
-65.504296166168 -54.4072625808537,
-65.4783278439194 -54.404538955334,
-65.4508324477539 -54.3987700611421,
-65.442593481181 -54.3981909554522,
-65.4047404938423 -54.3991837034738,
-65.4029650528047 -54.3986529154655,
-65.3803209642119 -54.3948728866845,
-65.3802769615129 -54.3951364828294,
-65.3498213528165 -54.3903768498112,
-65.3360704680889 -54.3894026187624,
-65.3251730413604 -54.3880092885167,
-65.314225584634 -54.3865662055733,
-65.3029719988571 -54.3827389868204,
-65.2804349304039 -54.3771079320715,
-65.2239658772443 -54.3696858437649,
-65.2200369355716 -54.3696208923973,
-65.16946916635 -54.3739370920428,
-65.1208150793751 -54.3883769218231,
-65.0959385037371 -54.4017053476921,
-65.064407163937 -54.4070311548533,
-65.0532070134674 -54.410266225818,
-64.9906666263987 -54.4380837806776,
-64.9788567427651 -54.4454197648222,
-64.9431753681338 -54.4722803894332,
-64.9128427361938 -54.5050612541206,
-64.8888268964652 -54.5427161753421,
-64.8718943014661 -54.5840434166807,
-64.8692067220745 -54.5966544067344,
-64.8325144264495 -54.5723787003976,
-64.8283899958515 -54.5708630225219,
-64.8093090288535 -54.5584050382834,
-64.8024271762225 -54.5548339452027,
-64.7606983455612 -54.5377606215092,
-64.7395334632428 -54.5332986412766,
-64.7150875168553 -54.5108782197983,
-64.6670265031104 -54.4833475868934,
-64.6140831266897 -54.4670750430382,
-64.6059041829254 -54.4655258913129,
-64.5637024691654 -54.4611960395253,
-64.5213762735947 -54.4640640404485,
-64.4801444093276 -54.4740473079421,
-64.4692614128016 -54.4776840619445,
-64.4379786067107 -54.4648695845943,
-64.4362521509882 -54.4644907310872,
-64.4161256144091 -54.4502302150753,
-64.4074286438834 -54.4452182225486,
-64.4057923303181 -54.4442955121825,
-64.4012208857489 -54.441495581264,
-64.3562849209024 -54.4198116089673,
-64.3079378565313 -54.4074829043333,
-64.2581054030801 -54.4050005316198,
-64.244859427845 -54.4070043137968,
-64.2276977513203 -54.4009119960059,
-64.2271761539369 -54.4007829655588,
-64.2252423236218 -54.4002046841724,
-64.1656900926269 -54.3900164901403,
-64.1592130859189 -54.3897033506199,
-64.1099474758539 -54.3921938288892,
-64.0826493008731 -54.399110272609,
-64.0824575580958 -54.3983429674823,
-64.0743704967541 -54.4003638527179,
-64.0632652428593 -54.4040215440184,
-64.0621299000636 -54.4043092018766,
-64.0594522399826 -54.4052774169217,
-64.0395915201453 -54.411818859635,
-64.0353494389522 -54.413569906262,
-64.0352473596014 -54.4136120689773,
-64.03336236178 -54.4143911333491,
-63.9887546054834 -54.4383788367116,
-63.9555053583068 -54.4661762979441,
-63.9506706612602 -54.4653075671044,
-63.9268067542994 -54.4628325503552,
-63.8760329672376 -54.4627502318867,
-63.8652899406211 -54.4638292342814,
-63.8460821534014 -54.4672441867073,
-63.8419507804262 -54.4663801474123,
-63.8380329280115 -54.4660441252962,
-63.7826320023988 -54.4674576306023,
-63.7289036915089 -54.4810417818417,
-63.6794882136132 -54.5061290515282,
-63.671130081523 -54.5116150658247,
-63.6328786011009 -54.5425053296793,
-63.6014125399237 -54.5802845719888,
-63.5779489469152 -54.6234915616851,
-63.5633953503627 -54.6704551324913,
-63.5620454532394 -54.6770462001376,
-63.5569677187371 -54.728955870866,
-63.5627713071128 -54.7807894088967,
-63.5792036093077 -54.8302906891567,
-63.581194571149 -54.8346896041399,
-63.5995733185706 -54.8682084964548,
-63.62284750177 -54.8985335173979,
-63.6253725081898 -54.9013486047224,
-63.6496135062883 -54.9240358825427,
-63.6545058394163 -54.9299208383391,
-63.661543437785 -54.9371000509084,
-63.6845014615864 -54.9616567018886,
-63.7134348883229 -54.9846317523338,
-63.7246500004897 -54.9922576413633,
-63.7528957878506 -55.0088670087787,
-63.76010169324 -55.0124910838694,
-63.8284256149494 -55.0352437922029,
-63.8404997045528 -55.0374026770923,
-63.8625739236019 -55.039892339172,
-63.8728251223022 -55.043738083842,
-63.8902051577764 -55.0487731349843,
-63.9241926172309 -55.056102268548,
-63.9300556662957 -55.0569452281677,
-63.9876744756357 -55.0585162525837,
-63.9956393791206 -55.0578112926178,
-64.0007341881255 -55.0568392034498,
-64.0370199265281 -55.0850137942288,
-64.0392847754373 -55.0864407880974,
-64.0796219620997 -55.1070093789019,
-64.1230075340462 -55.1199649839592,
-64.1680183365351 -55.1248826271781,
-64.2131779032179 -55.1216009976217,
-64.2179929294021 -55.1208080276725,
-64.2760013016182 -55.1038514367139,
-64.3084764839196 -55.0849662428077,
-64.3151237134151 -55.0862385502117,
-64.323362679988 -55.0871154816849,
-64.3703863095291 -55.0876724915533,
-64.3741794637872 -55.0869957980143,
-64.3873069963576 -55.0920325225462,
-64.4016959245406 -55.0955574983958,
-64.4115351146852 -55.0977585663733,
-64.431829160705 -55.1018705688111,
-64.4464934006701 -55.1032004389656,
-64.4494262306996 -55.1043777175696,
-64.4539736452668 -55.1057783844325,
-64.4796491651953 -55.1218728740476,
-64.4884762144763 -55.1261758581491,
-64.5237569266623 -55.1401692175869,
-64.5607493651854 -55.1486605221291,
-64.5678063576831 -55.1497245628267,
-64.5891359433209 -55.1505021335596,
-64.5919445609354 -55.1513646257475,
-64.631578685339 -55.1568579428299,
-64.6564425617296 -55.1582919774971,
-64.7290340965432 -55.1518387216112,
-64.7386931922059 -55.149526699351,
-64.7748775841843 -55.137894680647,
-64.8088804703912 -55.1209118124683,
-64.8158915216776 -55.1167158485064,
-64.8572061849594 -55.0857809111008,
-64.8912879658004 -55.0470213449386,
-64.8913442269915 -55.0469218051757,
-64.8954304183371 -55.0446757321704,
-64.9303663605483 -55.0162510811395,
-64.932891366968 -55.0137869776282,
-64.9638510287686 -54.9771430896924,
-64.9872416895277 -54.9352604898315,
-64.9913609156907 -54.9227106339828,
-64.9918082714283 -54.9238121213607,
-65.0182209784763 -54.9642031866611,
-65.0308468906748 -54.9799513410257,
-65.0698981771818 -55.0189266427695,
-65.0794544976438 -55.0265577904997,
-65.0852042963219 -55.0368716921804,
-65.0903852680164 -55.0440357048177,
-65.1236381424198 -55.0814618760304,
-65.1334871636264 -55.0905288405258,
-65.1689453026485 -55.1177406252951,
-65.1885303402432 -55.1301577778132,
-65.2163312345775 -55.1454032049538,
-65.2380211189318 -55.1555651896608,
-65.2750169663308 -55.1694495184405,
-65.2976839375193 -55.1759654255611,
-65.301488008953 -55.1770264970096,
-65.3077520315016 -55.1787205131674,
-65.3691913406422 -55.1873604656983,
-65.3759204079423 -55.1874634373787,
-65.4309290513749 -55.1821971233291,
-65.4380240641854 -55.1807130989914,
-65.4382588035469 -55.1806638823263,
-65.4424336823213 -55.1797864648328,
-65.4856819114496 -55.1900880311795,
-65.5044758042371 -55.1906652735936,
-65.5055973600599 -55.1913254497934,
-65.554946914239 -55.2078681152564,
-65.5745930307621 -55.2122439716241,
-65.6213249632912 -55.2181075315613,
-65.6474628721995 -55.2189045499697,
-65.6609471934666 -55.2189518975259,
-65.6859642072281 -55.2183648709375,
-65.7124932765021 -55.2163260776848,
-65.7252492674558 -55.2146591686019,
-65.7542121030031 -55.2091205756056,
-65.7602240649596 -55.2075985309552,
-65.8152153763239 -55.1865209494677,
-65.847701376406 -55.1641940815293,
-65.8596488494142 -55.172119760466,
-65.8651038841966 -55.1749197100734,
-65.909525776943 -55.1925829879126,
-65.9385244318392 -55.1980682242435,
-65.942853709911 -55.2000661795817,
-65.963686971123 -55.2071091771372,
-65.9704836681419 -55.2101921052331,
-65.9850097158789 -55.2149031036171,
-66.0523258766661 -55.2269042091903,
-66.4077835155563 -55.0537716690276,
-66.399993575918 -55.047092767418,
-66.3992916082915 -55.0432087108368,
-66.3942185368365 -55.0392917385218,
-66.3880764961248 -55.0303386589448,
-66.3822475949335 -55.0250476747712,
-66.3799744730859 -55.0204618265835,
-66.3781896306253 -55.0124587267658,
-66.3784485559961 -55.0017276695069,
-66.3780364932545 -54.9999996814956,
-66.3773655051421 -54.9971507983375,
-66.3699186284186 -54.9932137597464,
-66.3628616359209 -54.9899677755438,
-66.3553776189844 -54.9876247737694,
-66.3462604887986 -54.9873278280859,
-66.3375015592447 -54.9886317839979,
-66.326827532455 -54.9871827876335,
-66.3090055108449 -54.9859006581974,
-66.2974246291877 -54.9887768244503,
-66.2869945660716 -54.9932637494168,
-66.2770534864225 -54.9940947396788,
-66.2754664904044 -54.9940838264409,
-66.2584765151761 -54.9914317336053,
-66.2302015478543 -54.9950748188524,
-66.2254106364056 -54.9961777599626,
-66.2159196398108 -54.995181662972,
-66.2091675138952 -54.9953538104993,
-66.1973416124446 -54.9925117921199,
-66.1779706151292 -54.9900547294072,
-66.1581576316778 -54.9891927596312,
-66.1439206087258 -54.9876937735963,
-66.1167146106607 -54.9821887491434,
-66.1060185813752 -54.9816318219694,
-66.0930325323253 -54.9783097971413,
-66.0621336353626 -54.977096667532,
-66.0476075876256 -54.9723856691481,
-66.0444944984977 -54.9705277784015,
-66.0229184990617 -54.9632336870089,
-66.0116424839865 -54.9564937064709,
-66.0017925826801 -54.9545668158974,
-65.9792636111454 -54.9525066782093,
-65.973808576363 -54.9497067286019,
-65.9692535316694 -54.9437216977003,
-65.9746325258262 -54.937156681009,
-65.9721145602052 -54.929591694888,
-65.9670256469531 -54.9277118016455,
-65.9588166037746 -54.9244267410104,
-65.9573595104918 -54.9207577808283,
-65.9602884827346 -54.9162217462911,
-65.9699855987101 -54.9106137501578,
-65.9852445935877 -54.9043766586641,
-65.9846116257881 -54.8995746579575,
-65.9827114902495 -54.8970417306393,
-65.9712985316404 -54.8950958299094,
-65.962226638586 -54.8940847712218,
-65.9551235288571 -54.8935547751026,
-65.941139622617 -54.8972856943129,
-65.9229044821455 -54.8980027996565,
-65.9144745339089 -54.9011077918659,
-65.9112245012471 -54.903583688715,
-65.9044875130486 -54.903735769966,
-65.8986434741402 -54.9009328280192,
-65.8963925308083 -54.897479668316,
-65.8986124946261 -54.890655726254,
-65.8808594728429 -54.889083691933,
-65.8605955262373 -54.8911397811619,
-65.8419115348512 -54.8932076637286,
-65.8391265469409 -54.8936308157281,
-65.8256685883608 -54.8937036879942,
-65.8164595757524 -54.8963357145536,
-65.8069455205421 -54.8966828259276,
-65.7967074952095 -54.895187712332,
-65.758026579507 -54.8922076942988,
-65.7509155488796 -54.8918917384589,
-65.7290575654572 -54.9039577311438,
-65.7222214780175 -54.9066128163188,
-65.7093736046413 -54.9110187721007,
-65.699638644373 -54.9166067019578,
-65.6921924717294 -54.9245036617358,
-65.690338629442 -54.9311066987398,
-65.6965635755579 -54.9535677265675,
-65.702682557654 -54.9591257330303,
-65.7029726385589 -54.9616428185515,
-65.6988675008997 -54.9652447151264,
-65.6928555389432 -54.9667667597769,
-65.6800995479896 -54.9684336688598,
-65.6550825342281 -54.9690206954481,
-65.6289446253198 -54.9682236770397,
-65.6092985087967 -54.9638478206721,
-65.6058346118756 -54.9612886663789,
-65.6095965106 -54.956771818018,
-65.6170954892336 -54.9481927808698,
-65.6163935216072 -54.9461287707424,
-65.6121905168466 -54.9424166856685,
-65.601463508047 -54.9429588271654,
-65.5880275519627 -54.9420928089301,
-65.5786055551948 -54.9399068169659,
-65.5724415119873 -54.9359396789605,
-65.5642166270118 -54.9335436951762,
-65.5538715815395 -54.934543664606,
-65.5293886123564 -54.941509830801,
-65.5186535066383 -54.9422718212361,
-65.4940645734354 -54.9337007049864,
-65.4765625561245 -54.9265937228182,
-65.4749456367121 -54.9185788296627,
-65.476486515499 -54.9108316628763,
-65.4759366291236 -54.905570778117,
-65.4786915176196 -54.8971596640169,
-65.4785385562686 -54.8919028277168,
-65.4727635171871 -54.8883936936643,
-65.4618835470366 -54.8838956794398,
-65.4440074872968 -54.8852307908859,
-65.4272994960549 -54.887038691962,
-65.4183884852498 -54.8912468013016,
-65.410743586064 -54.8938747794017,
-65.3990174879344 -54.8989527794158,
-65.395507473782 -54.9062077943758,
-65.3985366013859 -54.9174457891382,
-65.3987425447467 -54.9297867250109,
-65.3958735953124 -54.9317966970085,
-65.3929595847667 -54.934722676912,
-65.3868406026706 -54.9360086787874,
-65.3797455898601 -54.9374927031251,
-65.3730165225601 -54.9373897314447,
-65.3667525000116 -54.9356957152869,
-65.3440855288231 -54.9291798081663,
-65.3223956444687 -54.9190178234592,
-65.302810606874 -54.9066006709411,
-65.2929615856674 -54.8975337064457,
-65.2877806139729 -54.8903696938084,
-65.286880623884 -54.8846437642975,
-65.2917405351596 -54.8744427031579,
-65.287979516535 -54.8627317427454,
-65.2796935526311 -54.8543737866752,
-65.2586285391579 -54.8407817008806,
-65.2410885015342 -54.835700708527,
-65.2258985064835 -54.8235708205943,
-65.2132725942851 -54.8078226662297,
-65.2169955925969 -54.804687750626,
-65.2491685220773 -54.7935638168019,
-65.2445604953738 -54.7909777314538,
-65.2294315792515 -54.7857017089774,
-65.2153624793476 -54.7827267955232,
-65.2056805010892 -54.7791366922861,
-65.1949996095208 -54.7718778048868,
-65.1865846229814 -54.7591707474839,
-65.1883775623604 -54.755084796001,
-65.2071226326749 -54.7437477019975,
-65.204635470548 -54.7384487969254,
-65.1951295122561 -54.7316667476154,
-65.1889496272516 -54.7215077552478,
-65.186828586655 -54.7168997285443,
-65.189262590752 -54.7080307865112,
-65.18322757018 -54.695361749421,
-65.1701814983215 -54.6812018232144,
-65.1564336348565 -54.6729697214202,
-65.1399155691584 -54.6724587354574,
-65.1325605748574 -54.6700437415168,
-65.1150205372337 -54.6665418242829,
-65.1100536058184 -54.6637117752612,
-65.1107715912619 -54.6577837748287,
-65.1225814748955 -54.6504477906841,
-65.1337816253651 -54.6472127197195,
-65.152503637064 -54.6505086935925,
-65.1600265544131 -54.649722764442,
-65.1740875573985 -54.6517908230287,
-65.1994015168435 -54.6419337049036,
-65.2063525453214 -54.6370238039575,
-65.2129436129677 -54.6389617837889,
-65.2168046109333 -54.6403958184561,
-65.2408526347791 -54.6498336570209,
-65.2401885114454 -54.6448977051198,
-65.2295456401898 -54.6298677122187,
-65.218330528023 -54.6260257244095,
-65.2153395967519 -54.6230046937241,
-65.2159046208444 -54.6195867380142,
-65.2198335625171 -54.6196516893819,
-65.2423706309703 -54.6252827441308,
-65.2554545471216 -54.6309817425868,
-65.2929835881632 -54.6359287837458,
-65.3113635930671 -54.6382788263188,
-65.3321534873327 -54.6397517613986,
-65.3391574978204 -54.6414607392536,
-65.3618015864133 -54.6452407680346,
-65.3741375937268 -54.6506847135591,
-65.394172538356 -54.6514477601139,
-65.4152606104448 -54.6551968093808,
-65.4216075383975 -54.6541477303804,
-65.42506457054 -54.6475756728904,
-65.4333035371128 -54.6481547785803,
-65.4453045784301 -54.6524466734239,
-65.4782185519695 -54.6558987770073,
-65.4871295627745 -54.658996728418,
-65.498046497118 -54.6614418217729,
-65.5047375441053 -54.6615366965349,
-65.5236964786791 -54.6602096820073,
-65.5442966234207 -54.657298663801,
-65.5651475966147 -54.6575887447058,
-65.5792235612973 -54.6598396880377,
-65.5865635939011 -54.66313971037,
-65.5940625725347 -54.6627846780975,
-65.6093525469264 -54.6643637532172,
-65.6194305701095 -54.6681557513559,
-65.6299665972454 -54.670352656558,
-65.6609874760449 -54.6725888142127,
-65.6916806056667 -54.673217733553,
-65.7098764936857 -54.6711656927834,
-65.7183226357591 -54.6667027065323,
-65.7271195856259 -54.6633836740436,
-65.7425535443502 -54.6612927328613,
-65.7662204849685 -54.6602137304665,
-65.7823106461279 -54.6615527143518,
-65.7917405637943 -54.662124779243,
-65.801315521913 -54.6588136676529,
-65.8157275087117 -54.6523586634407,
-65.8308104836227 -54.6488798048224,
-65.8422774803616 -54.647414790641,
-65.8478925172936 -54.6445116933332,
-65.8491434911956 -54.6426967514585,
-65.84133964598 -54.6407777817835,
-65.8406375023335 -54.6384847696796,
-65.8434906099708 -54.6357767024947,
-65.852653505348 -54.6326866719825,
-65.8917385628936 -54.6290207041398,
-65.9190675989153 -54.6236117865886,
-65.9517515143585 -54.6225966794417,
-65.9675595155116 -54.6202547337872,
-65.9885785877735 -54.6149936730079,
-66.0000225258968 -54.6137426991058,
-66.0107495346964 -54.6104277150764,
-66.0187455937155 -54.6063958017233,
-66.0207515172539 -54.6052736744367,
-66.0442735934398 -54.59500466959,
-66.0797495375919 -54.5791317170692,
-66.0927505483389 -54.5778886640657,
-66.1111675174358 -54.5666427484047,
-66.1397176039653 -54.5573158024188,
-66.1492996028827 -54.5521506725213,
-66.1670765633813 -54.5484276742094,
-66.1848985849914 -54.5428767085453,
-66.2047045276441 -54.5366558108886,
-66.2149656115923 -54.5344617220059,
-66.2308125131581 -54.5291137073632,
-66.2489775976829 -54.5249288326592,
-66.2505496320038 -54.5249408020169,
-66.2612305235722 -54.5216027593718,
-66.2703786332722 -54.5168797916302,
-66.2923585985313 -54.5012967439943,
-66.2960895177417 -54.4996337073506,
-66.3054506116011 -54.4954608020043,
-66.3268585119691 -54.4862637587537,
-66.3396915996681 -54.4747087520316,
-66.3523636290977 -54.4690937150996,
-66.3713986042971 -54.4598697407941,
-66.4239345796242 -54.4579657328163,
-66.4382395462832 -54.4491576936917,
-66.4552995774582 -54.4392206625018,
-66.4656675055261 -54.4308357753767,
-66.4872896221934 -54.4264108094384,
-66.5022655769648 -54.4217066758331,
-66.5156094746066 -54.4199637261247,
-66.541152612048 -54.4146387700975,
-66.5494684993463 -54.4098927437403,
-66.5556026191595 -54.4046477007779,
-66.5655665814042 -54.3904986878092,
-66.575393600115 -54.3844568024585,
-66.5962986114387 -54.3747517655845,
-66.6098174729272 -54.3622587484608,
-66.6299816162118 -54.3495747496734,
-66.6351395292907 -54.3450316743376,
-66.6407246428284 -54.3384356781322,
-66.6538395384938 -54.3254816647162,
-66.6637725212244 -54.3154796821587,
-66.6705556266542 -54.3072887690367,
-66.691459581858 -54.2939107235213,
-66.7056195080647 -54.2868957997956,
-66.7350766254816 -54.2740097300867,
-66.7471776461399 -54.2738337101202,
-66.7621845804254 -54.2608758242649,
-66.7979435646836 -54.2413747481942,
-66.8183215722275 -54.2330018304268,
-66.8285145364487 -54.228011664376,
-66.8624496018139 -54.2247126981635,
-66.8706586449924 -54.2226826598896,
-66.8866655487078 -54.2199937788811,
-66.9128185953332 -54.2145957745679,
-66.919464581209 -54.2127876974718,
-66.9233775050647 -54.2112007014536,
-66.9394916049397 -54.1975367995127,
-66.9610214871445 -54.1854898169841,
-66.9731295486014 -54.1811787359641,
-66.9903485258061 -54.1713976584646,
-67.008697551196 -54.164355803684,
-67.0247114957099 -54.1568527765912,
-67.0352404820472 -54.1529926587254,
-67.0520326108332 -54.1450266991206,
-67.0672305267824 -54.1402586702676,
-67.0816645160769 -54.1338886836992,
-67.0894546317351 -54.1316146817518,
-67.1011126101376 -54.1318626938846,
-67.1213755006234 -54.1241227439168,
-67.1353835215989 -54.1216317093506,
-67.1649626208527 -54.1125256684227,
-67.175086585247 -54.1086497087599,
-67.1820835549361 -54.1086578056784,
-67.1976546332143 -54.1020427993166,
-67.2303165461616 -54.0931546711073,
-67.2614215625051 -54.0821986603312,
-67.2723004765359 -54.0792316677756,
-67.2812345459565 -54.0774037004233,
-67.3235854779609 -54.0550077999832,
-67.3294145551721 -54.0499797896396,
-67.3387376287188 -54.0351217682457,
-67.3527144941603 -54.0236897994802,
-67.3852845246851 -54.0047037578316,
-67.3984604992789 -53.9978366908778,
-67.4073715100839 -53.9955447348937,
-67.413574629724 -53.9955368139952,
-67.4337084975743 -53.9843178293892,
-67.439903520296 -53.9824828212382,
-67.4488066102025 -53.9756168104042,
-67.4569244750384 -53.9666938302415,
-67.4716186218434 -53.9573017568679,
-67.4847565761244 -53.9467697781912,
-67.5037075897997 -53.941024662504,
-67.5149154851479 -53.935977818024,
-67.5307696035322 -53.9320636620285,
-67.5365675252094 -53.9293098296523,
-67.5384975841423 -53.9283947018464,
-67.5477525379619 -53.9199177562788,
-67.5611955348449 -53.8963467465422,
-67.5746534934251 -53.8794057048646,
-67.5750125741568 -53.873462742735,
-67.5726625315838 -53.865466683716,
-67.5749514952284 -53.85997767708,
-67.572624511271 -53.857238806401,
-67.5606236459737 -53.8508647713734,
-67.5559615811405 -53.8444747185289,
-67.5574955951487 -53.8408127991454,
-67.5682835068567 -53.8348467784002,
-67.587539563134 -53.8261188283604,
-67.6010285012283 -53.8210566701432,
-67.613342506046 -53.814170769053,
-67.6248936403288 -53.8102527406183,
-67.634529501356 -53.8077127725014,
-67.644523563015 -53.8022007072498,
-67.6576155760848 -53.7987327618695,
-67.6683656435 -53.7909317329733,
-67.6756826174882 -53.7888487126895,
-67.6807095717121 -53.7908937126605,
-67.682281606033 -53.7950016666392,
-67.6776966379451 -53.8025587318617,
-67.6811985551791 -53.806205689548,
-67.692817633169 -53.8130268152906,
-67.7105945936676 -53.8161698278128,
-67.7186966167065 -53.8163717227144,
-67.7399135354108 -53.8158417265952,
-67.7398985737137 -53.813781764927,
-67.7267305200184 -53.8072017865386,
-67.7189946185098 -53.8049397539488,
-67.7020266457773 -53.8056827342275,
-67.6958316230557 -53.8029597053455,
-67.6930925763567 -53.7974817879674,
-67.6922605299749 -53.7887997791388,
-67.6975634835063 -53.7752957033275,
-67.7013855810593 -53.7711676830726,
-67.7167285374609 -53.760829678399,
-67.720565596711 -53.7580756700029,
-67.7362975572386 -53.7504767120283,
-67.7554775728904 -53.7398906952219,
-67.7819675217317 -53.7301907629269,
-67.7919314839765 -53.7253496857877,
-67.8080065074188 -53.7152246652736,
-67.8248364804976 -53.7044107026105,
-67.8416446271005 -53.692447681606,
-67.8599925963705 -53.6811637456324,
-67.8722455222599 -53.6765367087725,
-67.8763885042118 -53.6685147748183,
-67.8935775580223 -53.6586037945835,
-67.9141924884411 -53.6461567186711,
-67.9163974905617 -53.6379166959784,
-67.9397125672669 -53.6284218269444,
-67.9496075296848 -53.6208267414091,
-67.9613496456313 -53.6086466877859,
-67.9743115799458 -53.6012607139708,
-67.9841535603537 -53.591144670475,
-67.9905165061235 -53.5796776737361,
-68.0011745150962 -53.5729868027688,
-68.0106355882966 -53.5637897595182,
-68.0219344859674 -53.5495456957675,
-68.0247805528061 -53.534438782141,
-68.0284495129882 -53.5234447510522,
-68.0444335341079 -53.4904218211535,
-68.060798638455 -53.4589997928503,
-68.0632785837633 -53.4464076764855,
-68.0627515799836 -53.4370347892883,
-68.0641025332266 -53.4253657216279,
-68.067207525436 -53.404083675536,
-68.0780184957596 -53.3868638182314,
-68.0907744867133 -53.3721467888307,
-68.1017076148937 -53.3636166852332,
-68.1088336072183 -53.3557927737414,
-68.1166305876552 -53.3424796795937,
-68.1271055358628 -53.3300586546363,
-68.131988505754 -53.3254546763921,
-68.1441196258265 -53.3210256619945,
-68.1581874935906 -53.3181838196351,
-68.1722104762633 -53.3130526615911,
-68.1892015076114 -53.3035548002176,
-68.19110164315 -53.3033106605241,
-68.2021565771472 -53.3030017454828,
-68.214370602624 -53.3038256949461,
-68.2358165233047 -53.3082348190875,
-68.2534405224525 -53.3122137504306,
-68.2913355090044 -53.3187717263232,
-68.3389515502474 -53.3153986557048,
-68.3560485456153 -53.3122787017983,
-68.3735195834121 -53.3091546994325,
-68.3899154912535 -53.3087806570036,
-68.4282605608598 -53.3013417011786,
-68.4438096366422 -53.2979927452956,
-68.4573594776449 -53.2905467486719,
-68.4641645855705 -53.2881967060989,
-68.4777906432187 -53.2844047079602,
-68.4871594819566 -53.2779116834352,
-68.4968794805278 -53.2704966663257,
-68.5070036209421 -53.2642206744194,
-68.5186996196574 -53.2597576881683,
-68.5202176158486 -53.2592887709775,
-68.5246045614742 -53.2521557378543,
-68.5386965439737 -53.2378307049191,
-68.5426406233635 -53.2284127566105,
-68.5486224859057 -53.210056690422,
-68.5477754778268 -53.1924557498899,
-68.5476374781731 -53.187423691087,
-68.5362165986654 -53.1724466801958,
-68.5339586145349 -53.1589778083777,
-68.5268174844932 -53.1473847813429,
-68.5097356268424 -53.1333767603673,
-68.4866484959938 -53.1214827391897,
-68.4681245067573 -53.1095427768008,
-68.4665605693548 -53.1077308272655,
-68.461112575371 -53.1025197561567,
-68.4518585016512 -53.0964358020339,
-68.4502945642487 -53.0946198040393,
-68.447585616964 -53.092586773426,
-68.4397425192958 -53.0819127466363,
-68.4305115041917 -53.0767367035009,
-68.4285816212788 -53.0753817017986,
-68.4228204877746 -53.0724638188136,
-68.388435515375 -53.0451046833776,
-68.3744655147122 -53.0308227753342,
-68.3617855643841 -53.0231548175327,
-68.3530046323343 -53.020030815167,
-68.3314585562926 -53.022506712016,
-68.320442522708 -53.0209957566234,
-68.3016585519809 -53.010635749454,
-68.2902374964533 -53.0077557107618,
-68.2826695179928 -53.0082737375233,
-68.2747875199121 -53.0117687899785,
-68.2707295556039 -53.0170627664915,
-68.2708126370281 -53.021407819365,
-68.2724605359547 -53.0277976961896,
-68.2718965679819 -53.0374068021819,
-68.2626416141623 -53.0486866896963,
-68.2486346493066 -53.0691527072234,
-68.2456585037127 -53.0719227334366,
-68.2401425660219 -53.0808826777923,
-68.2369465714898 -53.0923458020919,
-68.2309566120292 -53.0965077942002,
-68.2242356416476 -53.1022757924831,
-68.2113036307274 -53.1213567088937,
-68.2099766161998 -53.1314276912781,
-68.2113185924245 -53.1421657893356,
-68.2095715942568 -53.1504137329267,
-68.2010955287891 -53.1440736697527,
-68.1948776234718 -53.1363448090428,
-68.1955035504727 -53.1292497962323,
-68.2006755451489 -53.1214367979784,
-68.2002256381145 -53.1175497490578,
-68.2054215715062 -53.1111107626626,
-68.2188265480764 -53.0975148044287,
-68.2347646279848 -53.077724703573,
-68.2394715779095 -53.065795830442,
-68.24031048907 -53.0506936693546,
-68.2389834745424 -53.040870699103,
-68.2414855983664 -53.0330737186661,
-68.2480395257998 -53.0193027965854,
-68.2518535264343 -53.0014307853049,
-68.2609405572059 -52.9823757438294,
-68.2726976348496 -52.9644428296404,
-68.2916416077262 -52.9471317939931,
-68.2994535498603 -52.9408947024995,
-68.3116225142256 -52.9259257885267,
-68.327224572018 -52.9132116903251,
-68.341056573027 -52.9060057849357,
-68.3607405338429 -52.8902776968474,
-68.3760296281347 -52.8816798255628,
-68.3871076207476 -52.8703728309735,
-68.4051975447467 -52.8523677485983,
-68.4267195060529 -52.8368417314315,
-68.4384075838698 -52.8254277167026,
-68.4484715254555 -52.8155936571931,
-68.459556558867 -52.8063357110341,
-68.4683765673493 -52.7968707653944,
-68.4780275660936 -52.7908327524829,
-68.4894106013084 -52.7785947882907,
-68.5081785542186 -52.7607958252962,
-68.5085295380318 -52.759876825051,
-68.5114446046973 -52.7559587966163,
-68.5202714779584 -52.7476348123996,
-68.5332034888786 -52.7381207571893,
-68.5489505871233 -52.7214888065729,
-68.5666045096653 -52.705978807223,
-68.5894855211331 -52.6897196668957,
-68.5999525484422 -52.6735957099026,
-68.6027834775637 -52.6671556673876,
-68.6047515568093 -52.6653746973664,
-68.4398576363539 -52.4001467556956,
-68.4306796032597 -52.3985097700069,
-68.4231265864964 -52.3949207228896,
-68.4184345982688 -52.3858146819617,
-68.4035105693875 -52.3701707314173,
-68.374282629967 -52.3484727501445,
-68.3673705019018 -52.3396147213494,
-68.3645246110831 -52.3291167145262,
-68.3653485605464 -52.3156128147348,
-68.3682025482835 -52.3096386970712,
-68.3865814970676 -52.2978017063627,
-68.3949206190014 -52.2876627802712,
-68.3963696153658 -52.2855876808859,
-68.397430487704 -52.2832907963428,
-68.414611620616 -52.2687188073946,
-68.4160614970802 -52.2668727099857,
-68.4280855970131 -52.2553217517228,
-68.431976518373 -52.2465897532238,
-68.4410855516404 -52.2382657690071,
-68.4421694825942 -52.2368847163498,
-68.4450755722414 -52.2338826958208,
-68.4575045180973 -52.2241517840117,
-68.472389646566 -52.2089047584918,
-68.4871906374907 -52.1906858118573,
-68.5303875214542 -52.163932713166,
-68.5376585542312 -52.1574516579988,
-68.5491714921813 -52.1429176893633,
-68.5568005495701 -52.1364287132976,
-68.5706255097805 -52.1255267406512,
-68.6003345117695 -52.0979767995715,
-68.6289446211076 -52.0724906925993,
-68.6465605233368 -52.0526157501197,
-68.6637726357629 -52.0320546818106,
-68.6832355155009 -52.0130658238425,
-68.7158886274499 -51.977439734659,
-68.7574006482939 -51.9309428283632,
-68.7689366448596 -51.9092907883016,
-68.7785496232911 -51.8972737291674,
-68.7854914987307 -51.8829997420225,
-68.7999955439718 -51.8626787649477,
-68.8037495217978 -51.8527906673086,
-68.8091355567533 -51.8481486687515,
-68.8130565775275 -51.8437497537683,
-68.8144224924677 -51.8402978262048,
-68.8310085018728 -51.8165168246482,
-68.8463364965773 -51.7888566950695,
-68.8644485990922 -51.7677916815963,
-68.9029925712607 -51.7196767997683,
-68.9243015484075 -51.6969566705499,
-68.9369205958272 -51.6789316979184,
-68.9440006469405 -51.6602976962028,
-68.9571606037174 -51.6370007495541,
-68.972892564245 -51.6246446759644,
-68.9746855036239 -51.6234776635864,
-68.9822314795886 -51.6185647703008,
-68.9974746326692 -51.6135367599572,
-69.0044096433301 -51.6125216528103,
-69.0137094822412 -51.6158178027034,
-69.0260845659873 -51.6229587567251,
-69.037094614893 -51.6328618160614,
-69.0494385431051 -51.6388588163207,
-69.0564346326944 -51.6392098001339,
-69.0638355682066 -51.6407017453702,
-69.0692295240606 -51.6474876671194,
-69.0840755760968 -51.6513787644993,
-69.091697592687 -51.6585846698886,
-69.1028896462381 -51.6629908016905,
-69.1341015067013 -51.671657672802,
-69.1479416046288 -51.6776198211079,
-69.1612705405735 -51.6893077229048,
-69.1653825430113 -51.6910747873487,
-69.1779785318154 -51.6933898019483,
-69.2030025863756 -51.6936717859347,
-69.222373583691 -51.6995357150993,
-69.2251504746828 -51.6955986765082,
-69.2219775387663 -51.6899297774665,
-69.2159726176085 -51.6868247852571,
-69.2055205519966 -51.6831056593845,
-69.1899874940312 -51.6808397543555,
-69.1843794978979 -51.6786426731334,
-69.1698604909596 -51.6740687943034,
-69.1586376339143 -51.6692127554671,
-69.1529155768427 -51.6638107026946,
-69.1496886027965 -51.6565396699176,
-69.1527555746931 -51.6503106753424,
-69.1687925778227 -51.6376986687214,
-69.1788866188227 -51.6327287449667,
-69.1978145738824 -51.6283037790284,
-69.1943124806285 -51.6235537042119,
-69.1889345425915 -51.6174657016299,
-69.1766205377737 -51.6032446964949,
-69.1692736403912 -51.603133803916,
-69.158996538626 -51.6032976785048,
-69.1398695049842 -51.61183975146,
-69.1314395567476 -51.6122018245312,
-69.1140744829707 -51.6092677477092,
-69.0973735325274 -51.6044917979577,
-69.0880126146879 -51.5996017872678,
-69.0705795972038 -51.5849917780068,
-69.0536575656826 -51.5738027167951,
-69.0373075990525 -51.5680996698799,
-69.0049896291198 -51.5669747262738,
-68.9907915065804 -51.5701557591088,
-68.9839705568578 -51.5743747816863,
-68.9813534919956 -51.5833357821618,
-68.9784926394798 -51.585437812602,
-68.973670572497 -51.5839046786936,
-68.9717866307953 -51.5825577739098,
-68.962020514993 -51.5760617570454,
-68.9518125890746 -51.5672797688758,
-68.9409334990239 -51.549587826021,
-68.9411625010004 -51.5454636782055,
-68.9476014873956 -51.5407947485935,
-68.950401613023 -51.5368647508011,
-68.954933599101 -51.5196376766778,
-68.9650195431825 -51.5041656976408,
-68.9722286169313 -51.4903298241925,
-68.986892488302 -51.4594538098255,
-69.0124204880263 -51.4263576556207,
-69.0149535913645 -51.4155656954535,
-69.0125356050844 -51.3988957245243,
-69.019256575466 -51.3928487345945,
-69.0228195716283 -51.3596117644165,
-69.0308765335558 -51.3503378004405,
-69.034576649272 -51.341586791785,
-69.0419235466545 -51.3327828011197,
-69.0473025408114 -51.3201137640294,
-69.0455096014324 -51.3109897690649,
-69.0469974982094 -51.3018147283101,
-69.0548405958776 -51.2868197633823,
-69.0626446171132 -51.2610706825801,
-69.0813294885991 -51.2246287408517,
-69.0869594872282 -51.2096666916577,
-69.0929035054776 -51.203166802354,
-69.0951995099209 -51.1964947655231,
-69.1017835367685 -51.1876986957562,
-69.1132885538201 -51.1744727314919,
-69.1191105902327 -51.1553877666221,
-69.1179585395519 -51.1441916646117,
-69.1266095688663 -51.132613775294,
-69.1310655143188 -51.1160657862016,
-69.1328964740105 -51.0878907982207,
-69.1344905108273 -51.0821456825335,
-69.139770581763 -51.0779417976731,
-69.144554628433 -51.0700837383078,
-69.1429744971936 -51.0572927193808,
-69.1469264974818 -51.0469316560916,
-69.1426085516832 -51.0383066777322,
-69.1431045759488 -51.0323487539054,
-69.161872528859 -50.9926867029096,
-69.1657565854402 -50.9901046660207,
-69.1889415833901 -50.9810338290861,
-69.1968235814709 -50.9788437886627,
-69.2073286290927 -50.9788967706726,
-69.2158585566702 -50.9748646812995,
-69.2179945589639 -50.9739147015402,
-69.2182545404545 -50.9713937435797,
-69.2161025203438 -50.962733737247,
-69.2095184934962 -50.9518586956555,
-69.202064575974 -50.9464916708564,
-69.1963886361336 -50.9401737861981,
-69.1821896334944 -50.9287377689734,
-69.1733935637275 -50.9256787179752,
-69.1664194766341 -50.923045811316,
-69.1629635006114 -50.9178387886665,
-69.1573486396994 -50.9128947398469,
-69.1497345440077 -50.9123307718741,
-69.1490785175925 -50.9141696524644,
-69.1543955527212 -50.9207226997979,
-69.1614764839343 -50.9260978215155,
-69.1593556193577 -50.9275058052277,
-69.1535566415607 -50.9271426760368,
-69.1398776019026 -50.9193537925183,
-69.1326905306497 -50.9109997088873,
-69.127967562908 -50.9010088155877,
-69.125549576628 -50.8847957924916,
-69.122184602928 -50.8626558250829,
-69.1243206052217 -50.8427127628762,
-69.128288623327 -50.8234257270848,
-69.1298365429125 -50.7975426950881,
-69.1370464967611 -50.7784346716026,
-69.1384585289325 -50.7681156770854,
-69.137977642384 -50.7657848206888,
-69.1358104845562 -50.7553447244346,
-69.139160496559 -50.7486536774473,
-69.142425490918 -50.7399067172511,
-69.1343305086777 -50.725848706605,
-69.1222764853505 -50.7116236530108,
-69.1202846434094 -50.706622749742,
-69.1206815684339 -50.6979176822978,
-69.117668634667 -50.6849247684692,
-69.1140744829707 -50.6753697006067,
-69.0979844978311 -50.6584628068026,
-69.0929336048919 -50.6482467839658,
-69.0904085984722 -50.6286047159019,
-69.0865095801938 -50.6202008186204,
-69.0872645298302 -50.611491702717,
-69.0851746447677 -50.6035197584333,
-69.0842896163761 -50.5891148124333,
-69.0769805632863 -50.5757297261193,
-69.0778574947595 -50.5702247016664,
-69.0772625472727 -50.5638277840432,
-69.0641865520199 -50.5496138197068,
-69.0393825224179 -50.5179597970877,
-69.0080416393192 -50.4827427783064,
-68.9966966244172 -50.4758186808834,
-68.9917756342132 -50.4683376562864,
-68.9866025834172 -50.4636116962053,
-68.9748685643891 -50.4555476934792,
-68.9714734912749 -50.4505658003668,
-68.9672924890102 -50.4327777506103,
-68.9605945772442 -50.4253277055274,
-68.9411165597891 -50.409820698517,
-68.9287036317502 -50.4022217405424,
-68.9205326088844 -50.3929556974649,
-68.9162745098743 -50.3831786684246,
-68.9092715555064 -50.3766437511476,
-68.9016416180177 -50.3728637223666,
-68.8768235068183 -50.3677177786454,
-68.8710174882227 -50.3650517802325,
-68.8715974740124 -50.3606988064605,
-68.868965623473 -50.3566167274169,
-68.86808763588 -50.3515968139918,
-68.8733295104829 -50.347862726422,
-68.8749385089969 -50.3423497810707,
-68.8667065832227 -50.3417777161795,
-68.8630675464349 -50.3395387422053,
-68.8547666208338 -50.336906715646,
-68.8385696155546 -50.3327786953912,
-68.8279645885918 -50.3246877616102,
-68.8063046276318 -50.3167416922616,
-68.7957765213943 -50.3109318012267,
-68.7852404942584 -50.3046647863387,
-68.7625275818586 -50.2967227654494,
-68.7467495040998 -50.2939486907771,
-68.7319715717907 -50.288875795342,
-68.7271655226249 -50.2829896876616,
-68.7252954865006 -50.2798077747268,
-68.7070846367845 -50.2791218249173,
-68.692687611683 -50.274265786081,
-68.6653135145498 -50.2643048161756,
-68.6585385060385 -50.2643847292404,
-68.6410296239489 -50.2629927633452,
-68.6337504942534 -50.2573587162569,
-68.606819615396 -50.2496647075004,
-68.5988765383868 -50.2458686609024,
-68.5792004984694 -50.242889698989,
-68.5720065624378 -50.2402228204763,
-68.5647816468921 -50.236186682644,
-68.5507965085122 -50.2326817730707,
-68.5295185108795 -50.2221636999713,
-68.5094756453518 -50.2180326873771,
-68.498718537138 -50.2151716588413,
-68.4787216128216 -50.2128677334995,
-68.4687115333456 -50.2109107435118,
-68.4633026157944 -50.2082216864833,
-68.4618685811272 -50.2075498182711,
-68.4346235066295 -50.1995887872253,
-68.4213945500258 -50.1969757708224,
-68.4099196323885 -50.1929737808636,
-68.3962555544275 -50.1866986690572,
-68.3801345897739 -50.181594794108,
-68.3635866006815 -50.1730578257318,
-68.3555986385809 -50.1653557200568,
-68.3513945777006 -50.1512107555474,
-68.3523785293134 -50.1473157857282,
-68.3572614992046 -50.1424676677904,
-68.3639525461919 -50.139430795308,
-68.3841325312735 -50.1353497723843,
-68.3929446188573 -50.1320647117491,
-68.408355518966 -50.1216196869359,
-68.4263305019269 -50.1145787122552,
-68.4472656126649 -50.1132277590121,
-68.4553375362895 -50.109027746591,
-68.470344646595 -50.0972057175797,
-68.487525603487 -50.0876508257371,
-68.4944995145605 -50.0820847223559,
-68.4971774823311 -50.0751956529062,
-68.4953155431252 -50.0715557360186,
-68.4952465432984 -50.0688098245409,
-68.5022206303918 -50.0634767715953,
-68.5096205097843 -50.0611077188659,
-68.5150605828695 -50.0512157487875,
-68.5173495465141 -50.0431857179149,
-68.5131145061197 -50.0292776762803,
-68.5129696416872 -50.0233306656915,
-68.5289225072728 -50.0082897595525,
-68.5373996288604 -49.9999997471893,
-68.5483095224052 -49.9893227280602,
-68.5631566305612 -49.973830682747,
-68.5697936394187 -49.9700967711972,
-68.5750805751331 -49.9691237328223,
-68.5839465248267 -49.9692497631183,
-68.5905984953814 -49.9524768205087,
-68.5891646367341 -49.9518088247357,
-68.5753326357251 -49.9508208246637,
-68.568130602775 -49.9463266828785,
-68.5658115397162 -49.9385758196728,
-68.5703584874913 -49.9081037711289,
-68.5744785868476 -49.903255829211,
-68.5909654970116 -49.8838536763615,
-68.6013716214122 -49.8624607376907,
-68.5921245884911 -49.860282666625,
-68.5810316341811 -49.8546906883087,
-68.5782624880678 -49.8570097513675,
-68.5609136081278 -49.8697858085974,
-68.5214846075676 -49.9058987690083,
-68.518501597195 -49.9143947247323,
-68.5132296231778 -49.9306906532326,
-68.5072555055141 -49.9472236806279,
-68.4921646097046 -49.9682006841178,
-68.4758986045986 -49.9846117296763,
-68.4587855914136 -49.9957657629147,
-68.4542845848498 -49.9999997471893,
-68.4528885704953 -50.001315672459,
-68.4527285683457 -50.0100098266653,
-68.4492945948189 -50.0148466793253,
-68.4344026015715 -50.0307807107744,
-68.4223936393558 -50.0491976798713,
-68.3987884817457 -50.0734477746387,
-68.3872375234829 -50.0813368135181,
-68.3738475086098 -50.0862697730798,
-68.3629765154776 -50.0927777593019,
-68.3574215013542 -50.0987737034414,
-68.3471605934259 -50.1180837978485,
-68.3401565829381 -50.1234098099954,
-68.3316954791675 -50.1266897660515,
-68.3181995002746 -50.1272697518412,
-68.3025055600598 -50.1244356543603,
-68.2850956011913 -50.1248167375878,
-68.2779615119483 -50.1235087332166,
-68.2573775610436 -50.1250566528021,
-68.2413785782268 -50.1247327760638,
-68.2321016219114 -50.1225207331445,
-68.2100605777238 -50.1222417414976,
-68.1975936115552 -50.1207427554627,
-68.1836855699206 -50.1176486764912,
-68.1676406458925 -50.1145707913567,
-68.1398316034221 -50.1090617184446,
-68.125884485355 -50.1032176795362,
-68.11119051457 -50.0948597234659,
-68.1033245343062 -50.0914877089673,
-68.0755235887542 -50.0848197205956,
-68.0630726404025 -50.0833017244044,
-68.045547564476 -50.0740437782453,
-68.0330656366101 -50.0700037679738,
-68.0255506401596 -50.0657078246709,
-68.0130386128795 -50.0591547773374,
-67.9959796378243 -50.0572016597889,
-67.9831315884281 -50.0513347382848,
-67.9716795533864 -50.0436247117114,
-67.9594646478099 -50.0313487272064,
-67.9534144895207 -50.0293237935116,
-67.9376835851128 -50.0191227323719,
-67.9263075906967 -50.0166697181185,
-67.9173884829732 -50.0119168269826,
-67.9010775927757 -49.9999997471893,
-67.8879926205046 -49.9814268244021,
-67.8787455875835 -49.9782716665022,
-67.8626784850396 -49.9657747769393,
-67.8612595880895 -49.9650956919084,
-67.8587565841656 -49.9632758214746,
-67.8484115386933 -49.955550657184,
-67.8351744851712 -49.9416656741651,
-67.8145215344396 -49.9282687945133,
-67.7885205690652 -49.9087147364327,
-67.7774735559665 -49.8984677340818,
-67.77529953336 -49.8920746888978,
-67.7766415095848 -49.8840636681816,
-67.7719576182757 -49.8731076574055,
-67.7450945071053 -49.8263358079221,
-67.7329714839513 -49.8106036713745,
-67.7214886454154 -49.7843476530687,
-67.7128145574853 -49.7541927925044,
-67.710571535052 -49.7359087184823,
-67.7100755107863 -49.7148708120839,
-67.7042925508063 -49.692710778399,
-67.7024235708018 -49.6762507992898,
-67.7033996015162 -49.6643557219924,
-67.6990885204962 -49.6520237631381,
-67.6979524876323 -49.6392207748533,
-67.6978986255225 -49.630763719542,
-67.6957165059976 -49.6193347431159,
-67.6973186397328 -49.5960087531727,
-67.6947175926876 -49.5740657521065,
-67.6791225756939 -49.5512547965854,
-67.6722796234755 -49.522693796818,
-67.6641086006097 -49.5048867369051,
-67.6644286049089 -49.4998546781023,
-67.6658015606477 -49.4955068089093,
-67.660453546005 -49.4799767432833,
-67.6543736403414 -49.4585037155277,
-67.6532745716705 -49.449359654287,
-67.6540455391238 -49.4434696741673,
-67.6552885921274 -49.4340367641615,
-67.6496425756813 -49.4258227924239,
-67.6520306385671 -49.4152987346457,
-67.6495434764402 -49.4086758073855,
-67.6382595404665 -49.3929327576,
-67.6262516343705 -49.3703347862384,
-67.6113665059019 -49.3283077309723,
-67.6046066351077 -49.302264696826,
-67.5922695716743 -49.2753216725909,
-67.584884477959 -49.2613947968199,
-67.5879975670869 -49.2556727397483,
-67.5907825549971 -49.2536046811617,
-67.5984344949817 -49.2487866626381,
-67.6095966251385 -49.2485277372674,
-67.6186755589916 -49.2507857213979,
-67.6333315094639 -49.2514306585552,
-67.6399766152399 -49.2541536874372,
-67.6494295915219 -49.2598377241961,
-67.6609346085735 -49.2586597985801,
-67.664070580297 -49.2575077478993,
-67.6766125309714 -49.2542647560361,
-67.6685105079325 -49.2414897549261,
-67.6587065478373 -49.234660708285,
-67.6565855072407 -49.2298697968363,
-67.6533205128817 -49.2070157164234,
-67.6480635005617 -49.2017747219203,
-67.6320185765336 -49.1981657845467,
-67.6208414846796 -49.1938557596466,
-67.6114045262146 -49.1877096704756,
-67.6008915576943 -49.1733397524489,
-67.595977608289 -49.1648937863954,
-67.5994335843116 -49.159396682841,
-67.6192166443687 -49.1460837647133,
-67.6251066244883 -49.1398927904509,
-67.6281964789806 -49.1311988122646,
-67.6263736162073 -49.115203701887,
-67.6096034899172 -49.0987926563286,
-67.6036605277876 -49.0919497041102,
-67.5966184969871 -49.0727688083586,
-67.5913695815855 -49.064780670238,
-67.5735855802882 -49.0476836748701,
-67.5644985495166 -49.0337597914385,
-67.5516205767262 -49.0257906634743,
-67.5345915250653 -49.0187417678951,
-67.5269246233836 -49.0107576782338,
-67.5234455887454 -49.0057377648086,
-67.515098545913 -48.9993517604233,
-67.4963376338016 -48.990699674989,
-67.4869534813266 -48.9829447633241,
-67.471305482323 -48.9603427435032,
-67.4636616392569 -48.9516677754733,
-67.4494395780021 -48.9468877772625,
-67.4275895154782 -48.9313737294535,
-67.4216845736614 -48.9151536655587,
-67.4109426031646 -48.9016796891616,
-67.4001995765481 -48.8932307307687,
-67.3846205773714 -48.8863867224305,
-67.3673176386426 -48.8758887156073,
-67.3524395509725 -48.8626407488472,
-67.3448335521993 -48.8603556576419,
-67.3265075854251 -48.8491627239909,
-67.318206483804 -48.8452797235295,
-67.2967755248204 -48.8402517131859,
-67.2583926109213 -48.8345296561142,
-67.2421565292096 -48.8285828215454,
-67.2300796232867 -48.8214878087349,
-67.2218095011798 -48.8141706587267,
-67.219421614314 -48.8045698256729,
-67.219116571712 -48.7929157197097,
-67.2149964723557 -48.786510705168,
-67.2125855268743 -48.7830807801004,
-67.1960755580946 -48.7652437967932,
-67.1641156127738 -48.7325246773567,
-67.145561524123 -48.7162746900676,
-67.1380236450768 -48.7062107484819,
-67.1274566384267 -48.6828837024189,
-67.1144336251838 -48.6684687232808,
-67.0924526038049 -48.6567727245655,
-67.0794065319464 -48.6487507906114,
-67.0667116199211 -48.641639759984,
-67.0278626051506 -48.631492736974,
-67.000732647711 -48.6218257204128,
-66.9846035861389 -48.6153826855584,
-66.9688105466829 -48.6107637456169,
-66.9537354926703 -48.6027217453866,
-66.9375916454211 -48.5994676642656,
-66.9248655778617 -48.5980566882139,
-66.9125214736297 -48.5936697425884,
-66.90568556221 -48.5893056795585,
-66.8805316049145 -48.580386747855,
-66.8796305587059 -48.5800667435558,
-66.8686595862327 -48.5763668038596,
-66.8563075611022 -48.5738067694665,
-66.8350825454794 -48.564803700219,
-66.8224414955639 -48.5574377926801,
-66.8142695925983 -48.5510067271833,
-66.8125685356418 -48.5493966725496,
-66.8023834923191 -48.5383838073244,
-66.7884215885748 -48.5282626592495,
-66.7812426142403 -48.5250318127641,
-66.7641905039638 -48.5153537069449,
-66.7522736001905 -48.5068397971844,
-66.7351986073184 -48.4994397417719,
-66.7198255515025 -48.493419682897,
-66.7113415651363 -48.4862898181332,
-66.6991576390738 -48.4738848109928,
-66.6927415352742 -48.4667667395667,
-66.6813204797466 -48.4493367144221,
-66.673805483296 -48.4474677344176,
-66.665283476617 -48.4435347442857,
-66.6433945136805 -48.439521665069,
-66.6246265607704 -48.4330098064076,
-66.6160355542645 -48.4338687838442,
-66.600944482435 -48.4342306808954,
-66.5927356152764 -48.4325746850504,
-66.5798495455675 -48.4235797127213,
-66.5726624743145 -48.423076823677,
-66.5634536377261 -48.4198186940967,
-66.5425334886854 -48.4203606595736,
-66.523025547836 -48.4181637543715,
-66.4887546363747 -48.4170037827922,
-66.4752275019477 -48.4070737924009,
-66.4626464748408 -48.4019547797346,
-66.4602885113693 -48.3996506783729,
-66.4550624785633 -48.3863567704015,
-66.4597704846078 -48.373142775495,
-66.4578175430793 -48.3676456719406,
-66.4372026126604 -48.3533178226859,
-66.4270325310349 -48.3482097232575,
-66.417831615345 -48.3463097637389,
-66.4000625757449 -48.3445627655712,
-66.3846205201021 -48.3460348205512,
-66.3653415812292 -48.3511237338032,
-66.3533174812963 -48.3530766753318,
-66.3350825168448 -48.3567996736436,
-66.3251576310326 -48.3567127197802,
-66.3221355442274 -48.353942693567,
-66.3235706350145 -48.3509867902693,
-66.3336484821776 -48.3439936930195,
-66.3469694972238 -48.3294907038981,
-66.3470536347677 -48.3256077034367,
-66.3500065457261 -48.3155787898243,
-66.3494564833307 -48.3094068257182,
-66.3392564783108 -48.2908097881956,
-66.3283006435548 -48.2756347548421,
-66.3131025515856 -48.2670437483362,
-66.2983165223581 -48.2557147512511,
-66.2898635155059 -48.2517546540443,
-66.2754135083945 -48.2411077343295,
-66.2662125927046 -48.2401088210195,
-66.2580646284544 -48.2379758110652,
-66.249381563506 -48.2294386666691,
-66.227989504935 -48.2098117363223,
-66.2212525167365 -48.2060887380105,
-66.2036205966903 -48.2011147657966,
-66.1947405653993 -48.2012517093305,
-66.1808545262606 -48.196769712923,
-66.1707156001691 -48.1927837407812,
-66.1587605000631 -48.1931157144381,
-66.1478495503985 -48.192542769447,
-66.1432344828963 -48.1860956861333,
-66.1420285701057 -48.1799166812287,
-66.1497426451384 -48.1720007112944,
-66.1515575870132 -48.1674537635192,
-66.148651497366 -48.1612508198991,
-66.1388545780694 -48.1574936737138,
-66.1331865591276 -48.152408808921,
-66.1277616237594 -48.1379588018095,
-66.1171954972092 -48.1378436847514,
-66.1138454852064 -48.1355207492532,
-66.1096644829417 -48.1261096657233,
-66.1012956136336 -48.1203076955869,
-66.0871656108212 -48.1135258222969,
-66.0743254823236 -48.1094967252633,
-66.0654445709328 -48.1100807595122,
-66.0585635984016 -48.1125147636092,
-66.0513835679474 -48.1133457538712,
-66.0488055795177 -48.1080626905961,
-66.0454555675149 -48.1059687570744,
-66.0383455930073 -48.1045146561309,
-66.0245584770898 -48.1100657978151,
-66.0122905895033 -48.1099207573626,
-66.0033265966883 -48.1018176782039,
-65.9947355901824 -48.1042247512461,
-65.9827956277935 -48.104766716723,
-65.9741055220465 -48.0989497848894,
-65.9601365775035 -48.0990068153586,
-65.9522556355426 -48.1005096738327,
-65.9487456213902 -48.1041217795657,
-65.9425655603657 -48.1170657598436,
-65.9366986388617 -48.11950275628,
-65.9333114866459 -48.1187747376985,
-65.9297565874021 -48.1123346951835,
-65.9184955340241 -48.1128766606604,
-65.9110865015934 -48.1100427391994,
-65.9081265498364 -48.1063457918426,
-65.9040145473985 -48.0960157080675,
-65.9066164745436 -48.0889668124883,
-65.9160615299271 -48.0806347313532,
-65.9250645991746 -48.0757257105069,
-65.9333345452616 -48.0726318075554,
-65.9454035302859 -48.0672987546098,
-65.9647755837211 -48.0570337982223,
-65.975196493799 -48.0498507754286,
-65.9735415540738 -48.0480037979199,
-65.9682005802297 -48.0445136740238,
-65.9550246056359 -48.0411527487831,
-65.9385905014618 -48.0331808044994,
-65.932601598121 -48.0287627033398,
-65.9358065696714 -48.0240057637446,
-65.9402774768209 -48.0222357069613,
-65.9500735160176 -48.0246427800034,
-65.9565654844228 -48.0235827877651,
-65.9604115206912 -48.0199736743715,
-65.954093636033 -48.0150988013988,
-65.9436565321182 -48.011543726135,
-65.9253085628482 -48.0110816737229,
-65.9158015484365 -48.0105057363924,
-65.9131466392815 -48.0084147952102,
-65.9146575946741 -48.0034066751228,
-65.9196706433206 -47.9999998086708,
-65.9355235295652 -47.9999998086708,
-65.9340666123023 -47.992480763761,
-65.9383315760911 -47.98822776933,
-65.9505005404564 -47.9818417649446,
-65.9538195729451 -47.9757426731048,
-65.9516605120358 -47.9629176823242,
-65.9423215966921 -47.9510956533129,
-65.929168504694 -47.9412536729049,
-65.9272845629923 -47.9405627945363,
-65.9094546204838 -47.9340206604407,
-65.8948514760014 -47.934192807968,
-65.8831024952762 -47.9389837194167,
-65.8633954758447 -47.9392776727608,
-65.8534776308312 -47.9409026890917,
-65.8448336423154 -47.9443857721892,
-65.8364404822519 -47.9572257246669,
-65.8320084755149 -47.9575957186365,
-65.826019572174 -47.9549636920771,
-65.8166505574161 -47.959338668345,
-65.8115926236782 -47.958549746855,
-65.8050466171433 -47.9531667042389,
-65.7897105255204 -47.9542237041379,
-65.7768855347398 -47.9525907669085,
-65.7742996254117 -47.9497987381996,
-65.7774885791451 -47.9468958169117,
-65.7870716341823 -47.9452667521216,
-65.7953945622792 -47.9415546670477,
-65.7987825945948 -47.934318662244,
-65.7954785238033 -47.9248927930369,
-65.7915495821306 -47.9218446552767,
-65.7669756106248 -47.9174577096512,
-65.774024506204 -47.9118956547291,
-65.7718126393048 -47.9084247170094,
-65.7779615447952 -47.9074097858824,
-65.7931895601586 -47.9084086991924,
-65.8311915668503 -47.9009627025687,
-65.8372195466237 -47.8951487630746,
-65.8475795537931 -47.8910177504803,
-65.8522875598376 -47.8856127053684,
-65.8540195963081 -47.8836138226286,
-65.8612216292582 -47.8668637626147,
-65.8662874838946 -47.8292926528011,
-65.8716816157686 -47.8147847351207,
-65.883308614657 -47.7969776752078,
-65.8851085948347 -47.7869677717518,
-65.8829576308438 -47.774364742149,
-65.8861995665871 -47.7700916814418,
-65.8941035671637 -47.7672808185964,
-65.885406596638 -47.7497516942107,
-65.8610765888058 -47.7494197205538,
-65.8482135777125 -47.7492407082479,
-65.8394924924513 -47.7474667790253,
-65.8362195771939 -47.7451167364523,
-65.8343815767035 -47.7409667137017,
-65.8412785670516 -47.737910655043,
-65.8424306177325 -47.7349667211029,
-65.8386535812909 -47.7211877021038,
-65.8205265170789 -47.6810836649721,
-65.8052824838984 -47.6670726516571,
-65.7965855133727 -47.646716822629,
-65.7738875626701 -47.5935667136387,
-65.7652734975486 -47.5828817736111,
-65.7484435244698 -47.5313647778702,
-65.7460095203728 -47.5263666909209,
-65.7392195501643 -47.5124398151499,
-65.7328715660918 -47.4538227020195,
-65.7255855716176 -47.4082067756562,
-65.7250515270392 -47.4020077044753,
-65.7214586074826 -47.3601417074787,
-65.7152326052469 -47.3424147366505,
-65.7158125910366 -47.3371737421474,
-65.7388305460383 -47.2791058113126,
-65.7397916150555 -47.2766756796548,
-65.7611315717164 -47.2286877082226,
-65.7587964908406 -47.2210957910467,
-65.746581585264 -47.209869765642,
-65.7467956255433 -47.2053027515907,
-65.7516935571316 -47.2008357168804,
-65.7860255475213 -47.1825907192908,
-65.7961804914297 -47.1735647674476,
-65.8128965795902 -47.158694776696,
-65.8437805148557 -47.141734724862,
-65.8545156205738 -47.1261826567402,
-65.8561475016834 -47.1195907089941,
-65.8631824916852 -47.1117326496287,
-65.8738706000722 -47.1044088108618,
-65.883056554065 -47.1009368170222,
-65.9243925549424 -47.0962758083088,
-65.9251865810114 -47.0959626687884,
-65.9315335089641 -47.0934447031673,
-65.9473415101173 -47.0834696516647,
-65.9723666207972 -47.0766446534829,
-65.9804075649078 -47.0763436593401,
-65.9919815817863 -47.0793076595563,
-66.0317156249484 -47.0802917871891,
-66.0488286381333 -47.0787847042358,
-66.0839535984722 -47.0865207817643,
-66.0963135445012 -47.0906678121755,
-66.1034164782101 -47.0930477781428,
-66.1395185253832 -47.0932428082657,
-66.1918795368635 -47.0966876950305,
-66.2218395433248 -47.0912668081216,
-66.277923553117 -47.0875628199661,
-66.2878646327661 -47.0869067935509,
-66.3564224735057 -47.0766068091901,
-66.4163356216496 -47.0645367680459,
-66.4565125310475 -47.0581627330183,
-66.5003055946376 -47.0511967428433,
-66.5475995193418 -47.055782767051,
-66.6130446229934 -47.0569457309698,
-66.6364595030196 -47.056129702405,
-66.6385036228908 -47.0555956578266,
-66.6489185482898 -47.0528757973039,
-66.6622004869034 -47.0443728007813,
-66.6719585057873 -47.0419917786942,
-66.6986235944954 -47.0437238151648,
-66.719833472401 -47.0380626610016,
-66.7335125120591 -47.038470675284,
-66.7399066133629 -47.0367236771163,
-66.7874295400435 -47.0090028206491,
-66.7921525077852 -47.0018616906074,
-66.8024065509347 -46.9863397218998,
-66.8143304955067 -46.97734879803,
-66.8294294882347 -46.961539740757,
-66.8508454855211 -46.9462627918429,
-66.8578415751104 -46.9340058174943,
-66.8629076057668 -46.9315528032409,
-66.8658444989081 -46.9338716902798,
-66.8698654990233 -46.9330067281643,
-66.8969035740404 -46.9056776921426,
-66.9248805395589 -46.8797226679795,
-66.9393386435888 -46.8741757507746,
-66.9421385931962 -46.8687207159922,
-66.9393155849732 -46.8616066930254,
-66.9420625525707 -46.8584367494483,
-66.9541165758979 -46.8556026519674,
-66.983367573934 -46.835826808729,
-66.9926906474806 -46.8295207174085,
-67.0024484903446 -46.824828729181,
-67.0171885783609 -46.8204197810596,
-67.0351105793119 -46.8080406488542,
-67.0449985009311 -46.7976306520143,
-67.0557094919138 -46.7796898169269,
-67.0631405268403 -46.7747387273086,
-67.0848004878004 -46.7422787092628,
-67.0884856418194 -46.7411727758132,
-67.0921245025873 -46.7418978020553,
-67.0942224845682 -46.7400098118944,
-67.1077115986824 -46.7278827402811,
-67.1120225036825 -46.7128407780223,
-67.1168516114639 -46.7044337123814,
-67.1208954941747 -46.7019616879716,
-67.1315235797531 -46.7013776537227,
-67.1405636131936 -46.6978107851211,
-67.1467054778854 -46.689872812691,
-67.1579975107775 -46.6895216528578,
-67.1630936408482 -46.6838568022753,
-67.1726224817357 -46.688747693065,
-67.1825866200004 -46.6881557379176,
-67.1922756390574 -46.685046697249,
-67.2174375172514 -46.6715656800532,
-67.2651676194326 -46.6393047405896,
-67.2760845537761 -46.6403117508181,
-67.2948155424933 -46.631789744139,
-67.3397675215429 -46.6209608197788,
-67.3478016008747 -46.6162257066595,
-67.3582915107794 -46.6039657399715,
-67.3733065419834 -46.5981407112194,
-67.3877185287821 -46.588653763084,
-67.4207074868273 -46.5562168036538,
-67.4396595566224 -46.5309827572736,
-67.4477235593485 -46.5188637825788,
-67.4809795396829 -46.4688718238278,
-67.5272976096927 -46.4058726936309,
-67.5433346128222 -46.3840177025479,
-67.5568385126137 -46.3628426765957,
-67.5809935565991 -46.3088107075731,
-67.5904695914967 -46.2901187952885,
-67.5927816137569 -46.2896768091526,
-67.5911636382247 -46.2873797485895,
-67.6077265890142 -46.255470673039,
-67.612380556929 -46.236575809733,
-67.6171116215891 -46.2173428120713,
-67.626785502929 -46.1289137252715,
-67.6253965293732 -46.1114307181169,
-67.6250835658727 -46.1074107741216,
-67.6194076260323 -46.0886268033945,
-67.6157455306289 -46.0671076584076,
-67.6188125025255 -46.0579797910039,
-67.6165775770107 -46.053394822916,
-67.6113735467005 -46.0494767944812,
-67.5992885438592 -46.0448307474649,
-67.586761554882 -46.0248607542035,
-67.5842895304722 -46.0131837656445,
-67.585189520561 -45.9951248211595,
-67.5848996156761 -45.9921497316854,
-67.5781325280633 -45.9831887312099,
-67.573570618591 -45.9813306644433,
-67.5621036218522 -45.9808006683242,
-67.5641635835204 -45.9741817895231,
-67.5606454724495 -45.9677577648251,
-67.5472795723119 -45.962642800618,
-67.5270075287878 -45.959766810385,
-67.5273666095195 -45.9577107211561,
-67.5454866329329 -45.9502796862296,
-67.5478745197987 -45.9438936818443,
-67.5451275522012 -45.929237731372,
-67.5319214781932 -45.9136008216263,
-67.5157315137127 -45.9011417763561,
-67.4983365165414 -45.8822706757456,
-67.4889675017835 -45.8742028005802,
-67.4756396219586 -45.8686217355018,
-67.4698485650601 -45.8621746521881,
-67.4657976415506 -45.8491097461932,
-67.4455945978535 -45.8238066999861,
-67.4407806277891 -45.8178257175437,
-67.4058225343785 -45.7972067386657,
-67.382461516462 -45.7874187963875,
-67.375106522161 -45.7868198004414,
-67.3700635501203 -45.7864077376998,
-67.3687745559054 -45.7850228126032,
-67.3669585579109 -45.7767757491119,
-67.3724445722074 -45.7420496500172,
-67.3706516328284 -45.7322008048305,
-67.365501640648 -45.7282716871379,
-67.3479535061058 -45.7240148202676,
-67.3460385848901 -45.7214817169294,
-67.3467715320307 -45.7169147028781,
-67.3560256057504 -45.7096667287167,
-67.3607026322808 -45.7035297925841,
-67.3618395452446 -45.6941607778261,
-67.3596035636099 -45.6787866658905,
-67.3568805347278 -45.6600377231367,
-67.3500066029953 -45.643054788707,
-67.3433606171195 -45.631793735329,
-67.3193585344849 -45.6073457941193,
-67.3058775172891 -45.5964816657658,
-67.2886196396718 -45.5787166746249,
-67.2770465028931 -45.5706097230269,
-67.2571256192023 -45.5569377241674,
-67.2181315639794 -45.5375936579069,
-67.2164386039414 -45.5363388115656,
-67.206588526615 -45.5290216615574,
-67.185012527179 -45.5022777159044,
-67.1769105041401 -45.4848137189062,
-67.134284628948 -45.4253696639731,
-67.1133804977241 -45.40067670297,
-67.077331608581 -45.3723908224102,
-67.05215459267 -45.3378027229693,
-67.0375745068033 -45.323230734021,
-67.0194245599956 -45.3090746802537,
-67.010169606176 -45.302795696008,
-67.0016864999095 -45.3052177307473,
-66.9698335747283 -45.2822036481848,
-66.9474716461418 -45.2695926976835,
-66.8758845017784 -45.2413597991338,
-66.8714905153542 -45.2396196657447,
-66.8467255621848 -45.2335927420911,
-66.8179095094859 -45.2339176749493,
-66.785308499447 -45.2307507237117,
-66.7723235065168 -45.232410768016,
-66.7297514934345 -45.2272678166342,
-66.7109145406975 -45.229755682841,
-66.6999205096087 -45.2293777679729,
-66.6954724850547 -45.2277258205871,
-66.6851885185109 -45.2239118199525,
-66.6659085235181 -45.2192918238913,
-66.6504286235826 -45.217700779414,
-66.5843736107469 -45.2194896703337,
-66.5769805961332 -45.2177777001393,
-66.5607526113399 -45.2193676884969,
-66.5520785234098 -45.2174066500499,
-66.5491484950471 -45.218047714768,
-66.5463406245412 -45.2251017149262,
-66.5433576141686 -45.2273447373596,
-66.5375214961587 -45.2277147313292,
-66.5327525872058 -45.2248957715654,
-66.5315706131306 -45.224876761409,
-66.529197511942 -45.2248417334357,
-66.5180814990164 -45.2285617394081,
-66.515975596137 -45.2234957087517,
-66.5186236405133 -45.2111776554747,
-66.5160144965496 -45.2015266567304,
-66.5208355074126 -45.1922187209009,
-66.5355226134189 -45.1775668188879,
-66.5574724792638 -45.1788137443307,
-66.5634914820189 -45.1722677377958,
-66.5732655187198 -45.1698948126272,
-66.5767896144695 -45.1708638025429,
-66.5808025176662 -45.1771007180165,
-66.585014499445 -45.1769336750683,
-66.5936584879609 -45.1690516769875,
-66.5934606415185 -45.1646997593353,
-66.5906064777614 -45.1628267308716,
-66.5809095378058 -45.1629147408548,
-66.5787205535022 -45.1605907492369,
-66.5797805457406 -45.1576346699192,
-66.5905306131558 -45.1548157101554,
-66.5955586234994 -45.1487116897564,
-66.5928195768004 -45.1431807903685,
-66.5883405727324 -45.1415096568063,
-66.5678405833517 -45.1462437138059,
-66.5552525154461 -45.1458247862855,
-66.5482865252711 -45.1411437112959,
-66.5437855187072 -45.1403887616595,
-66.5409545895857 -45.1483536651445,
-66.536331601185 -45.1517177587446,
-66.5236055336257 -45.1554147061014,
-66.5029605037926 -45.1644786782574,
-66.4922715153057 -45.1652297554545,
-66.4852446222223 -45.1623727753779,
-66.4841305918542 -45.1624757470584,
-66.470336611158 -45.1637416826576,
-66.4613495597274 -45.1516987485882,
-66.4624025111672 -45.1491968007841,
-66.497695570574 -45.1470027119015,
-66.5189895860237 -45.1480216914877,
-66.5245516409457 -45.1460456913435,
-66.5308836072013 -45.1397357275837,
-66.5333705933083 -45.1324497331096,
-66.5305255825894 -45.1202777764049,
-66.5221706188586 -45.1084788060091,
-66.5086214819358 -45.0977396518319,
-66.5054626276167 -45.095630756613,
-66.4918515316656 -45.0970227225082,
-66.4585265515044 -45.0793346520927,
-66.4376296370992 -45.076709666332,
-66.4267505470485 -45.0737877348878,
-66.3954165287286 -45.0551987942836,
-66.389305643551 -45.0546378186503,
-66.3840334935138 -45.0579867745333,
-66.3703234743416 -45.0625647018225,
-66.3743895355682 -45.0569118205977,
-66.3735045071765 -45.0543787172596,
-66.3666224785255 -45.0480847713167,
-66.357109479435 -45.0431176638815,
-66.3532636191865 -45.0423657065846,
-66.3395916203271 -45.046027801988,
-66.3325275870308 -45.0449906923453,
-66.3242264854097 -45.0519447131625,
-66.3129805697488 -45.0506097777365,
-66.3061444823091 -45.0523228040506,
-66.2981184998957 -45.0510406746145,
-66.2846906407299 -45.0567586832269,
-66.278533638321 -45.057567670993,
-66.2773435673273 -45.0545726912627,
-66.2832185857499 -45.0528406547921,
-66.2791745270191 -45.0484237857723,
-66.2727355406238 -45.0480807228575,
-66.2535175046593 -45.0262297802338,
-66.2481385105025 -45.0233877618544,
-66.2343065094935 -45.022453799912,
-66.2320634870601 -45.0166817531699,
-66.2284086084753 -45.0072437385851,
-66.2150875934291 -45.0010527643227,
-66.2136225792478 -44.999999812883,
-66.1978145780946 -44.9886097368695,
-66.1952895716749 -44.9871906638995,
-66.1874776295408 -44.9893377554511,
-66.1745915598319 -44.9977986832017,
-66.1707305618663 -44.9974976890589,
-66.1632916060413 -44.9895787267852,
-66.1597365307775 -44.9899707232507,
-66.1560284941628 -44.9942517048564,
-66.1508556193867 -44.9946137779275,
-66.1381374727258 -44.9900288098396,
-66.1117175798312 -44.9897617875504,
-66.0827635274786 -44.9965367960617,
-66.0750806079799 -44.9952426972679,
-66.0697635728513 -44.9992598249438,
-66.0658645545729 -44.999999812883,
-66.0585785600988 -44.9967577011197,
-66.0587695417625 -44.999999812883,
-66.0591585458885 -45.0066107707855,
-66.0211866386112 -45.0047266530639,
-66.0052795382169 -45.0073887790376,
-65.978408506148 -45.0260806913222,
-65.9632494906114 -45.0390086537831,
-65.9576876117093 -45.0437467592419,
-65.9479524754211 -45.0451506944948,
-65.9351885635689 -45.0494726887527,
-65.9099045275182 -45.0368196694795,
-65.898933555045 -45.0368237179387,
-65.8890685160214 -45.0411948217673,
-65.8848575903624 -45.0340117989736,
-65.8859556029135 -45.0308307661386,
-65.8916396396724 -45.0261417702505,
-65.8899385827159 -45.0206106948426,
-65.8934176173542 -45.0145036821042,
-65.886894493415 -45.0086438013988,
-65.8644795828185 -45.0049707927575,
-65.8485034825973 -45.0056836736219,
-65.8470305475175 -45.0057488010095,
-65.8382034982365 -45.008537661359,
-65.8292546431387 -45.0142977387434,
-65.8260956127996 -45.0201836704038,
-65.8258595700245 -45.0256726770398,
-65.8300555339863 -45.0330887502691,
-65.8298335728086 -45.0381167606128,
-65.826797580426 -45.0412597731349,
-65.8198924931595 -45.0443156557737,
-65.8127216157434 -45.0384408133711,
-65.8050004999121 -45.0380437123267,
-65.8010256170281 -45.0329206512011,
-65.8027805360943 -45.0297547560833,
-65.8109135386474 -45.0280987602383,
-65.8143466320743 -45.0233647032388,
-65.8119205488758 -45.0198788038218,
-65.8061375888958 -45.0192988180321,
-65.8012236394905 -45.0210227575842,
-65.7960736473101 -45.028236759892,
-65.7866514745223 -45.0296366466858,
-65.779907621545 -45.0290297298412,
-65.7736965810064 -45.023631725528,
-65.7711256333754 -45.0253447518421,
-65.7703705077191 -45.0258486970063,
-65.7526475853502 -45.0254596928803,
-65.7402876393212 -45.0277057076531,
-65.7359695175025 -45.030586802465,
-65.7363734833257 -45.0358617688217,
-65.7335585720211 -45.041064743012,
-65.7240594785079 -45.0442887247188,
-65.7045515376585 -45.047515698765,
-65.6955266419352 -45.0615077019236,
-65.6893085605979 -45.0634266715985,
-65.6868745565009 -45.0601657256988,
-65.687042479549 -45.0565067986548,
-65.6948084804718 -45.0489007998815,
-65.6945875754138 -45.0466037393184,
-65.6858906048881 -45.0393147525049,
-65.6804885521156 -45.0373577625171,
-65.6786114751926 -45.0432697451326,
-65.668189508995 -45.0450558197329,
-65.6597445990613 -45.0465048160973,
-65.6527705119679 -45.0438266723067,
-65.6518405984847 -45.0499877231748,
-65.6463165638755 -45.0507777007845,
-65.6418076364131 -45.0435756678344,
-65.6348955083479 -45.0395236882052,
-65.6197505744086 -45.0391767528511,
-65.609039583426 -45.0336608151603,
-65.6059565937124 -45.0306126774001,
-65.6054684903452 -45.0271686707352,
-65.6085895003716 -45.0226627356123,
-65.6222386166353 -45.0135917226577,
-65.6239695969861 -45.0108866478122,
-65.6180875377649 -45.005714653136,
-65.5896525682936 -45.006881665514,
-65.5862735129963 -45.0033686590222,
-65.5882035719292 -44.999999812883,
-65.5911945032003 -44.9947857494348,
-65.5918505296155 -44.9943467556383,
-65.6061706339917 -44.984832700428,
-65.6079105913607 -44.982124809263,
-65.6049115631711 -44.9772457118111,
-65.5989536393444 -44.9736747947503,
-65.5997545301921 -44.9704856649969,
-65.5957484917741 -44.9665026851945,
-65.5937724916299 -44.9605026925958,
-65.5846324788484 -44.963035795934,
-65.5746766135222 -44.9623447415454,
-65.5651245379991 -44.9531897670668,
-65.5504145493971 -44.9441418127278,
-65.5398176193527 -44.9434317481829,
-65.5340806005839 -44.9355127859091,
-65.5243685229113 -44.9364247453557,
-65.522193620205 -44.9347687495107,
-65.5229336081442 -44.9327237495396,
-65.5328826086918 -44.9267807874101,
-65.5392455544615 -44.9208376492605,
-65.5443496054307 -44.9160646918484,
-65.5649794975466 -44.9087716565756,
-65.5759275874242 -44.9019316966966,
-65.5868526186862 -44.9024157516046,
-65.5989835627387 -44.9113998106957,
-65.6032485265275 -44.9096677742251,
-65.6082534782555 -44.8990247269496,
-65.6166154827849 -44.8923496977792,
-65.628333483996 -44.8894157969773,
-65.6415406141239 -44.8892626596064,
-65.6588136294584 -44.8914907203426,
-65.6692125370404 -44.8894386795729,
-65.6785736308998 -44.8816376506768,
-65.6794206389787 -44.881683767908,
-65.6859585485951 -44.8820347517212,
-65.6913905247619 -44.8757437981178,
-65.6961515128163 -44.8772276464356,
-65.7037275881953 -44.8732758221673,
-65.7154616072233 -44.8627778153441,
-65.7236704743819 -44.8519707174597,
-65.7259134968153 -44.84492481422,
-65.7251205268661 -44.8410147066837,
-65.7158275527337 -44.84035075937,
-65.7152935081553 -44.8378176560318,
-65.7236025306748 -44.8318217118923,
-65.7266846402886 -44.8204457174761,
-65.7245174824608 -44.8114657068442,
-65.7192386436649 -44.8072276741104,
-65.7043075739849 -44.8034587345872,
-65.6975635449877 -44.7932467602097,
-65.6967844806159 -44.792072707033,
-65.6902995530094 -44.7722357848662,
-65.6891936195598 -44.7399257358319,
-65.6827014751347 -44.7203178156415,
-65.669067496588 -44.7026058065106,
-65.6446075860205 -44.6763997778752,
-65.6378244805908 -44.6705207109935,
-65.6088714843579 -44.6519888008584,
-65.5909956006381 -44.6435548041627,
-65.5789415773109 -44.6476206893693,
-65.5738065468277 -44.647727709509,
-65.5643845500598 -44.636970777315,
-65.5504985109211 -44.6256488210286,
-65.5327226065423 -44.6156077620385,
-65.5185625043157 -44.6102298240015,
-65.506179499671 -44.6078678120707,
-65.4974135293184 -44.6037596820721,
-65.4821015524309 -44.6024706878573,
-65.4745555764662 -44.5995367870554,
-65.4643025894365 -44.5997427304162,
-65.4640806282587 -44.5988916738781,
-65.4626846139042 -44.5935207766397,
-65.4666285172741 -44.5849148084366,
-65.4652096203239 -44.5812187411797,
-65.4570766177709 -44.5773547508746,
-65.4364696082506 -44.5731777970691,
-65.4259034817004 -44.5731427690958,
-65.4175335562724 -44.574077787158,
-65.4116595939697 -44.5764507123266,
-65.4015505912726 -44.5865018044548,
-65.3920595946779 -44.5906146869925,
-65.3876575113352 -44.5824887252381,
-65.381423588201 -44.579124807658,
-65.374725500415 -44.5787236581543,
-65.3698955125337 -44.5854717356107,
-65.3676296075047 -44.5861017110709,
-65.3602754933035 -44.5795016664063,
-65.3620224914713 -44.5765688217241,
-65.3695146053262 -44.5730246596983,
-65.3849865843632 -44.5657008209314,
-65.390029556404 -44.5607907439653,
-65.3919756331538 -44.5539706743426,
-65.38941964722 -44.5474927875347,
-65.3838505514993 -44.5436897001381,
-65.3664164778955 -44.5404966979454,
-65.3630985015266 -44.5365177666023,
-65.3641815523806 -44.5340267320361,
-65.3713754884122 -44.5310057013507,
-65.3720244740288 -44.5243797817511,
-65.3701174737115 -44.5179217851994,
-65.3667296174159 -44.5153158095951,
-65.3574065438693 -44.5162196721232,
-65.3484955330642 -44.5091207868735,
-65.3411945768929 -44.5080187258631,
-65.3318405238322 -44.5096087142207,
-65.3239895052655 -44.5130687387025,
-65.3212435937878 -44.5166627143789,
-65.3202746038722 -44.5292358205874,
-65.3186115672285 -44.5305667075542,
-65.3144756260752 -44.5299986911223,
-65.3096165948994 -44.5188826781967,
-65.3003616410798 -44.5122257790829,
-65.2917635937752 -44.5177267550765,
-65.2840885951751 -44.5177577345906,
-65.2809825468459 -44.5158428133749,
-65.281791534612 -44.5126566759609,
-65.2893595130725 -44.508502780771,
-65.2908405450708 -44.5046497037039,
-65.284835623913 -44.4971656867675,
-65.2897036321071 -44.49315665601,
-65.2918475552993 -44.4913938160453,
-65.2992245520961 -44.4908977917797,
-65.3128506097443 -44.4933166581596,
-65.322341606339 -44.488982694544,
-65.321258555485 -44.4852906757462,
-65.315696500563 -44.4814796674511,
-65.312126639622 -44.4763486854271,
-65.312988609398 -44.4720187702707,
-65.3166966460127 -44.4682237797925,
-65.3326415906998 -44.4626807350269,
-65.3343424716363 -44.46066671457,
-65.3302155075013 -44.4539188131335,
-65.3179166404007 -44.4444387297767,
-65.306732507748 -44.4446027803855,
-65.3040385221604 -44.4410976947922,
-65.3092724758649 -44.4325337953612,
-65.3090814942012 -44.4300077328216,
-65.3043286030652 -44.4291987450555,
-65.2926635838641 -44.432555797857,
-65.2866364841905 -44.4323996681467,
-65.2850035469611 -44.4323577753946,
-65.2812955103464 -44.4299697125089,
-65.2917255734625 -44.4258916819246,
-65.2896955351886 -44.4219437300955,
-65.2827075425178 -44.4213026653774,
-65.2798385930835 -44.4088598139442,
-65.268890503206 -44.404449809703,
-65.2625125957391 -44.3921396773245,
-65.258186553022 -44.3895076507652,
-65.240348513595 -44.3888056831387,
-65.2340464707337 -44.3872607558926,
-65.2321706259505 -44.3743857754415,
-65.2303315693403 -44.3729626540122,
-65.2166514735624 -44.3721346560897,
-65.2143095279078 -44.368179663462,
-65.2203975304898 -44.3617017766542,
-65.2222284901816 -44.3516887048388,
-65.2244415892206 -44.339595781099,
-65.2280654882913 -44.3374027483361,
-65.241226501188 -44.3356937704812,
-65.2471235221063 -44.3326417602817,
-65.2536086257327 -44.3245696606371,
-65.2552875041734 -44.3168256622101,
-65.2533956415732 -44.3103637932192,
-65.2605056160808 -44.3084907647555,
-65.265541547323 -44.3035847362486,
-65.2705765984652 -44.2924956543779,
-65.2695995116311 -44.2867466662514,
-65.2651826426112 -44.2738037420933,
-65.2917706345739 -44.2522888215857,
-65.3002856004543 -44.2415197440141,
-65.3062285625839 -44.2249527447653,
-65.3091585909465 -44.2112886668044,
-65.3089755301814 -44.2025797269209,
-65.3041686009157 -44.1845897822628,
-65.2968525070273 -44.1722608157479,
-65.2827915040418 -44.1551706851586,
-65.2815016297272 -44.1542166569401,
-65.2766646010472 -44.1506536607778,
-65.2697985902132 -44.148181812388,
-65.2377316247527 -44.1475567654868,
-65.229255559285 -44.1454968038187,
-65.2203366275814 -44.1397587289301,
-65.216285528052 -44.1323206532049,
-65.2187806110774 -44.127120671354,
-65.2305755330139 -44.1143798181175,
-65.2322315288589 -44.1009137626188,
-65.2378085454781 -44.085487724793,
-65.2354204825923 -44.0764887040048,
-65.228561512557 -44.0680576996484,
-65.2211684979432 -44.0613597878824,
-65.2155305784156 -44.0562557369133,
-65.2120665054745 -44.0497477506912,
-65.2076565012333 -44.0491718133607,
-65.2047196080919 -44.0447387505039,
-65.1915436334982 -44.041862760271,
-65.1863255215907 -44.0385127482682,
-65.1908955279814 -44.0361178206037,
-65.2047886079188 -44.0374106872578,
-65.2149044753947 -44.0440976857859,
-65.222862514101 -44.0436287685951,
-65.2354965232178 -44.0386996814726,
-65.2418365863919 -44.0326847271767,
-65.2484665544508 -44.0211786540053,
-65.244811499846 -44.0121497098227,
-65.2459415480311 -44.0087437234706,
-65.2583775346856 -43.9953346984411,
-65.2580105330554 -43.9900548035254,
-65.2525864777872 -43.984641661495,
-65.2482905344843 -43.9820098109557,
-65.2463984958642 -43.9815176591293,
-65.2354655437037 -43.9786877861275,
-65.2321016261236 -43.9763067640404,
-65.2335354847709 -43.9731368204634,
-65.2374415438479 -43.9711796544557,
-65.2608645207926 -43.9718098059358,
-65.2730405259566 -43.9691547207608,
-65.2818455727418 -43.9643516639344,
-65.2914735128704 -43.9559016494217,
-65.3014675745295 -43.9339487912374,
-65.3119815991696 -43.8955157116478,
-65.3194735370045 -43.8663937362471,
-65.3293994789365 -43.8453517813895,
-65.3214185576346 -43.8217807716529,
-65.3215565572883 -43.8128507506915,
-65.3141325631604 -43.8034937052913,
-65.312988609398 -43.7949907087687,
-65.3161395428187 -43.7888866883697,
-65.3236385214523 -43.784274789227,
-65.3419956437606 -43.7774237400901,
-65.3499526263471 -43.7698437922719,
-65.3516535072835 -43.761184666039,
-65.3512196180661 -43.7586857105743,
-65.3448026341667 -43.7216108010463,
-65.3341675077896 -43.6633837481617,
-65.3280715843091 -43.6467327873889,
-65.3241655252321 -43.6431616943082,
-65.3190304947488 -43.6384778029991,
-65.3013306309955 -43.6272428005761,
-65.2882305210073 -43.6060528129267,
-65.2550886016112 -43.5769876919752,
-65.2350466161834 -43.5627057839318,
-65.2131425155298 -43.5543217769065,
-65.2098006004455 -43.5519136477446,
-65.2019194824646 -43.5462267946663,
-65.1736526120612 -43.5154377341627,
-65.1681745186632 -43.5001676500272,
-65.1602705180866 -43.4891857643161,
-65.1269536348439 -43.4538916487894,
-65.1172105776571 -43.44721169106,
-65.1130146136952 -43.444335700827,
-65.0945436064686 -43.4374006901662,
-65.0842816424205 -43.4238207497492,
-65.0770796094704 -43.4176596988811,
-65.0672605116581 -43.4134827450756,
-65.0591206443264 -43.4072947631526,
-65.0483556152141 -43.3746837199756,
-65.0494615486637 -43.3660087519457,
-65.0565796200898 -43.350639744589,
-65.0560534964098 -43.3430636692101,
-65.0544585794932 -43.3377498024408,
-65.0345075963881 -43.3071636929586,
-65.0107426126485 -43.283561703708,
-64.9999995860319 -43.275417787917,
-64.9563825424083 -43.2423438122281,
-64.9227525196451 -43.2218517437459,
-64.8892444787187 -43.2057188097345,
-64.824493597815 -43.1785316458058,
-64.8125914797189 -43.1738317366798,
-64.7483904851907 -43.1484297672515,
-64.7287214860719 -43.1427647406491,
-64.6948015584238 -43.1297686584611,
-64.6574245986333 -43.1203767611075,
-64.566169511271 -43.0973816887014,
-64.5398406206991 -43.0887107691307,
-64.52411658107 -43.085433805414,
-64.5060805191806 -43.0841367142808,
-64.4949565853565 -43.0809327988502,
-64.4916685323819 -43.0799828190909,
-64.4703755730521 -43.0710107293575,
-64.4371644778092 -43.0533717685126,
-64.4076306156868 -43.0321847732026,
-64.363799531784 -43.0153007619941,
-64.3531415228113 -43.0117687453459,
-64.3289875349456 -43.0037617730889,
-64.3145296069357 -42.9773517373124,
-64.3162685081849 -42.9746667287431,
-64.3243786281423 -42.9699136615872,
-64.3273545977162 -42.9532887517694,
-64.3337786224143 -42.9457246457482,
-64.3398666249963 -42.94319171843,
-64.3455276031395 -42.9424747891064,
-64.3730625825221 -42.9503177107546,
-64.3869935067522 -42.9531556806748,
-64.4192125534638 -42.9597166489068,
-64.4245146268953 -42.9596707076955,
-64.4415054822235 -42.9524686747454,
-64.4490125577755 -42.9520377778674,
-64.458846617285 -42.9542088081344,
-64.4721144743013 -42.9514537436185,
-64.4864115200619 -42.9521717290619,
-64.4955745914589 -42.9501916804585,
-64.5281756014979 -42.9274676788009,
-64.5345686466819 -42.9249307030235,
-64.5398944828088 -42.9249187336657,
-64.5473475202312 -42.9249037719686,
-64.5801166293381 -42.9289737056344,
-64.6391524939689 -42.9215277090107,
-64.6972355625209 -42.9037097358599,
-64.7008135203803 -42.9010736608413,
-64.7012706442333 -42.8991237116522,
-64.7029185431599 -42.8919787091713,
-64.7066116180774 -42.887511674461,
-64.7587056072686 -42.8701587460617,
-64.801345564058 -42.8540918195378,
-64.8152465648939 -42.8451308190622,
-64.8266445618059 -42.8418197074721,
-64.8449634877814 -42.841998719778,
-64.8480985794051 -42.8420256508329,
-64.8587954887904 -42.8398357864294,
-64.8734355974657 -42.8395997436543,
-64.8822705676452 -42.8373488003225,
-64.8826595717712 -42.837035660802,
-64.8858566224231 -42.834480730988,
-64.8926694752272 -42.8186526635587,
-64.9330445831075 -42.8084216790247,
-64.9596866131999 -42.7879178172048,
-64.9627535850965 -42.7886967055566,
-64.9701075232777 -42.7960166718843,
-64.9735254789876 -42.7961198195847,
-64.9773785560547 -42.7942386942025,
-64.9999995860319 -42.7831607015896,
-65.0100784893148 -42.7871246712356,
-65.0147326332495 -42.7872617907896,
-65.0178455463574 -42.7871246712356,
-65.0255205449575 -42.7832256529573,
-65.0327915777345 -42.7751928057652,
-65.0380855542475 -42.763664730098,
-65.037925552098 -42.74372870869,
-65.0345075963881 -42.7324067524036,
-65.027915648642 -42.7223627010741,
-65.0199206457427 -42.7152557189059,
-65.00736954203 -42.709140785269,
-65.0054095597029 -42.7081867570505,
-64.9999995860319 -42.7022937845914,
-64.9924625870855 -42.6729846999663,
-64.9863895462007 -42.659290698611,
-64.9695204966894 -42.6503106879791,
-64.9565275828607 -42.6386947783486,
-64.94517552716 -42.6310236521877,
-64.9187695398427 -42.6210637384022,
-64.9066695753043 -42.6196788133056,
-64.899673485715 -42.618877746438,
-64.877014611445 -42.6195566554489,
-64.8585055839056 -42.6233407326891,
-64.8516995958801 -42.6231307408691,
-64.843246589028 -42.6192017991964,
-64.8222195958676 -42.6022838161344,
-64.7916255654869 -42.5850567420111,
-64.7750545177789 -42.5664368218928,
-64.7717435822086 -42.5637667750207,
-64.7623446440564 -42.5561827787433,
-64.7126466386495 -42.532825809286,
-64.6773525231228 -42.5124397048237,
-64.6377635204131 -42.501975669854,
-64.6273116308212 -42.5009346877721,
-64.5658114866591 -42.4947697644647,
-64.4598925279261 -42.5105356968458,
-64.4518056426043 -42.511733688738,
-64.4101026400966 -42.5201337135802,
-64.3598556284142 -42.5360107145602,
-64.3457865285102 -42.5380287834764,
-64.3295976201496 -42.544097775902,
-64.3122325463726 -42.5537906673983,
-64.307945580088 -42.5577586855035,
-64.3069915518695 -42.5598376573281,
-64.3057705013617 -42.5624927425031,
-64.3073506326012 -42.5666767371072,
-64.3137435017652 -42.5730937210066,
-64.3130265724415 -42.5792537157549,
-64.3171304779609 -42.5874217462813,
-64.3156966193137 -42.5903477261847,
-64.3113865944135 -42.5899617143982,
-64.3024905453056 -42.5839157805882,
-64.2935716136021 -42.5829087703597,
-64.2885585649556 -42.5790597417518,
-64.2836764751643 -42.5779687699993,
-64.2770915682168 -42.5791056829631,
-64.265014486274 -42.588290756856,
-64.2623745388161 -42.5953026882422,
-64.2667845430573 -42.612647695743,
-64.273925497079 -42.6218417466542,
-64.2745586408986 -42.6262207713813,
-64.2713925697608 -42.6272506642054,
-64.2666856198361 -42.6243667530739,
-64.2630536238469 -42.6221348198985,
-64.2562335542242 -42.6221196821814,
-64.2440716306575 -42.6184697321556,
-64.2323536294464 -42.6175806553047,
-64.22197760446 -42.6197247545169,
-64.2168124745625 -42.622741736743,
-64.2119824866812 -42.6344836766696,
-64.2136155999306 -42.6377486710286,
-64.2253725015543 -42.6427647120145,
-64.2267685159088 -42.6451077137888,
-64.2222745501436 -42.6518177709325,
-64.225074499751 -42.6562726602651,
-64.2290416377564 -42.6573367009627,
-64.2374876038099 -42.6562687878258,
-64.2479555112188 -42.6804806862605,
-64.2476194891027 -42.6910096725977,
-64.2473836223475 -42.6981087338674,
-64.2513886046458 -42.7216267615941,
-64.259483586886 -42.7397957185581,
-64.2612995848806 -42.7497137395916,
-64.2573695870881 -42.7619476553246,
-64.248611537634 -42.7765277411913,
-64.2390825207265 -42.7887836594201,
-64.2185746104473 -42.8064917961118,
-64.211326636286 -42.8127517702011,
-64.1815715170657 -42.8474116857884,
-64.1624525803423 -42.8583948036393,
-64.1508335023524 -42.8733177764008,
-64.1453936052871 -42.8754076614633,
-64.1203765915256 -42.8769946574814,
-64.0976716000244 -42.8766017809161,
-64.0951075171721 -42.8763127561311,
-64.0887144719881 -42.8755798089905,
-64.0738985193663 -42.869289735487,
-63.9920884873874 -42.8595197472453,
-63.9598234994646 -42.8493347039226,
-63.9465945428609 -42.8472136633261,
-63.9306105217412 -42.8465917847844,
-63.9233136140291 -42.8463057523388,
-63.9099426093125 -42.8418846588397,
-63.875919533964 -42.8389396687799,
-63.8616715977741 -42.8337896765995,
-63.8307915349478 -42.8263707870506,
-63.8041266222598 -42.8250696474581,
-63.7818755862522 -42.8189006756915,
-63.7659915444735 -42.8178596936095,
-63.7636064739272 -42.8177037399192,
-63.7438925897169 -42.8191907565963,
-63.7368236278615 -42.8179897723648,
-63.6911626403868 -42.8007547773431,
-63.6623914727793 -42.7825967336169,
-63.6403995381624 -42.7734297897806,
-63.6358485419281 -42.7679666580797,
-63.634513606502 -42.7571336852602,
-63.6348035113869 -42.7545548167308,
-63.6355135759318 -42.7482378121723,
-63.6434936171339 -42.7215156929952,
-63.6436006372736 -42.7040978132282,
-63.6313785148783 -42.68547771709,
-63.6076925641037 -42.6388586529374,
-63.6047785535579 -42.6351926850947,
-63.5890506414895 -42.6153756531842,
-63.5871165340974 -42.6084177599276,
-63.5876695888322 -42.6013336603551,
-63.5994715515674 -42.5692786642523,
-63.6035194827374 -42.5531726612958,
-63.6031915575398 -42.5176236688576,
-63.605235501391 -42.5144466844819,
-63.6070675172025 -42.5116007936632,
-63.6109315075076 -42.5097006581247,
-63.6103365600207 -42.5053557812711,
-63.6059344766781 -42.5062786539556,
-63.6020465476576 -42.5045087731922,
-63.6004636000987 -42.5010036875989,
-63.6048355840271 -42.4885787902023,
-63.6079136451816 -42.4489746497754,
-63.6089745175198 -42.4353406712287,
-63.602233480862 -42.3431317316679,
-63.6053805418434 -42.3234407300533,
-63.6058385457963 -42.3205907907754,
-63.6118466353135 -42.3107567312659,
-63.626254573653 -42.2760656601446,
-63.6352845739554 -42.2629206650649,
-63.6430055137668 -42.2547647799162,
-63.6625136306361 -42.2415997185604,
-63.6804386239266 -42.2208057758356,
-63.6843564763413 -42.2145917429576,
-63.695503644801 -42.1969066648815,
-63.7252656288 -42.1250267993138,
-63.7399525587864 -42.1015666821561,
-63.7422064944577 -42.0966486842916,
-63.7484055656385 -42.0831227820044,
-63.7648775141054 -42.0725707370515,
-63.7905655159793 -42.0701867226249,
-63.8150294750059 -42.071868769425,
-63.8438756271191 -42.0767057981049,
-63.8637695797551 -42.0820886647011,
-63.8814965505832 -42.0834887275148,
-63.8898626035719 -42.085963744264,
-63.9182166038586 -42.0943447589498,
-63.9289936023287 -42.0984417996905,
-63.9451786382502 -42.1128307278736,
-63.9718856197102 -42.1221277504652,
-64.0068815574136 -42.1491587846836,
-64.0211405828614 -42.1520046755023,
-64.026946601457 -42.1542357285779,
-64.0304335569938 -42.155570664004,
-64.043533490962 -42.1661607292697,
-64.0599056361079 -42.1697696666432,
-64.0724335051849 -42.1798707484419,
-64.1127165546227 -42.1894266964042,
-64.1449965042427 -42.1991197639205,
-64.1768115851311 -42.2064437787074,
-64.1901774852688 -42.2095147990632,
-64.2540815341135 -42.2164536821634,
-64.3052676123174 -42.224956678686,
-64.3420105481885 -42.2329867095586,
-64.3805925406698 -42.2413976476388,
-64.3826144820252 -42.2435306575931,
-64.37328348758 -42.2448046901107,
-64.3622135918856 -42.2492217351506,
-64.3373035982638 -42.253146804384,
-64.3236995431114 -42.253803710899,
-64.2936175548134 -42.2520336541157,
-64.2911835507163 -42.2514837677403,
-64.2898334775731 -42.2486876905721,
-64.2740025938243 -42.2504047653455,
-64.275581492924 -42.2451936942367,
-64.2715525719103 -42.2435077749974,
-64.2701796161715 -42.242931661647,
-64.2511365440537 -42.2420077328427,
-64.246650499187 -42.2400127225422,
-64.2410585208706 -42.2407227870872,
-64.2365724760039 -42.2433086964153,
-64.2333606396749 -42.2498356927938,
-64.2295605446177 -42.2513007069751,
-64.2233505601989 -42.247405737156,
-64.2024004877638 -42.2473187832925,
-64.1815875348827 -42.249755779729,
-64.1742406375001 -42.2490237126882,
-64.1606746026605 -42.2446218053655,
-64.1479414943025 -42.245975750948,
-64.1323624951258 -42.2440187609602,
-64.1226275348575 -42.246627728904,
-64.1164935910642 -42.2493437169874,
-64.1016464829083 -42.2559166545771,
-64.0930866319365 -42.2549057719094,
-64.0874406154904 -42.2606507115766,
-64.0795975178223 -42.2626416734179,
-64.0717774787697 -42.273113805306,
-64.062507563253 -42.2778017450743,
-64.059463473952 -42.2815817738553,
-64.0575784761305 -42.290904671382,
-64.0520245181269 -42.2952727828712,
-64.0524525986855 -42.3023947267365,
-64.0483324993292 -42.3171307662935,
-64.051330471399 -42.3227466833253,
-64.0640185186456 -42.331023670211,
-64.0673595536301 -42.3361926725478,
-64.0600056154489 -42.3400156502006,
-64.0484615219647 -42.3460117703601,
-64.0443495195268 -42.3518147966163,
-64.0485685421043 -42.3664126604996,
-64.0564575809837 -42.3816107524687,
-64.1117625264041 -42.4169427122882,
-64.1206135144006 -42.4319417256753,
-64.1257936059953 -42.4330517075841,
-64.1297915474948 -42.4320297356585,
-64.1758195365998 -42.4202576963177,
-64.1863634846342 -42.4197306925379,
-64.2136075030121 -42.4234887188231,
-64.2294086393866 -42.4183387266427,
-64.2711945472984 -42.4173428056721,
-64.2840955787045 -42.4184987287923,
-64.2930294721052 -42.4139447402185,
-64.2975315347889 -42.4116517281146,
-64.308471527748 -42.409751768596,
-64.3187405325947 -42.4133297264555,
-64.3270185756001 -42.4143147341881,
-64.332092527155 -42.4170147044545,
-64.3396145644042 -42.4248467128648,
-64.3447034776563 -42.4273187372746,
-64.3551865227823 -42.4276927797034,
-64.3652194848539 -42.4255257978956,
-64.3753205666526 -42.4270286563698,
-64.3913955900949 -42.4317206445973,
-64.4135665370178 -42.4329566568022,
-64.4261554850232 -42.439124748469,
-64.4352495565934 -42.4419627183892,
-64.4426344742887 -42.4424476533969,
-64.4476246403396 -42.4420246774174,
-64.4560016065662 -42.4413066919739,
-64.4768825031544 -42.4434046739549,
-64.4836045296558 -42.4397387061122,
-64.4931185848661 -42.4311337940289,
-64.5067446425143 -42.4306826548547,
-64.5142974832577 -42.4236066522007,
-64.5207825868841 -42.423599787422,
-64.5253754758705 -42.429256717106,
-64.5330504744706 -42.4299738224496,
-64.5431365945721 -42.4268797434781,
-64.5495685401687 -42.4277837820261,
-64.5609895956963 -42.4329797154178,
-64.5675505639284 -42.431827664737,
-64.5771404837442 -42.4266507415017,
-64.586410575281 -42.4267306545665,
-64.5952985274704 -42.428851695163,
-64.5964584990497 -42.4291268143707,
-64.608207479775 -42.4290616869831,
-64.6129985672437 -42.4264717291957,
-64.6205065228956 -42.4148067099945,
-64.6218104788075 -42.4086646692828,
-64.6204755433814 -42.4001426626038,
-64.6158525549808 -42.3949507776713,
-64.5976184706291 -42.3851816695295,
-64.5953905859129 -42.3812106590849,
-64.5972516450189 -42.3760038124553,
-64.5711825599175 -42.3432846930188,
-64.5681604731123 -42.3372267898511,
-64.5676494871495 -42.3301697973534,
-64.5669936367543 -42.3211517664087,
-64.5612865413798 -42.3136286730397,
-64.5409014930373 -42.294379657561,
-64.5270694920283 -42.2936817383938,
-64.5208665484082 -42.2843056828372,
-64.5098415378052 -42.2782016624383,
-64.4875646268625 -42.2600247845757,
-64.4762805148689 -42.2532237251093,
-64.4716944906612 -42.247794741282,
-64.4710465611644 -42.2434197650142,
-64.4781795942877 -42.2395666879471,
-64.4790195615679 -42.2391127324534,
-64.5173945545686 -42.2413487140881,
-64.5464404893437 -42.2350047784748,
-64.6219326366643 -42.2295187641783,
-64.6453175932962 -42.2265857434762,
-64.6796566244846 -42.222259700759,
-64.710914602179 -42.2145727328012,
-64.7455595560691 -42.2170678158266,
-64.7532956335976 -42.2163996440337,
-64.7716825032803 -42.2073666513919,
-64.790252609748 -42.2003976688774,
-64.7980425493863 -42.1988147213185,
-64.8060685317997 -42.1991616566725,
-64.8173904880861 -42.1996538084989,
-64.8398286333181 -42.194858672571,
-64.8599244808557 -42.1931958119473,
-64.8770445348393 -42.1898347106866,
-64.8952946370079 -42.1828387971173,
-64.9181365720431 -42.1704827235276,
-64.9540175381382 -42.1469576550023,
-64.9842076026957 -42.1271367506524,
-64.9999995860319 -42.1140787094362,
-65.0189666175242 -42.0983997309185,
-65.0334546449484 -42.0805087094816,
-65.0540315550544 -42.0476037129605,
-65.065368473038 -42.0294608069514,
-65.0688784871904 -42.0213207635998,
-65.0717166331305 -42.0026248028559,
-65.0741045199963 -41.997619675108,
-65.0855174786055 -41.9737126432554,
-65.0864255656127 -41.9682426467758,
-65.0830155308014 -41.9573816867817,
-65.0739974998567 -41.9424627624794,
-65.072944548417 -41.9277726641336,
-65.0759125970924 -41.9122887157388,
-65.0739746172611 -41.9083407639098,
-65.0686415643155 -41.9049757902098,
-65.0662765600453 -41.8861277482149,
-65.0488055222485 -41.8750796789964,
-65.0572895086147 -41.8595316593338,
-65.0569605272973 -41.8485297073465,
-65.0534366075676 -41.8399506701983,
-65.0493694902212 -41.8359377670016,
-65.0296635269095 -41.832607645255,
-65.0267565571624 -41.8297726676743,
-65.0264585553591 -41.8255538211167,
-65.0241695917145 -41.7925986589052,
-65.022621496109 -41.7872847921359,
-65.0133206010781 -41.778304781504,
-65.0097736227328 -41.7704127502852,
-65.014945617409 -41.7595746728867,
-65.0300905513483 -41.7394177464208,
-65.033798587963 -41.7102207865143,
-65.0318456464344 -41.6215477360409,
-65.0186305954081 -41.5950507464009,
-65.012222588527 -41.5895916631593,
-65.0092695015487 -41.5821757659499,
-65.017311501779 -41.568679787057,
-65.0166325927681 -41.5643078031285,
-65.01026155008 -41.5581627700774,
-65.0052794809476 -41.5488546582279,
-65.0041355271852 -41.5362276899097,
-65.0094756209295 -41.5162386864918,
-65.0156785645496 -41.5047146592838,
-65.0383224771225 -41.483447750909,
-65.0516285304715 -41.4678157697224,
-65.0690075098259 -41.4440616992207,
-65.0879215593082 -41.41394081051,
-65.0945735298629 -41.3950577405417,
-65.1007685525846 -41.3774606724489,
-65.1034926375864 -41.3544157863923,
-65.1218876041875 -41.2810137001541,
-65.1237416224948 -41.2713847039057,
-65.1326526332999 -41.2252426538624,
-65.1370846400368 -41.2157597541861,
-65.1454776240804 -41.2056996850397,
-65.1492696222191 -41.1966557791599,
-65.1599045725763 -41.1496387338631,
-65.1715695917774 -41.0979576875134,
-65.1731416260984 -41.0849566767663,
-65.172355520928 -41.0528907674256,
-65.178001537374 -41.0132297725495,
-65.1776505535608 -40.9843827403365,
-65.174652581491 -40.9721637863007,
-65.1648106010831 -40.9521976654785,
-65.1573635483396 -40.9296377144296,
-65.1525346165781 -40.9149967256545,
-65.1390535993823 -40.8958397686184,
-65.1246945945936 -40.8645247604548,
-65.1214595236289 -40.8454357471257,
-65.1148374764685 -40.8337976589794,
-65.0922395051069 -40.817249669887,
-65.051063506379 -40.7870486920916,
-65.0221485304589 -40.7706147639375,
-65.0061726062577 -40.7655527817403,
-64.9999995860319 -40.7650907293282,
-64.975021472683 -40.7632296702222,
-64.9515536106468 -40.7634197717861,
-64.9412455293675 -40.7649307271787,
-64.922553617083 -40.7712137598836,
-64.9183734949181 -40.7706256771754,
-64.9164504767838 -40.7673606828165,
-64.9193495256324 -40.7637897657557,
-64.9534606109641 -40.7559237854919,
-64.9596024756559 -40.7535976816343,
-64.9609375871019 -40.7511217847853,
-64.957046489722 -40.7452807382163,
-64.9520184793784 -40.7437516527671,
-64.941574510685 -40.7477756452217,
-64.9322964982498 -40.7470287925038,
-64.9298705910712 -40.7419206930754,
-64.9334335872335 -40.7372246563886,
-64.9383545774374 -40.7350886540949,
-64.9572825324971 -40.7350006441117,
-64.9831615160347 -40.7348707413764,
-64.9937896016131 -40.7329097029294,
-64.9981455677245 -40.73006768455,
-64.9935915791508 -40.7253498213874,
-64.9728465699767 -40.7254028033973,
-64.9517285744936 -40.7158237968193,
-64.9367526197222 -40.7149007481149,
-64.9208145398137 -40.7150917297786,
-64.8827894745065 -40.7207187360682,
-64.8723294879961 -40.7222597908751,
-64.8559186184577 -40.7254028033973,
-64.8274385878749 -40.7347867798524,
-64.818710637835 -40.7349666722581,
-64.812538497709 -40.7324788060514,
-64.8079985907326 -40.733016723069,
-64.7879104880735 -40.7426677218133,
-64.7734525600636 -40.7536386942865,
-64.7739565052277 -40.7552566698188,
-64.791046635817 -40.7562717769657,
-64.7945555938496 -40.7579877956193,
-64.798385612301 -40.7647476664135,
-64.7994464846392 -40.771568792156,
-64.79970558603 -40.7732577037348,
-64.7984315535123 -40.7798536999401,
-64.7910915209085 -40.7819057407098,
-64.7863615123682 -40.7803807037199,
-64.781257637419 -40.7749476714333,
-64.7625356257201 -40.7761727704003,
-64.743667517449 -40.7851636942701,
-64.7406765861779 -40.7901036946305,
-64.7431185111734 -40.7947576625453,
-64.7525934899512 -40.7973597657103,
-64.7551575728035 -40.7999608127556,
-64.7370525110873 -40.8060037542261,
-64.7354125330592 -40.808238679741,
-64.7387845475578 -40.8124696716762,
-64.7480696007917 -40.8132327182311,
-64.7724536467536 -40.8110157467528,
-64.8110125806193 -40.8074986918018,
-64.8295216081586 -40.7993966687629,
-64.8404695220162 -40.7974586889315,
-64.8436665726681 -40.7993927963236,
-64.8454515911486 -40.8051676593852,
-64.842941546426 -40.8124128172271,
-64.8454515911486 -40.8159256476989,
-64.8511886099173 -40.8156507045112,
-64.8561625821312 -40.8128357932066,
-64.8581695617895 -40.8092347767316,
-64.8528595674595 -40.7964787857779,
-64.8551634928013 -40.792892731,
-64.8582225437994 -40.792072653976,
-64.8664166252808 -40.7962226767266,
-64.879096575609 -40.8007127700525,
-64.8997725849562 -40.8080327363802,
-64.90958358585 -40.8156656662083,
-64.9105985169769 -40.8246227942446,
-64.9057766260141 -40.8301927700651,
-64.8948135744394 -40.8378596717468,
-64.8884126083569 -40.8392597345605,
-64.867393536095 -40.8381386633937,
-64.8090746007879 -40.8257447455112,
-64.8041916308967 -40.8254967333784,
-64.7841565102476 -40.8244818022514,
-64.741233513352 -40.8274267923112,
-64.710609559577 -40.8362577140315,
-64.6938785097194 -40.8391377527237,
-64.6452945346806 -40.854224776094,
-64.6346585282037 -40.857520749967,
-64.6182474826452 -40.8599397923669,
-64.6057435522836 -40.8639988127948,
-64.5850605021378 -40.8707127423778,
-64.5398786410119 -40.8803707819207,
-64.5144425237101 -40.8920747015345,
-64.4897916314789 -40.8932346731139,
-64.4687426358227 -40.8998567202743,
-64.432044585043 -40.9081687351332,
-64.4180985230957 -40.9140817738685,
-64.3936234748112 -40.929225651688,
-64.3796156298556 -40.9360467774305,
-64.3595046446009 -40.9437907758576,
-64.346061471698 -40.9465067639409,
-64.3424145140117 -40.9477767479994,
-64.3293915007688 -40.9523087340773,
-64.3073194770671 -40.9622607269644,
-64.2818905765839 -40.9773488064545,
-64.2583315362051 -40.9867787241208,
-64.2316286032043 -41.0024987152907,
-64.2198106226522 -41.0075497842499,
-64.2022475264129 -41.0128407684235,
-64.2015385179878 -41.0129546533418,
-64.1848375675445 -41.0156176594153,
-64.1550065837186 -41.0144847949108,
-64.1406174795156 -41.0173687060422,
-64.1368335782954 -41.0151637039217,
-64.1345826349635 -41.0038526608731,
-64.1264955736218 -40.998275644254,
-64.1141285867941 -40.9936787068083,
-64.1054536187642 -40.9924277329063,
-64.0999676044677 -40.993133748992,
-64.0886535690797 -40.9995648144887,
-64.074325543805 -41.0015256769158,
-64.0732345720526 -41.0042307517612,
-64.0751114729556 -41.0077397097938,
-64.0944215673626 -41.0080297906986,
-64.0990904969745 -41.0105018151084,
-64.0986175313245 -41.0130048190323,
-64.0884705083145 -41.0199396536732,
-64.0870815347587 -41.022632759161,
-64.0907436301622 -41.0287707514134,
-64.091422539173 -41.0298997434787,
-64.0903095649247 -41.0328327641808,
-64.0597535548568 -41.0465316940951,
-64.0238035889349 -41.0549697392501,
-63.9591445904537 -41.0801196480863,
-63.9472546177353 -41.0865936624549,
-63.9336665803999 -41.0939866770687,
-63.9118995993002 -41.1107446579811,
-63.8963624928755 -41.1291276552245,
-63.8899495574353 -41.1341357753119,
-63.8714755578693 -41.1384276701555,
-63.8250355060227 -41.1525606653073,
-63.8150826330358 -41.1562537402248,
-63.8016896258233 -41.1612206716401,
-63.7836225844199 -41.1639056802093,
-63.7603376071289 -41.1633946942465,
-63.7248725762148 -41.1596187139248,
-63.6715735543328 -41.1635517040567,
-63.6511224985028 -41.1631737891885,
-63.5578345565472 -41.1614037324052,
-63.5188714808384 -41.1638217186853,
-63.4848285152337 -41.1635587448553,
-63.4810215553978 -41.163528645441,
-63.4692804955711 -41.166446704446,
-63.4419475871101 -41.1672896640657,
-63.382030566527 -41.1625367729297,
-63.3607134924617 -41.1638637874573,
-63.3254315223127 -41.1617967849905,
-63.3195265804959 -41.1620296594062,
-63.3011164761777 -41.1627467647498,
-63.2902835033583 -41.161788688072,
-63.2557635236443 -41.165237799316,
-63.1535455607273 -41.1622577812828,
-63.1520764980867 -41.1622157125108,
-63.0951845566482 -41.1576766856342,
-63.0644495342743 -41.1520727379601,
-63.0439104684611 -41.1442067576963,
-63.0268405801679 -41.1312367264633,
-63.0181425535224 -41.126685730229,
-63.0028305766349 -41.1215897761783,
-63.0014875442904 -41.1209606808179,
-62.9635355272692 -41.1031647101629,
-62.9241146236275 -41.0934297498946,
-62.9041175232912 -41.0901446892595,
-62.8872945910111 -41.0851818063035,
-62.8560336209773 -41.0723916674763,
-62.851161564324 -41.0696376590801,
-62.8306656234025 -41.0580516728439,
-62.8125035312171 -41.0445287628961,
-62.8024105463369 -41.0355376630063,
-62.7984615383881 -41.0289187842053,
-62.7988505425141 -41.0245857006895,
-62.7904246427368 -41.0207176619252,
-62.7788925186103 -41.0279277917938,
-62.7521784963516 -41.0357326931292,
-62.7085345216732 -41.0332677095181,
-62.6965825899266 -41.0282937373042,
-62.681102513971 -41.0155757666633,
-62.6715734970636 -41.0139347325154,
-62.6440846349122 -41.000835678647,
-62.632167555119 -40.9951477694489,
-62.5993915812333 -40.983344750594,
-62.513015591323 -40.9469036889654,
-62.4972915516939 -40.942626755819,
-62.4511565424492 -40.9300576980697,
-62.4243655994652 -40.9258617341079,
-62.4056126082522 -40.9197957340217,
-62.3858754894064 -40.9113847959415,
-62.3477175290244 -40.8913577722109,
-62.3267095460204 -40.8829197270559,
-62.3190655269344 -40.8776817248922,
-62.3134195104883 -40.8704907812,
-62.3024555788137 -40.8403056452015,
-62.2760925403683 -40.7918397795603,
-62.2735256411965 -40.7843397448069,
-62.2725675645188 -40.7815547568966,
-62.2651976085206 -40.7705957537811,
-62.2555156302622 -40.7462117078192,
-62.2367515497914 -40.7100786811321,
-62.2315404786826 -40.6864017073757,
-62.2253375350624 -40.6759647794809,
-62.2154385241853 -40.6683006941187,
-62.2004476077168 -40.656680736029,
-62.1932184676918 -40.6475597334039,
-62.1766775193981 -40.6383667386125,
-62.1709135695745 -40.6327666633777,
-62.1707915877377 -40.6279447724149,
-62.1750834825813 -40.6240617719534,
-62.1688726180627 -40.6138497975759,
-62.1695675448905 -40.6067847081597,
-62.1732525228896 -40.5998836693524,
-62.2170485788191 -40.5700377238294,
-62.2259595896241 -40.5618286806508,
-62.2357975215728 -40.5564227554391,
-62.2694055418402 -40.5443266633399,
-62.2778476354544 -40.5418667843078,
-62.3036995119171 -40.5343208083431,
-62.3118395552688 -40.5214768074062,
-62.3173635898781 -40.5201797162729,
-62.3195645435394 -40.5097577500753,
-62.3275834851542 -40.5012626744512,
-62.3375476234189 -40.4974597630745,
-62.3536455294569 -40.4985806582213,
-62.361278635305 -40.4971658097304,
-62.3716925045841 -40.4917827671143,
-62.3819615094309 -40.481574665176,
-62.4049305308819 -40.470229650274,
-62.4139974953773 -40.4599537806485,
-62.4166186086987 -40.4561577340506,
-62.4202495485681 -40.4508966732713,
-62.4236256115259 -40.4373316945515,
-62.4517324797797 -40.3996738068944,
-62.4529116375354 -40.3839267086497,
-62.4655535675508 -40.3639868148025,
-62.4776806391641 -40.3495216699739,
-62.481597611479 -40.3426936794527,
-62.484825641645 -40.3370747700815,
-62.4905624843938 -40.3140106978485,
-62.4883495613747 -40.3056448208798,
-62.4795876394813 -40.2937127793894,
-62.4549444921287 -40.2694588121827,
-62.4545025059928 -40.261413643593,
-62.4476856047294 -40.2543987198673,
-62.4362224804298 -40.2459796848687,
-62.4233355306211 -40.240005743225,
-62.420165587044 -40.2390747736221,
-62.393684615221 -40.231273744726,
-62.3880424712142 -40.2277566897749,
-62.3757474765528 -40.2156176488039,
-62.3545265093893 -40.2032166901227,
-62.3468585515878 -40.1959187262909,
-62.3443645246822 -40.1907388107161,
-62.3480304925249 -40.1836087699323,
-62.347099522922 -40.1808047718657,
-62.335838469544 -40.1705586496146,
-62.3318486249629 -40.1623158106025,
-62.3319206171292 -40.1474306821338,
-62.3319625098812 -40.1391797462032,
-62.3439295793449 -40.0823326898561,
-62.343387613868 -40.0692406767864,
-62.3363605447647 -40.0365447919855,
-62.3363686416831 -40.0229757648065,
-62.3363765625816 -40.0019496517459,
-62.3316074776087 -39.9999997025568,
-62.3354725240336 -39.9876786569404,
-62.3298835380567 -39.9804996826059,
-62.3372265629999 -39.965541681871,
-62.3316615157385 -39.9581296571009,
-62.3276635742389 -39.9466777980792,
-62.3234744750557 -39.9436986601458,
-62.3188014969846 -39.942756777305,
-62.3192866080123 -39.9407196982324,
-62.324787584006 -39.9391856842242,
-62.3274115136469 -39.9365807647397,
-62.3262064809561 -39.9303246630897,
-62.3312184734827 -39.9179916481156,
-62.3303065140362 -39.9149586480725,
-62.3274954751709 -39.9132007366669,
-62.3254884955126 -39.90277472201,
-62.3167344945177 -39.9041286675925,
-62.3183024803795 -39.9000897134407,
-62.3180995293581 -39.8964427557544,
-62.3174176280078 -39.8839918074027,
-62.3228075354026 -39.877181770918,
-62.3244784929448 -39.8720016793234,
-62.3227885252462 -39.8677826567459,
-62.3182445698105 -39.8654667620464,
-62.3076134918927 -39.8646547819408,
-62.3050346233632 -39.8668057459317,
-62.3028144835255 -39.8779187665179,
-62.2925796265523 -39.8824007629253,
-62.2858584801507 -39.8811107125907,
-62.2748755383198 -39.8713336835504,
-62.270626592348 -39.875457655346,
-62.2615085820623 -39.8616557537513,
-62.2568165938348 -39.8609386484077,
-62.2504534720451 -39.8621906784295,
-62.2486605326662 -39.8591117371752,
-62.2299385209673 -39.8621977192282,
-62.2253956216514 -39.8598827046285,
-62.2209166175833 -39.8600918163487,
-62.2176364855073 -39.863349769909,
-62.2109185074651 -39.862056727235,
-62.2064326386184 -39.8654746829449,
-62.197917496718 -39.8643106629063,
-62.1954424799688 -39.8559187349825,
-62.1718024704054 -39.8637697535492,
-62.1671824743441 -39.8591538059472,
-62.1627884879199 -39.8584477898615,
-62.1495584751964 -39.8600008140261,
-62.1441954988565 -39.8602757572138,
-62.1346164922786 -39.8607636845609,
-62.1306076375411 -39.8591617268457,
-62.1265255584975 -39.8520547446775,
-62.1173366121654 -39.8517646637727,
-62.1138616259863 -39.8476716714912,
-62.1184194869994 -39.812385652883,
-62.1187555091155 -39.7896267992719,
-62.119178485095 -39.7608297567294,
-62.1107216058036 -39.7156338140062,
-62.1006245724642 -39.693958715329,
-62.1015395242501 -39.6905706830135,
-62.1100574824699 -39.6977047722565,
-62.1143794767278 -39.7052877124141,
-62.1214105942905 -39.70935764608,
-62.1224285177568 -39.7080387284709,
-62.118053541489 -39.7041207000361,
-62.1147684808539 -39.6949917765125,
-62.1109425108616 -39.6915627315448,
-62.108348504615 -39.6845356624414,
-62.1154676321609 -39.6720966834474,
-62.1159854829024 -39.6604267356872,
-62.112380593988 -39.6391218069996,
-62.1051745125787 -39.6182977648606,
-62.101345550247 -39.5962906925266,
-62.0985795724932 -39.5848926956146,
-62.0856206305181 -39.5561716936976,
-62.086940604247 -39.551658717776,
-62.0791626339665 -39.5431856446477,
-62.0793414702525 -39.5426097073172,
-62.0808635149029 -39.5377767270965,
-62.0675014872045 -39.5195806630576,
-62.066116562108 -39.5123897193654,
-62.0614625941932 -39.5084537368941,
-62.0563845941791 -39.4996717487245,
-62.0395315624847 -39.4470866638268,
-62.0416034935106 -39.4439927608752,
-62.0658984733695 -39.4373546958979,
-62.0734905665654 -39.4352648108354,
-62.0944026186877 -39.4206276944995,
-62.1162986224228 -39.4110907566936,
-62.1336135305093 -39.3999136648396,
-62.1525914752395 -39.3773577622499,
-62.1511495196738 -39.3738366588397,
-62.1519815660555 -39.3681447011824,
-62.157199501943 -39.3629338060935,
-62.1806414890441 -39.3555377991403,
-62.2091635883989 -39.3442957559187,
-62.216854604816 -39.3536756839145,
-62.2215115650702 -39.3543927892581,
-62.2328294728974 -39.3502117869934,
-62.2411194852605 -39.3499866574562,
-62.2485695303435 -39.3524667787845,
-62.2577625251349 -39.3520617568415,
-62.2653155418982 -39.3534007407268,
-62.2718506351951 -39.3466526632704,
-62.2769275790894 -39.3450207821608,
-62.2785455546217 -39.3445016992795,
-62.2833744863832 -39.3401797050216,
-62.280441641701 -39.333595678174,
-62.2759555968343 -39.331050781498,
-62.2721326191815 -39.3340487535678,
-62.2698475279762 -39.333232725003,
-62.264270511357 -39.3264997852637,
-62.2650715782246 -39.3210377096826,
-62.2727886455967 -39.3269727509137,
-62.275920568861 -39.3218727484038,
-62.2789614898026 -39.3208926692302,
-62.2889446382237 -39.3246617847733,
-62.2943195839213 -39.3240397302116,
-62.2971725155386 -39.3219037279179,
-62.2938195111964 -39.3134577618644,
-62.2910494849833 -39.3114697923625,
-62.2791595122649 -39.3092037113136,
-62.2796405748334 -39.3071638159216,
-62.2870485511443 -39.3036766843649,
-62.2924196244027 -39.3030548058232,
-62.2968486388003 -39.2998618036305,
-62.3133124903487 -39.3005447611006,
-62.3164785614864 -39.2981947185276,
-62.3149684861937 -39.2953567486074,
-62.3126635047321 -39.2947727143585,
-62.302890524151 -39.2951467567874,
-62.3014225176303 -39.2918546553536,
-62.2825665547369 -39.2979206554397,
-62.2617794767908 -39.2992856902801,
-62.2534445793362 -39.3063926724483,
-62.242042533965 -39.2988738035584,
-62.2365265962741 -39.2978787626877,
-62.2297325776064 -39.2979548033132,
-62.220287522223 -39.3010978158354,
-62.2143744834877 -39.3012236701115,
-62.2056386125494 -39.3062397110974,
-62.200015478699 -39.3063817592103,
-62.1906695225567 -39.3021847391287,
-62.1860315724588 -39.3044467717184,
-62.178565509559 -39.3110126685095,
-62.1757356365572 -39.3135037030757,
-62.1721615511371 -39.3263816758661,
-62.1579245281851 -39.3395727881771,
-62.1487695537065 -39.3521307566684,
-62.1414795107731 -39.3542447564663,
-62.1350635829935 -39.3596156537047,
-62.1292225364245 -39.362037688444,
-62.1170085109478 -39.3755686953102,
-62.0954705318245 -39.3876496496923,
-62.0862845778318 -39.3910257126501,
-62.0691145341777 -39.3944056480473,
-62.051532603802 -39.3959197717992,
-62.0348735461107 -39.3970297537081,
-62.0276565514635 -39.3952368143292,
-62.0100175906186 -39.385043674088,
-62.0119286393951 -39.3651887978846,
-62.0169145809667 -39.3624956923969,
-62.0231786035152 -39.3557437425012,
-62.0336796026778 -39.3540537748026,
-62.0472296197005 -39.3451957460075,
-62.0616076346456 -39.3268167972234,
-62.063377515409 -39.3245507161744,
-62.0984076009859 -39.3070486988635,
-62.1257515987048 -39.2957577220912,
-62.1382405673692 -39.2916487119927,
-62.1591455786929 -39.2921447362584,
-62.1854595075677 -39.2853697277471,
-62.1831395644089 -39.2912067258568,
-62.185089513598 -39.2924647405575,
-62.1879806415481 -39.2930867951192,
-62.1948244738663 -39.2893407381917,
-62.1964185106831 -39.2901997156283,
-62.2024116385032 -39.2934377789324,
-62.2048875353522 -39.2922017667275,
-62.2036555716066 -39.2896077604809,
-62.198059544831 -39.2863117866079,
-62.1925694820753 -39.2850836953015,
-62.1972926258369 -39.281905654806,
-62.2153475218626 -39.2813147557784,
-62.2233886419931 -39.290027744121,
-62.2258985106957 -39.2789266928926,
-62.2290195207221 -39.2802466666215,
-62.2332265739418 -39.2857587318731,
-62.2379685518399 -39.2855688063292,
-62.2396044814087 -39.2838248005009,
-62.2396356369428 -39.2771717738264,
-62.2414394895597 -39.2768137492145,
-62.2492986050448 -39.2811547536288,
-62.2504004900352 -39.2883266871646,
-62.2568475733489 -39.2792817251651,
-62.2516326298008 -39.2750898096624,
-62.2565384822877 -39.273067692287,
-62.2622605393593 -39.2749937027607,
-62.2631455677509 -39.2758907005101,
-62.2730524995265 -39.2859187340226,
-62.2921145818007 -39.2872087843572,
-62.2977334911719 -39.2838517315558,
-62.2963945072866 -39.2823978066323,
-62.283622498516 -39.2832948043817,
-62.2742915040709 -39.2820897716909,
-62.2699355379594 -39.2749637793664,
-62.2862055915247 -39.2777026500454,
-62.2871705329811 -39.2768398001695,
-62.2826885365737 -39.2678717588954,
-62.287197640056 -39.2669758172658,
-62.2915115373954 -39.2713437527349,
-62.3023105383613 -39.2726327469498,
-62.3078465423283 -39.2766116782929,
-62.3108216318024 -39.2763136764896,
-62.3224185312766 -39.2689287587943,
-62.3252565011968 -39.2648466797508,
-62.3288765278282 -39.2596477540197,
-62.3248095865018 -39.2525407718515,
-62.3165285511569 -39.2495577614789,
-62.309593540496 -39.2448157835808,
-62.3023225077191 -39.2437207633691,
-62.2982365562363 -39.2400547955264,
-62.2923854765292 -39.2459257654897,
-62.2819445001752 -39.2503928002,
-62.2760545200555 -39.2502937009589,
-62.2721785603928 -39.2475546542599,
-62.2676925155261 -39.2514346623819,
-62.2512966076847 -39.2532726628723,
-62.2458035525896 -39.2552608083941,
-62.2420115544509 -39.2548177661384,
-62.2414706450937 -39.2511176504222,
-62.2428555701903 -39.2488976866044,
-62.2527964738194 -39.2434887690533,
-62.2587165533534 -39.2337226532509,
-62.2619016346475 -39.2343596695097,
-62.2685166410093 -39.2392887566321,
-62.2715565058311 -39.2415546616612,
-62.273738625356 -39.2370878029708,
-62.2864794785926 -39.2364198071979,
-62.2907755979154 -39.2378047322944,
-62.2919125108792 -39.231902782817,
-62.2982824974475 -39.2267497982972,
-62.3024525864743 -39.2295038066934,
-62.3048624758359 -39.2289507519585,
-62.3058284734122 -39.2248727213742,
-62.3040466232911 -39.2217907877804,
-62.3129764682326 -39.2144847270301,
-62.3190114888046 -39.2065587239578,
-62.3297156150086 -39.1862717187366,
-62.3345336335322 -39.1851617368277,
-62.3463405248264 -39.1624067556559,
-62.3424876237792 -39.1594427554397,
-62.345611626145 -39.156959641772,
-62.3478886204319 -39.1551517406959,
-62.3424876237792 -39.1530146822824,
-62.3341555426441 -39.1378708044629,
-62.3483005071536 -39.1280976478619,
-62.3479655411573 -39.1189007806312,
-62.3573345559152 -39.1033517048488,
-62.3563264895669 -39.101463714688,
-62.3468096180371 -39.0961186923846,
-62.3424145754931 -39.095874728711,
-62.3404695548631 -39.0849797968634,
-62.3383786136808 -39.0821117275289,
-62.3320616091224 -39.080386731857,
-62.3250575986346 -39.0733417087171,
-62.3183214905359 -39.0729676662882,
-62.3098676035839 -39.0621107547533,
-62.3067436012181 -39.0580976755366,
-62.3049504858192 -39.0423926460639,
-62.2999194831362 -39.0299487385109,
-62.3009835238338 -39.0279428149724,
-62.3119775549226 -39.0299297283545,
-62.3177686118211 -39.0277287746931,
-62.3106426194965 -39.0220526588328,
-62.3064844998274 -39.0225106627857,
-62.3119395346098 -39.0111087934344,
-62.3169745857521 -39.007488766803,
-62.3095625609819 -38.9953687359884,
-62.3125496198138 -38.9948466607677,
-62.3172305187834 -38.9983216469467,
-62.3228075354026 -38.9984017360315,
-62.3244556103491 -38.9964257358873,
-62.3198204765708 -38.9860727695166,
-62.3215755716569 -38.9797437956004,
-62.3243336285123 -38.9785197527532,
-62.324356511108 -38.9718626776195,
-62.3329586068717 -38.9645386628326,
-62.3403285628699 -38.9610446664972,
-62.3455046060054 -38.9526097897016,
-62.3439595027393 -38.943801750577,
-62.336337486149 -38.9371837518758,
-62.3355445161999 -38.9265827733722,
-62.3271974733676 -38.9086757341183,
-62.3228795275689 -38.9077456446152,
-62.3322485423268 -38.8855437181783,
-62.3387795871645 -38.8879698013768,
-62.3418655692175 -38.8863067647331,
-62.3416596258567 -38.875934788206,
-62.3415485572579 -38.8704487739095,
-62.350227573747 -38.8718486607032,
-62.3541676046776 -38.8736768040755,
-62.3497885799505 -38.8766437966311,
-62.3521685459178 -38.8795317562218,
-62.368186538891 -38.8808747885663,
-62.3878704997069 -38.8968808121818,
-62.3902705319504 -38.8963237089878,
-62.385982509546 -38.8820877421556,
-62.3826405944617 -38.8768537884512,
-62.3761785494509 -38.8801687724806,
-62.3715435916925 -38.8762437032472,
-62.3703116279468 -38.8704338122123,
-62.372581581435 -38.8648226477196,
-62.3816105256176 -38.8655506663012,
-62.3752665900043 -38.8578566575446,
-62.3774944747205 -38.8559118129346,
-62.380672515216 -38.8568957645474,
-62.3883436413769 -38.8592646412568,
-62.3963666314509 -38.8548847364299,
-62.4043155171189 -38.8383367473375,
-62.3983535448329 -38.8361738139889,
-62.3896174978746 -38.8354648055638,
-62.396076550546 -38.8321457730751,
-62.3930125709888 -38.8303716678326,
-62.3871956391553 -38.829822661557,
-62.3793294828715 -38.8163038000684,
-62.3803065697057 -38.8119967675077,
-62.3762165697636 -38.8053437408332,
-62.3703806277737 -38.8018076757258,
-62.365463510009 -38.8010747285852,
-62.3565864710575 -38.8051756417651,
-62.3496665981137 -38.8006587934043,
-62.3429185206573 -38.8007468033875,
-62.3321415221872 -38.8063426541432,
-62.3300785681796 -38.8059576984764,
-62.326953509694 -38.8053667994488,
-62.3234744750557 -38.8081586521377,
-62.3044924818663 -38.8009038131977,
-62.3000756128464 -38.7979007365489,
-62.3000145339181 -38.7953716816699,
-62.3180386264497 -38.7874257883413,
-62.340869472227 -38.7749216819598,
-62.3612976454614 -38.7597536894049,
-62.4041326323737 -38.7527086662649,
-62.4028776100124 -38.7503436619948,
-62.3952974861742 -38.7499277268139,
-62.3632204875756 -38.7559356403111,
-62.3574445683943 -38.7570186911651,
-62.3498456104197 -38.7600407779703,
-62.3432195148 -38.7555387152866,
-62.3438494902602 -38.7615438124644,
-62.3401185710498 -38.7670747118523,
-62.3263096286565 -38.7738836922172,
-62.316375589806 -38.7831997249652,
-62.3088114837848 -38.7857627516977,
-62.3003956171456 -38.7848317820948,
-62.2955814710613 -38.7893866507684,
-62.2791595122649 -38.7925986631174,
-62.2709085763343 -38.7962686794193,
-62.2660595782967 -38.7954177989012,
-62.2651365295922 -38.7952577967516,
-62.2584875513769 -38.7974087607425,
-62.2541576362205 -38.7934917884275,
-62.2435115966055 -38.794498798656,
-62.2375795477139 -38.7888827056042,
-62.2350735514505 -38.7937927825703,
-62.2317164986491 -38.7952116795204,
-62.2303775147638 -38.8001856517343,
-62.2133106188101 -38.8008307649116,
-62.1929394760449 -38.8086277453485,
-62.1835745097462 -38.8201746551522,
-62.1833305460726 -38.8204807538739,
-62.1788906184371 -38.8209186915506,
-62.1713946321429 -38.8163606545176,
-62.1678085773651 -38.817073711402,
-62.1507145743365 -38.8273508131672,
-62.1429135454404 -38.8292007830153,
-62.1413846360112 -38.8320387529355,
-62.1340335141494 -38.8456806523806,
-62.111518624212 -38.86666064821,
-62.1095885652791 -38.8716006485704,
-62.1108134882261 -38.8803937259978,
-62.1040226379178 -38.8839077886094,
-62.1010515969029 -38.8874126981828,
-62.1038015568399 -38.8956027312049,
-62.1030004899722 -38.8978536745368,
-62.0914916004814 -38.901553790253,
-62.0852395472906 -38.905559652651,
-62.0837636198713 -38.9079436670775,
-62.0772705953463 -38.9184147428458,
-62.0726696094415 -38.9142457099388,
-62.0671005137208 -38.9125826732952,
-62.0573655534525 -38.9142337405811,
-62.0409854874082 -38.9170116876927,
-62.0321045760174 -38.9146577726805,
-62.0307156024616 -38.916873688039,
-62.0362964915201 -38.9199528053133,
-62.0437856130356 -38.921531704413,
-62.0643725562797 -38.9181327588595,
-62.0686684995826 -38.9192967788981,
-62.0555645171551 -38.9304766870715,
-62.0440595001035 -38.9371606932602,
-62.0294225597876 -38.9427417583386,
-61.9999995902441 -38.9497566820643,
-61.9989505112437 -38.947055655678,
-61.942653517292 -38.9610367455987,
-61.9324836116864 -38.9644777599242,
-61.8938715197908 -38.9775236557627,
-61.8803176303289 -38.9742737991208,
-61.874339640226 -38.9769327567351,
-61.8661305970474 -38.9759176495882,
-61.8556934931327 -38.9771346516367,
-61.8343396308944 -38.9861447616829,
-61.8119014856624 -38.9892956951035,
-61.8045956009321 -38.9922368127241,
-61.7815706051317 -38.9868467293093,
-61.7725335640306 -38.984729737172,
-61.7562406278697 -38.9780277769468,
-61.7135505053898 -38.9755247730229,
-61.7014765918064 -38.9766116963162,
-61.6939165342444 -38.9797707266553,
-61.6720465814643 -38.9953227947771,
-61.6459465168488 -39.0060346658596,
-61.6356234738724 -39.0086937994938,
-61.6324575787546 -39.0095096520386,
-61.5729105521411 -39.0123057292068,
-61.5604015172004 -39.0146677411375,
-61.5541874843224 -39.0147897229743,
-61.5440175787168 -39.0098456741547,
-61.5216105890189 -39.0104106982472,
-61.4918095285873 -39.0005988172535,
-61.4792404708381 -39.0009837729203,
-61.4729236422996 -39.0011788030432,
-61.4646075789814 -38.9957088065637,
-61.457549530364 -38.9938928085691,
-61.4557535986456 -38.993430756157,
-61.4259606351325 -38.9960557419177,
-61.4034466252949 -38.9890057902187,
-61.3896785195338 -38.9893076644612,
-61.3745846313848 -38.9867166505541,
-61.340137523937 -38.9918897013501,
-61.3238864805281 -38.9928477780279,
-61.3102685197984 -38.9936486688755,
-61.2900045731928 -38.9906807962201,
-61.2812614854358 -38.992820670953,
-61.2557334857115 -38.9947667477029,
-61.2479625562297 -38.9924196974693,
-61.2371065247946 -38.9919206808642,
-61.2074695149719 -38.9997597300732,
-61.2006835932226 -38.9994736976276,
-61.1661685420678 -39.0039637909535,
-61.1531376079264 -39.003356698089,
-61.1443366096004 -39.0048556841238,
-61.13797753627 -38.9998966736071,
-61.1244695880193 -38.9967767197005,
-61.1137735587338 -38.9916158142822,
-61.091823516869 -38.9910236831148,
-61.0851785871129 -38.9895627173927,
-61.0574075649553 -38.9834516561951,
-61.0320775876933 -38.9844966867363,
-61.0115246163027 -38.9840087593892,
-60.9743805309279 -38.983115810099,
-60.940128629623 -38.9875337352387,
-60.9072796074512 -38.9823756461398,
-60.8904306242161 -38.9846686582436,
-60.8637046325996 -38.9817358135615,
-60.8521075571055 -38.9820827489155,
-60.8284075247335 -38.9762536717043,
-60.8075065618691 -38.9681776996204,
-60.7896345505886 -38.9677617644395,
-60.7724264866217 -38.9654157703257,
-60.7580035865851 -38.9606097211599,
-60.7349395143521 -38.9593777574142,
-60.7144245632743 -38.9561236762932,
-60.6975326311673 -38.9505767590883,
-60.6953005219719 -38.9498446920475,
-60.6772616437631 -38.9506837792279,
-60.6453626013506 -38.9433057263113,
-60.6123465362307 -38.9425127563621,
-60.596099541281 -38.9384077947229,
-60.5835266110925 -38.9400407319523,
-60.5749285637879 -38.9370577215797,
-60.5589375018696 -38.9363136851813,
-60.5409855775243 -38.9310107316499,
-60.5246965138026 -38.9298556886296,
-60.5177345720869 -38.9270057493517,
-60.5154456084422 -38.9216237628554,
-60.5071564761789 -38.9264298120213,
-60.4744415812216 -38.9222107894438,
-60.4537775412322 -38.9239806702071,
-60.4463084859929 -38.921573773185,
-60.3924525369368 -38.9161676719533,
-60.382804530532 -38.9134326737135,
-60.3727984995153 -38.9132427481696,
-60.3590316258939 -38.9102477684393,
-60.3316615772199 -38.904292660932,
-60.3101616184095 -38.9056547034329,
-60.2932056150347 -38.8987997818568,
-60.2773745552659 -38.8963237089878,
-60.2734146340791 -38.8937527613568,
-60.258079598576 -38.8906206620726,
-60.2455365917818 -38.8926427794479,
-60.2301825461223 -38.8930926864824,
-60.2247885902683 -38.8893167061606,
-60.2059665992285 -38.885234803137,
-60.2020455784543 -38.8843837465989,
-60.1956025435998 -38.8848727300659,
-60.1854856200042 -38.8829836837852,
-60.1787495119055 -38.8792647339326,
-60.1711274953153 -38.8783226750718,
-60.1456565260601 -38.8806727176448,
-60.105522565534 -38.8699187777903,
-60.088909625074 -38.867664666099,
-60.0779875861515 -38.8617936961358,
-60.0688016321587 -38.8655547147604,
-60.0628695832671 -38.8655886866139,
-60.0495835961942 -38.8606606556113,
-60.0394055936702 -38.861713783071,
-60.0268595945365 -38.8597027549535,
-60.0221176166385 -38.8613777609549,
-59.9999994757056 -38.85583066773,
-59.994682616597 -38.8544957323039,
-59.9902495537402 -38.8567846959485,
-59.9856184684211 -38.8561327179926,
-59.9644585801859 -38.8502506587714,
-59.9240915692241 -38.8476827034798,
-59.9200404696947 -38.8474237781091,
-59.9012035169577 -38.8439678020864,
-59.8931044862582 -38.8438716951847,
-59.8865315486685 -38.8464586606327,
-59.8744505942864 -38.8431477250624,
-59.8617935265539 -38.843444670746,
-59.8340415145526 -38.8354876881595,
-59.7842715169794 -38.833034673906,
-59.7698285506666 -38.8256187766966,
-59.7625235460361 -38.8218686713099,
-59.7249225128282 -38.8113176824768,
-59.7074886152444 -38.808414761189,
-59.6926265453913 -38.803504684223,
-59.6784324713111 -38.8006816759999,
-59.6435815740602 -38.7906337522312,
-59.6308095652895 -38.7845878184212,
-59.616386489233 -38.7866138082358,
-59.6026264803903 -38.7862967962761,
-59.558639618817 -38.7763638135455,
-59.5239145758421 -38.7723957954402,
-59.5137406217773 -38.7689776637104,
-59.4739984816967 -38.7626837177676,
-59.4511945669742 -38.7590677395954,
-59.4396555780691 -38.7552757414566,
-59.4296375776946 -38.7543757513678,
-59.4210854716013 -38.7508926682703,
-59.4082985011335 -38.7532617209997,
-59.3997955046109 -38.7506177250826,
-59.391719532527 -38.7507016866067,
-59.3727225776404 -38.7435876636398,
-59.352531503301 -38.7390437082041,
-59.3468015253309 -38.7331347179281,
-59.3447646222783 -38.7351077257328,
-59.3356665022489 -38.73606879475,
-59.3278466392163 -38.7341767561299,
-59.2619555009695 -38.7182386762215,
-59.2206615688641 -38.7114677161694,
-59.1978536056824 -38.7126887666771,
-59.1918905772766 -38.7114147341595,
-59.1613546334849 -38.704887737781,
-59.1022686031637 -38.697211683061,
-59.0900116288151 -38.6944657715833,
-59.0682525686139 -38.6852947792878,
-59.0545995799109 -38.6815378091224,
-59.0377924894277 -38.6791497462366,
-59.0194855328099 -38.6789207442602,
-59.0026545036114 -38.6710466670779,
-58.9834676231809 -38.6643028141007,
-58.9396205214611 -38.653938758472,
-58.9258235484255 -38.6472207804298,
-58.8872375074849 -38.6393276930912,
-58.8866885012093 -38.6392176806121,
-58.8688925305543 -38.6330416680469,
-58.8572195904547 -38.6308896479362,
-58.8297346007426 -38.6191177846153,
-58.8143235246139 -38.6172866489036,
-58.8079334717694 -38.6132737457069,
-58.7826075429667 -38.6066937673185,
-58.7410585579297 -38.5898396795043,
-58.7285725816047 -38.5847697764087,
-58.7202456050486 -38.5793348079025,
-58.7167815321075 -38.5745926539845,
-58.7120626128251 -38.5768467656757,
-58.7037696081225 -38.5775256746866,
-58.6517606365751 -38.568580692028,
-58.6415905549496 -38.5693127590688,
-58.6267855155657 -38.5652157183281,
-58.5969504832806 -38.5569577415988,
-58.5912435639262 -38.5571286569863,
-58.5854185351741 -38.5573046769529,
-58.5680656067748 -38.5538177214161,
-58.4993595572235 -38.5372927909393,
-58.439407508667 -38.517947668559,
-58.4256974894948 -38.511596692147,
-58.4116665859236 -38.5098877142921,
-58.4045715731132 -38.5073507385146,
-58.3916895518635 -38.5072937080455,
-58.3724445848441 -38.4970857821271,
-58.3612894954859 -38.4936067474889,
-58.3527255960548 -38.4940607029825,
-58.3282054866588 -38.4856796882967,
-58.2911685974436 -38.4761357096921,
-58.2883184821457 -38.4754027625515,
-58.2544365748105 -38.4611507779024,
-58.2474285158635 -38.4602888081263,
-58.2368696061319 -38.4568557146993,
-58.211528539612 -38.4486116435474,
-58.1963955750305 -38.445853762712,
-58.1309085786268 -38.4187127160145,
-58.1119806235671 -38.4062497983051,
-58.1099666031102 -38.4049266562168,
-58.0708236349956 -38.3913956493505,
-58.0603824826216 -38.3851277543628,
-58.0481874673013 -38.3816446712653,
-58.0036845151862 -38.3608547769997,
-57.9896205198613 -38.3506656852178,
-57.9850045722593 -38.3490976993561,
-57.9739265796465 -38.3398856944083,
-57.9562754734239 -38.3335797791077,
-57.947784622279 -38.3287316611699,
-57.9378394941706 -38.3277126815837,
-57.9253575663048 -38.3233868148865,
-57.9127195087287 -38.315051741412,
-57.9041705709948 -38.3154717250521,
-57.9021375403815 -38.3147586681677,
-57.8564265632362 -38.2987137441396,
-57.841323522049 -38.2885357416156,
-57.8350065174906 -38.2703437260359,
-57.8208384943655 -38.2704697563319,
-57.7963375711458 -38.2590367314466,
-57.7869984797822 -38.2525097350681,
-57.7769815355275 -38.2491607791851,
-57.765197526829 -38.2485927627532,
-57.7596095969719 -38.2421877482115,
-57.7528386369198 -38.2398146470229,
-57.7407724682149 -38.2388347438693,
-57.731208599354 -38.2331507071104,
-57.7215535521505 -38.2291446686924,
-57.710037621861 -38.2243616781422,
-57.7069125633754 -38.2193716881113,
-57.7003515951434 -38.2153058029047,
-57.6841625107627 -38.2110367906567,
-57.6755635833583 -38.2023776644238,
-57.643211641572 -38.1792827886967,
-57.6372565340647 -38.1770976768323,
-57.6262964748294 -38.1693307958097,
-57.6077805825114 -38.1456066487022,
-57.599449557496 -38.1349217086746,
-57.5873566337562 -38.1250688150288,
-57.5756375764253 -38.1181566869635,
-57.5515895525795 -38.1096156701281,
-57.5479355540946 -38.0964087160202,
-57.5407636205587 -38.0896076565539,
-57.5387455516426 -38.0852207109283,
-57.5416145010769 -38.067867782529,
-57.5401875072083 -38.0573537578889,
-57.5331424840683 -38.0464857570961,
-57.5306165975488 -38.0425877949375,
-57.5252955139609 -38.0273097899036,
-57.5308535204237 -38.0183297792717,
-57.541713600318 -38.0086057322413,
-57.5475535907672 -38.0002556970695,
-57.5532265382681 -37.9792517625247,
-57.5422555657949 -37.9468007214973,
-57.5342065247659 -37.9372746969292,
-57.5306706356785 -37.9311977836051,
-57.5274195468969 -37.925609677728,
-57.5289576093643 -37.9160877016192,
-57.5266915283154 -37.9043278076561,
-57.5216064875026 -37.8964197586203,
-57.515453533553 -37.8868527214,
-57.5100975980117 -37.8700947404876,
-57.4903675199646 -37.8371927363059,
-57.4744915751044 -37.8155977267135,
-57.4557834689829 -37.7965888024692,
-57.4445386094418 -37.7860677370304,
-57.4300465335583 -37.7654917070242,
-57.4215394885764 -37.7576137574027,
-57.4104044654944 -37.7511217889975,
-57.4082415321458 -37.7484357243084,
-57.4097595283371 -37.7474216732813,
-57.4124485853656 -37.7477497744989,
-57.4182774865569 -37.7513236838991,
-57.4223065835905 -37.7516216857024,
-57.4239696202342 -37.7513127706612,
-57.4273264970157 -37.7516287265011,
-57.4300345642006 -37.7523578012024,
-57.4318614754331 -37.752044661682,
-57.4332884693017 -37.7459027969902,
-57.4245914987759 -37.7417408048819,
-57.4213634686099 -37.7447396570514,
-57.4166714803824 -37.7445907441598,
-57.4106214981132 -37.7396966850107,
-57.4069065967198 -37.738727695095,
-57.4024425543489 -37.7401657782215,
-57.3994445822791 -37.7393377802989,
-57.3681836122453 -37.7167776532301,
-57.3542785629502 -37.70352968647,
-57.3473775241428 -37.696952700421,
-57.3387226223891 -37.6834146527561,
-57.2934765139754 -37.6448787775061,
-57.2690965164727 -37.6282727018247,
-57.2621495364541 -37.6178586565256,
-57.2497865980857 -37.6105427386571,
-57.2435185270779 -37.6068347020424,
-57.2095146379058 -37.5777477546151,
-57.1916315373674 -37.5645867417185,
-57.1853025634512 -37.558669654524,
-57.1622126162832 -37.5370867903093,
-57.155841573595 -37.5275037352721,
-57.1420894856508 -37.5191876719539,
-57.13993852166 -37.5178867083813,
-57.1116445441818 -37.4914097850175,
-57.0662345611792 -37.429370667718,
-57.063659565089 -37.4224587156727,
-57.0578725566498 -37.413509684555,
-57.0526046310918 -37.4053576718456,
-57.0408405126495 -37.3718147789658,
-57.0358464741594 -37.363254751974,
-57.0199626084007 -37.3428607266131,
-56.9914285396881 -37.2999687092317,
-56.9833444706858 -37.287811714224,
-56.957782499108 -37.2595598055179,
-56.9285434704296 -37.2212407868666,
-56.9147334719164 -37.2075497778507,
-56.9066045178226 -37.1971667120657,
-56.9048194993421 -37.1948817968803,
-56.8871995486536 -37.172355641665,
-56.8712845273608 -37.1580617642639,
-56.8575215261787 -37.1348686693955,
-56.8404196022517 -37.1146816435153,
-56.8261945486574 -37.0933957249841,
-56.8210255463206 -37.0888827490625,
-56.8181226250328 -37.0863496457243,
-56.8079685612242 -37.0696337335838,
-56.8015095085528 -37.0638317634474,
-56.7889635094192 -37.0458826554216,
-56.7840726186295 -37.0404277966591,
-56.7727395730851 -37.0277867467436,
-56.7669485161867 -37.0166927363138,
-56.7477646280956 -36.9954717691502,
-56.7379765097974 -36.9825017379173,
-56.7320215783101 -36.9746167474971,
-56.6981166123592 -36.9409527528803,
-56.6712915215016 -36.9054866658464,
-56.6690324812513 -36.8985557036447,
-56.6723634830978 -36.8737986713738,
-56.6757694694499 -36.8484496839554,
-56.6759495378757 -36.8100467037801,
-56.6732215804345 -36.7592357241249,
-56.6753155139562 -36.747600804338,
-56.6707685661811 -36.7204477882828,
-56.6734695925674 -36.7123906503353,
-56.6778144694209 -36.6730767668332,
-56.6760296269604 -36.6520047125614,
-56.6783066212473 -36.6369858089181,
-56.6777834899068 -36.6228746402422,
-56.6776275362165 -36.6186406559676,
-56.6799884920274 -36.6074216713615,
-56.6806026256906 -36.5884206680157,
-56.678565546618 -36.5563737688314,
-56.6837465183126 -36.5311847835626,
-56.6900784845682 -36.5222287116462,
-56.688381476071 -36.4987717628479,
-56.6870264743687 -36.4800677051856,
-56.6901545251937 -36.4454157104968,
-56.7047536212168 -36.3875806540777,
-56.7106555706942 -36.3748897905116,
-56.719173528914 -36.3565486860203,
-56.7368165382181 -36.3301087268494,
-56.7487445312493 -36.3162077260136,
-56.7564695195199 -36.3120767134193,
-56.7749095472324 -36.2980646439846,
-56.7832455008068 -36.2979357973691,
-56.5694445360946 -36.1433179331469,
-56.5590170637134 -36.1534088069065,
-56.5470890706822 -36.1673098077424,
-56.5288634071268 -36.1913445554315,
-56.5112203978226 -36.2177845146024,
-56.4924328352558 -36.2512459897612,
-56.4839424133307 -36.2695278023374,
-56.4780680311564 -36.2821593883911,
-56.4623570173181 -36.3263933480545,
-56.447757921295 -36.3842284044736,
-56.4411669360181 -36.4229394911411,
-56.4380388851931 -36.4575914858299,
-56.4377864651103 -36.4860990833574,
-56.4336916977329 -36.5060071317372,
-56.4290690937061 -36.5722331504202,
-56.4303460061754 -36.5923212686097,
-56.4301189716369 -36.5993456092145,
-56.4302333560857 -36.5993493062477,
-56.4290400869538 -36.6133045126978,
-56.4288541714897 -36.6145307987968,
-56.4288032437969 -36.6160743783237,
-56.4277969548612 -36.6278428632954,
-56.4279529085516 -36.6320768475701,
-56.4279551060565 -36.6321363151852,
-56.428123469431 -36.6366778209082,
-56.4271907605116 -36.6649475169052,
-56.4252287679979 -36.6827002743977,
-56.4215437851943 -36.7007752556018,
-56.4242017367066 -36.7617369951398,
-56.4242443518258 -36.7619914799223,
-56.4235811081915 -36.7726385080996,
-56.4259180911826 -36.8161671912907,
-56.4258478570651 -36.8311459384512,
-56.4245930901643 -36.8404845167931,
-56.4212650991949 -36.8652191712979,
-56.4200593232145 -36.9211912194805,
-56.4313393482402 -36.976028114988,
-56.4335983884905 -36.9829590771896,
-56.4496951028815 -37.021223553893,
-56.471901760208 -37.056296887951,
-56.4987268510656 -37.091762974985,
-56.5219714763321 -37.1183587591315,
-56.5432339676381 -37.13947013243,
-56.5482130163653 -37.1460677659623,
-56.5623109843116 -37.1631230322151,
-56.5726882871563 -37.1746022694723,
-56.5865949473197 -37.1946704736275,
-56.5927238892517 -37.2015067878899,
-56.5966030199159 -37.2070565200872,
-56.6040406588655 -37.2154602494267,
-56.6044547680466 -37.2161419678813,
-56.6268479255419 -37.2473278719993,
-56.6316340199629 -37.2522002687586,
-56.632562383166 -37.2535894419788,
-56.6496690221998 -37.2762805798046,
-56.6532222485106 -37.2804747904561,
-56.6562887048392 -37.2856423125393,
-56.6780417314969 -37.3166720471799,
-56.7035461919733 -37.3433374753388,
-56.7078572701097 -37.3488489558737,
-56.7095954332603 -37.3510738938342,
-56.7097565793852 -37.3512799468411,
-56.717885533479 -37.3616630126261,
-56.7387232895573 -37.3850896767634,
-56.7402699015831 -37.3866229628944,
-56.7590335995457 -37.4112136050838,
-56.7724009075431 -37.4272907373965,
-56.7854789119905 -37.4417449662725,
-56.8118143828269 -37.4813320817394,
-56.8167031504267 -37.4881171144146,
-56.8426309964466 -37.5410450800818,
-56.8478989220046 -37.5491970927912,
-56.8479421380053 -37.5492639453638,
-56.8537291464446 -37.5582129764816,
-56.8541978178042 -37.5579099039951,
-56.8645010125301 -37.5770310054849,
-56.9099109955326 -37.6390701227844,
-56.9408264876177 -37.6739507161854,
-56.9691204650958 -37.7004276395492,
-56.9859363113555 -37.713160736264,
-56.9914967833479 -37.7197233265916,
-57.0145774447065 -37.7412975110825,
-57.0208971337204 -37.7472059176319,
-57.0434486216783 -37.7659367441964,
-57.0539615660679 -37.7736737133196,
-57.0810115710871 -37.7968123040238,
-57.092308183295 -37.8048926118593,
-57.1283586540382 -37.8348951935272,
-57.141619434084 -37.8439275782521,
-57.1592857165216 -37.8589738591371,
-57.1749009232898 -37.8779273454909,
-57.1818019620971 -37.8845043315399,
-57.1818302163106 -37.8845312548093,
-57.1957352656058 -37.8977792215694,
-57.2218844584896 -37.9195005123515,
-57.2385272119612 -37.9315111004007,
-57.2473787866437 -37.9406544459072,
-57.2526891702259 -37.9444383545939,
-57.2737347766026 -37.9686219774289,
-57.2809772371272 -37.9753982649262,
-57.2802034513172 -37.9780159684952,
-57.2753485680693 -38.0221596210287,
-57.2783809384626 -38.0664657908038,
-57.2892048738928 -38.1095363651225,
-57.2921362059879 -38.1179528663417,
-57.295490606566 -38.1429011382479,
-57.3116243916269 -38.1897002719588,
-57.3136424605431 -38.1940872175844,
-57.324863688567 -38.2134001394761,
-57.3277812171405 -38.2210150821016,
-57.3531393702867 -38.261660154237,
-57.3857847977165 -38.2967220122569,
-57.4245187291338 -38.3249131522983,
-57.4373449492589 -38.3309081321469,
-57.481748696918 -38.3733061372136,
-57.4927087561533 -38.3810730182363,
-57.503686216636 -38.386845244093,
-57.5211118516077 -38.3992847717354,
-57.5405633650718 -38.415681080479,
-57.5788445316259 -38.4377703860292,
-57.5880146379707 -38.4410797266343,
-57.6141454392454 -38.4552397613663,
-57.625661369535 -38.4600227519165,
-57.6257441644908 -38.4600571223112,
-57.6353992116943 -38.4640631607292,
-57.6354941484834 -38.4638343513459,
-57.6536098551986 -38.4719772924745,
-57.6562773804561 -38.4736180984692,
-57.6615169787352 -38.4755315143698,
-57.6648330449446 -38.4770220734932,
-57.6664987652311 -38.4773507816087,
-57.6897177051231 -38.4858299600526,
-57.7016114207799 -38.4958532005017,
-57.7167144619672 -38.5060312030257,
-57.7736271372087 -38.5346040895324,
-57.819338114354 -38.5506490135605,
-57.8193952849318 -38.5506690731165,
-57.8214283155451 -38.5513821300008,
-57.8321785041973 -38.5540211523028,
-57.8434920634591 -38.5596029012224,
-57.8559739913249 -38.5639287679196,
-57.8590442189233 -38.5646084350605,
-57.8628348456272 -38.5672136270061,
-57.8661771898051 -38.5687022880542,
-57.8978718370579 -38.5873579274134,
-57.9423747891729 -38.6081478216789,
-57.967116182859 -38.6173933632332,
-57.9891456282993 -38.6276766329741,
-58.0023148738018 -38.6322289998461,
-58.0351912311184 -38.6496633371134,
-58.100678227522 -38.6768043838109,
-58.1450214721664 -38.6898721121531,
-58.1595283045995 -38.6945915409378,
-58.1595686044322 -38.6946046476858,
-58.1701275141638 -38.6980377411128,
-58.1758329065535 -38.6993038109019,
-58.1913855897632 -38.7058458452733,
-58.2260534133709 -38.7175247590955,
-58.2288439876404 -38.7182423944252,
-58.2564779197 -38.7253633395674,
-58.2718679704619 -38.7306236848361,
-58.295840645358 -38.7363322665505,
-58.3307941517362 -38.7497638097969,
-58.3547402821274 -38.7527786517355,
-58.3626361389771 -38.7558681527463,
-58.4225881875336 -38.7752132751267,
-58.4408976458735 -38.7803611042204,
-58.5096036954249 -38.7968860346972,
-58.51881427079 -38.7989183250541,
-58.5361671991893 -38.8024052805908,
-58.5510827763623 -38.803661848626,
-58.5600959892625 -38.8061565971375,
-58.560108315481 -38.8061600085465,
-58.5749133548649 -38.8102570492872,
-58.6168662819149 -38.8180871756049,
-58.6284665613086 -38.8182449522815,
-58.646836274815 -38.821404345053,
-58.6470045009386 -38.8214726528987,
-58.6470848522717 -38.8215052631479,
-58.6886338373087 -38.8383593509621,
-58.7197417066886 -38.8486604729395,
-58.7247420562586 -38.8499596234015,
-58.7310680645874 -38.8530164272002,
-58.7525306063947 -38.8580165199947,
-58.7587921675997 -38.8606983562789,
-58.7869337288877 -38.8692031741914,
-58.7869268448941 -38.8692230101852,
-58.8047228155492 -38.8753990227504,
-58.8375687882346 -38.8843446962536,
-58.8376264353609 -38.8843562478579,
-58.8572764731135 -38.8883758223052,
-58.8821131320595 -38.8972346691738,
-58.910520918476 -38.9039493633533,
-58.9135477084838 -38.9053653895425,
-58.963697828956 -38.9226167271953,
-58.9992147849239 -38.926855275256,
-59.0353591858228 -38.9384188623098,
-59.0476161601715 -38.9411647737875,
-59.0700609595407 -38.9451283377905,
-59.1190525085947 -38.9514929862414,
-59.1396340037887 -38.9558922393155,
-59.1396556773055 -38.9558968709814,
-59.1456187057113 -38.957170903499,
-59.2003570519274 -38.9614768608276,
-59.2122717745929 -38.9634305161732,
-59.2690626010586 -38.9771673668994,
-59.276874672867 -38.9790575204101,
-59.2936091389158 -38.9816163441862,
-59.2976423743005 -38.9829436539146,
-59.3011054112666 -38.9837230025209,
-59.3040449473484 -38.9848238066931,
-59.3484484747945 -38.9969284429974,
-59.3715751041734 -38.9988240155115,
-59.3935224483111 -39.0028246755082,
-59.3978720197169 -39.0025545360389,
-59.4120416626654 -39.0059828061348,
-59.4348455773878 -39.009598784307,
-59.4348934455418 -39.0096063699227,
-59.4710601222746 -39.0153340712449,
-59.4955318695537 -39.02077941403,
-59.5167918057049 -39.023208779247,
-59.5475588065073 -39.0301564921939,
-59.5900957062175 -39.0353962167267,
-59.6091755228512 -39.0408971523748,
-59.6283465769444 -39.0455584057252,
-59.6290636832499 -39.0457953207167,
-59.6664264181501 -39.0550194974975,
-59.6704599634265 -39.0556911238158,
-59.6715380043687 -39.055993626087,
-59.7195659638559 -39.0745159183019,
-59.7719647038999 -39.0827315748716,
-59.792897160433 -39.0837632730179,
-59.8299093273949 -39.0914031306621,
-59.8509525580953 -39.0925028872104,
-59.8732019973883 -39.0961030538456,
-59.8901249704932 -39.0951928739086,
-59.9040942978666 -39.096914698994,
-59.9081453973961 -39.0971736243648,
-59.9082198535067 -39.0971783720598,
-59.9244834541122 -39.0982129841909,
-59.950766411943 -39.1036914668972,
-59.9553974972622 -39.1043434448532,
-59.9674971802213 -39.1047927220643,
-60.0094644896872 -39.1110573523883,
-60.0156652460035 -39.1107662513159,
-60.0194088176332 -39.111782029031,
-60.0513073548221 -39.114483954189,
-60.0552966024815 -39.1153946899399,
-60.0561648861838 -39.115512502223,
-60.0809513294745 -39.1221540575757,
-60.1244572530227 -39.129772277706,
-60.1447602649114 -39.1297001605506,
-60.1497152640724 -39.130625365001,
-60.1584662088625 -39.1311020952908,
-60.1844281808957 -39.1388701021713,
-60.235908220953 -39.1428616254662,
-60.2702183448719 -39.1524431450162,
-60.3037806047907 -39.1540754620973,
-60.3058807771494 -39.1545324124056,
-60.3058872591417 -39.1545338226514,
-60.3196541327631 -39.1575288023817,
-60.3430946866138 -39.160274315578,
-60.3674828320818 -39.1649175741431,
-60.411367441976 -39.1693227447465,
-60.4255503471953 -39.1723820098106,
-60.463827578067 -39.172912342463,
-60.473641802049 -39.174178017704,
-60.5055130628249 -39.1790023933166,
-60.5412043712012 -39.1850138069337,
-60.5579722843288 -39.1887312552612,
-60.577293168658 -39.1884727446305,
-60.6063438422931 -39.1924406813035,
-60.613868912305 -39.192621416178,
-60.6209254492854 -39.1942535499134,
-60.6497456005851 -39.1968662287362,
-60.6752592135415 -39.2030367690613,
-60.6957741646193 -39.2062908501823,
-60.7205354465248 -39.2089088134766,
-60.738656100345 -39.2131243915134,
-60.7558641643118 -39.2154703856272,
-60.7579538303973 -39.2156366173977,
-60.768698899634 -39.2190187435097,
-60.792398932006 -39.224847820721,
-60.8365128610888 -39.22952495216,
-60.8364339564229 -39.2302439828857,
-60.8631599480393 -39.2331768275678,
-60.8906045549183 -39.2328205650099,
-60.9013477874526 -39.2345075117425,
-60.9721095372052 -39.2354797405507,
-60.9874424422076 -39.2335020510242,
-61.0055163153684 -39.2339365496004,
-61.0055912903955 -39.2339383407589,
-61.0261442617861 -39.2344262681061,
-61.0343321936578 -39.2343546310658,
-61.0381402752459 -39.2351918824546,
-61.0562779098557 -39.2374100863548,
-61.0832585387804 -39.2472798356948,
-61.1345754328738 -39.2546650502992,
-61.1516330560877 -39.2535577681819,
-61.1545340137607 -39.2536929197132,
-61.1984195048572 -39.2518748141032,
-61.223007760122 -39.2486761063752,
-61.2344735324215 -39.2482970170978,
-61.2588025350235 -39.2437842733876,
-61.2747366049442 -39.2440434643441,
-61.2998494564239 -39.2421290356025,
-61.3249459996888 -39.2432174401272,
-61.3385639604185 -39.2424165492795,
-61.3385996285407 -39.242414449031,
-61.3548506719496 -39.2414563723532,
-61.3742598448408 -39.2394310342881,
-61.3990648235679 -39.2446047618721,
-61.4205568619167 -39.2448187353585,
-61.4298001407236 -39.2474314448805,
-61.4466547846414 -39.2486343422129,
-61.4623121286782 -39.2523375498064,
-61.8308890281118 -39.6043469192709,
-61.8399606374942 -39.624814351274,
-61.8450386375083 -39.6335963394436,
-61.8509909623768 -39.6421057384657,
-61.8546195356376 -39.6500274041233,
-61.8551924904058 -39.6516716524694,
-61.8516103924615 -39.6717790363957,
-61.8515504614857 -39.7154549298856,
-61.8590926201396 -39.7584747288937,
-61.8687938972745 -39.7851773345946,
-61.8687826125712 -39.7859456195484,
-61.8686567640959 -39.7944693651308,
-61.8659214657525 -39.8156454799719,
-61.8656881030618 -39.8252034117397,
-61.8647847189464 -39.8290490722458,
-61.8623962651594 -39.8730522292809,
-61.8677712456491 -39.9167911378781,
-61.8692091527556 -39.9235200291582,
-61.882502212304 -39.9664210063964,
-61.8999353381288 -39.9998768207323,
-61.8792673597789 -40.0375716682283,
-61.8645978436076 -40.0838197479009,
-61.8591378505585 -40.1320304111821,
-61.8601934302734 -40.1449362814562,
-61.8581888471836 -40.1526939856706,
-61.8581329100427 -40.1558862631566,
-61.8531648361447 -40.1783728871507,
-61.8518196637726 -40.2255117432855,
-61.8593506912724 -40.2720645613656,
-61.8754899488712 -40.3163748943656,
-61.88316298095 -40.3292275568198,
-61.8780117556495 -40.3558200498992,
-61.8774473551034 -40.4004292084658,
-61.8848207353353 -40.4444283998215,
-61.8904708002405 -40.4660693506251,
-61.9065960947083 -40.5102912737499,
-61.9279664143589 -40.54608658415,
-61.9207681921718 -40.5823126406791,
-61.920073265344 -40.5893777300953,
-61.9205753037224 -40.6429778543498,
-61.9225143004411 -40.6514814103647,
-61.9268806173325 -40.6870613981139,
-61.941888711169 -40.7330044518228,
-61.9654568640011 -40.7752010066203,
-61.9967041898846 -40.8120739193047,
-62.0024681397082 -40.8176739945395,
-62.0162423786998 -40.827910717686,
-62.0278249091864 -40.850214602165,
-62.0328437840076 -40.862854629962,
-62.046988941394 -40.889696323857,
-62.0564799520118 -40.9112981866958,
-62.0738799171934 -40.9432863194901,
-62.0784399646634 -40.9558407258042,
-62.0948700563694 -40.9918832690414,
-62.116786658458 -41.0248783503318,
-62.122432674904 -41.032069294024,
-62.1481147318312 -41.0600983514743,
-62.1777497075425 -41.0839093641397,
-62.1853937266285 -41.0891473663034,
-62.2335301942426 -41.1149059516518,
-62.2427675561236 -41.1186162210599,
-62.2696938722015 -41.1327483697825,
-62.2878667003533 -41.1413723548841,
-62.3076038191991 -41.1497832929642,
-62.328670674219 -41.1576611135691,
-62.347423665432 -41.1637271136553,
-62.3856824755951 -41.1728508349355,
-62.3987974278645 -41.1749048823469,
-62.4312529912432 -41.1837471012403,
-62.5022137589588 -41.2136846534723,
-62.5146884099871 -41.218558212753,
-62.5357338828377 -41.2261369383687,
-62.5363989689812 -41.2264543776792,
-62.5365402112901 -41.2265217370285,
-62.5640290734415 -41.239620790897,
-62.5726724034086 -41.2423667806472,
-62.6005274707058 -41.259104079515,
-62.6124794024525 -41.2640780517289,
-62.6526625569789 -41.2769443878466,
-62.6944371493391 -41.2828699212336,
-62.7232248639343 -41.2844958328331,
-62.7281365956171 -41.2872723462848,
-62.7281392184058 -41.2872738288792,
-62.7330112750591 -41.2900278372753,
-62.7613655172899 -41.3037743594483,
-62.7926264873237 -41.3165644982755,
-62.8165567578264 -41.3249653732057,
-62.8333796901065 -41.3299282561617,
-62.8635915060645 -41.336838106131,
-62.8738042197873 -41.3385158185625,
-62.8796927440681 -41.3399699848706,
-62.8953499202138 -41.3473117461023,
-62.8954414156489 -41.3473546264087,
-62.8967844479934 -41.3479837217691,
-62.9121966903304 -41.3541336635601,
-62.9260950400408 -41.3618668346007,
-63.4730480524364 -42.0730660154402,
-63.4614541370679 -42.0828953596613,
-63.4537331972565 -42.09105124481,
-63.429221533691 -42.1213649395113,
-63.4201915333886 -42.134509934591,
-63.3953752105951 -42.1801765590225,
-63.3856964591938 -42.2034808129217,
-63.3675089665754 -42.2320969968063,
-63.3494774781919 -42.2796670527328,
-63.3477264315649 -42.2862389342028,
-63.3393994752661 -42.3577101946067,
-63.3398954995318 -42.3751551814485,
-63.3439264015274 -42.4133141713143,
-63.353749392156 -42.4504068327662,
-63.355420648885 -42.455196845567,
-63.3531858440206 -42.4642108710585,
-63.3506939027241 -42.5117320739369,
-63.3518901594277 -42.5203301064004,
-63.3384279868958 -42.5818754008189,
-63.337874932161 -42.5889595003915,
-63.3382822696225 -42.6325322539764,
-63.3462491951393 -42.6753724089316,
-63.3481833025315 -42.6823303021881,
-63.3662712809528 -42.7288188394884,
-63.3862421971412 -42.7599127144333,
-63.3863904286904 -42.7877096338585,
-63.3877253641165 -42.798542606678,
-63.3980151780232 -42.8450074979875,
-63.4169235646249 -42.8886805939479,
-63.4437653244112 -42.9279792749209,
-63.4483163206456 -42.9334424066218,
-63.4919880031541 -42.9746113403176,
-63.5442131694756 -43.0041854668046,
-63.5467694393335 -43.005251002085,
-63.5577338427715 -43.0121708504476,
-63.6028784473791 -43.0346477042668,
-63.6485394348538 -43.0518826992886,
-63.694949806649 -43.0644579916083,
-63.7020187685044 -43.0656589758398,
-63.7488707343265 -43.0678391911658,
-63.79194213348 -43.0747725473875,
-63.7948563357665 -43.0749147486398,
-63.854360495509 -43.0880083497916,
-63.8819848307364 -43.0903994738102,
-63.9078340259173 -43.0950833566177,
-63.9168318511525 -43.0979236874447,
-63.9624434195526 -43.1077558645874,
-64.0289220635715 -43.115694934585,
-64.060239107821 -43.1239528220889,
-64.066632153005 -43.1246857692295,
-64.0671047230687 -43.1247394928613,
-64.0696688059209 -43.1250285176463,
-64.093346364289 -43.1265643627876,
-64.1117750277955 -43.1268832437711,
-64.1359108614659 -43.1625742353141,
-64.1688895403718 -43.1957738355575,
-64.2074775579044 -43.2222459269296,
-64.2503229092629 -43.2410630092134,
-64.2744768971285 -43.2490699814704,
-64.2744985706951 -43.2490771650922,
-64.2794977186541 -43.2507338604339,
-64.2879056555607 -43.2539726509983,
-64.2914390554426 -43.2565074406041,
-64.3198986588686 -43.2741629089784,
-64.3531097541114 -43.2918018698232,
-64.3733003651151 -43.3013938971541,
-64.394593324445 -43.3103659868875,
-64.422277026404 -43.3201594601243,
-64.4255650793786 -43.3211094398836,
-64.425764352396 -43.3211669240238,
-64.4368882862202 -43.3243708394544,
-64.4788832633263 -43.3318440592672,
-64.4879684207155 -43.3348360831352,
-64.5050824117234 -43.3398035653315,
-64.5963374990857 -43.3627986377376,
-64.5964997698759 -43.3628394700771,
-64.6193468142669 -43.3685803622459,
-64.6392768292746 -43.3762163488475,
-64.6595296878027 -43.3829989910221,
-64.6676183779756 -43.3853286797231,
-64.7206135653267 -43.4062969238887,
-64.720771033841 -43.406359166715,
-64.7301808975284 -43.4100749342668,
-64.7865601773329 -43.4337470866891,
-64.8031936360422 -43.4417555074836,
-64.8093708800577 -43.4455195402435,
-64.8109557869243 -43.4530503042317,
-64.8217208160366 -43.4856613474088,
-64.8421028219691 -43.531404653086,
-64.8711928891392 -43.5721679229764,
-64.9078237489623 -43.6063154893426,
-64.9159636162941 -43.6125034712656,
-64.9190355189648 -43.6142873009591,
-64.9268028685538 -43.6227734088811,
-64.9640971647536 -43.6506231734786,
-64.9894939273039 -43.6845104369519,
-65.0177607977072 -43.7152994974555,
-65.0556324920058 -43.7489584311281,
-65.0635136099867 -43.7546452842064,
-65.06364647426 -43.7547410901653,
-65.0669883893443 -43.7571492193273,
-65.0671200927523 -43.7572203134021,
-65.0635954137088 -43.7775828385973,
-65.0640268539925 -43.7910513714699,
-65.0348114892196 -43.8214503886636,
-65.0102631066411 -43.8625546321717,
-64.9964788389584 -43.8758528666333,
-64.96919624139 -43.9145979562556,
-64.9497147413773 -43.9577951003415,
-64.9387342771414 -44.0038922966238,
-64.9366493586841 -44.0512333487345,
-64.9435348936928 -44.0981173706137,
-64.9591434962311 -44.1428598965451,
-64.9679836115569 -44.1581049076365,
-64.9680918083042 -44.1623186110984,
-64.9781641503885 -44.2084666281454,
-64.99340814395 -44.2441127423732,
-64.9870571642065 -44.2656541945082,
-64.9827126788621 -44.2740366896824,
-64.9693901516244 -44.3180348818698,
-64.9643491543728 -44.3637286341175,
-64.9677601398111 -44.4095728903128,
-64.9795077712982 -44.4540175053095,
-64.9991948227596 -44.4955596604356,
-65.0015367684142 -44.4995146530633,
-65.0303195896443 -44.5388092763399,
-65.0335670971584 -44.5417951768165,
-65.0347433094109 -44.5590427896181,
-65.049267396838 -44.6096942345512,
-65.0740852647837 -44.6561763969366,
-65.1080943971391 -44.6964243398137,
-65.1497839624195 -44.7286500769833,
-65.1528900107487 -44.7305649981991,
-65.1682184119346 -44.7381541260832,
-65.1932952749829 -44.7655597398393,
-65.2006493891841 -44.7721597845039,
-65.2410534304944 -44.8016903736055,
-65.286529717929 -44.8225817480947,
-65.2894032550069 -44.8232549260297,
-65.2825065173596 -44.8533130269026,
-65.2818227824727 -44.8711644262952,
-65.2754346262854 -44.8970898666584,
-65.2580166486647 -44.9097277203861,
-65.2559866103908 -44.9115088664273,
-65.2240629734742 -44.9452611914894,
-65.1989356694402 -44.9843374839575,
-65.1814724297475 -45.0273883062552,
-65.1722763195888 -45.072926966743,
-65.1716649119943 -45.1193808602486,
-65.1796593209524 -45.1651457754838,
-65.1959834722714 -45.2086412939287,
-65.220073637363 -45.24836536707,
-65.2510979007113 -45.2829461872564,
-65.2554239434285 -45.2869481772152,
-65.2748299953388 -45.3020086562531,
-65.5455634550737 -47.0569598597216,
-65.5205124758341 -47.0990204098886,
-65.5041386097791 -47.1451564906892,
-65.4970697334839 -47.1935989558323,
-65.4968556932046 -47.1981659698836,
-65.4975554088674 -47.2093528262435,
-65.4834057973155 -47.2450483806431,
-65.467329468956 -47.3096757778397,
-65.4667494831663 -47.3149167723428,
-65.466848857432 -47.3707963120369,
-65.474201248855 -47.402807715727,
-65.475967096407 -47.4233840095023,
-65.475974103944 -47.4234655073507,
-65.4765081485224 -47.4296645785316,
-65.4787148234417 -47.4476381552298,
-65.485004735556 -47.4870178403027,
-65.4906727761536 -47.5393563737869,
-65.4990078832136 -47.581709975109,
-65.5145043786332 -47.6219984372832,
-65.5161579631359 -47.6253900966334,
-65.5276331566426 -47.6605159695178,
-65.5455347805047 -47.7021080133066,
-65.5535063955137 -47.7140702651794,
-65.5666731029516 -47.7449017681878,
-65.5666891714749 -47.7449393861366,
-65.5724844970049 -47.7585037250408,
-65.5679635157542 -47.7636989942519,
-65.5556212318696 -47.785322696231,
-65.5500135366487 -47.7932503891906,
-65.5459077452109 -47.8023407410798,
-65.5435327679553 -47.8065017051981,
-65.542146434168 -47.8106684024971,
-65.5303464791628 -47.8367938754781,
-65.5193223607059 -47.8832836287627,
-65.5173438400001 -47.9310215990174,
-65.5244831830158 -47.9782641447736,
-65.5271437706865 -47.9857523011991,
-65.5272895101558 -47.9883474471435,
-65.5396489167939 -48.0360486364323,
-65.5611246288291 -48.0803989710938,
-65.5908823033751 -48.1196754169313,
-65.5934682127032 -48.1224674456402,
-65.6257003107228 -48.1516963369936,
-65.6625120782451 -48.1748939662769,
-65.6684443087759 -48.1773188707447,
-65.6717403880544 -48.1884749688311,
-65.6758523904922 -48.1988050526063,
-65.6920446716798 -48.2320781342702,
-65.7129710058018 -48.2625965954648,
-65.7159309575588 -48.2662935428216,
-65.7464504935601 -48.2981782883625,
-65.7821016129597 -48.3241989870751,
-65.8217730965619 -48.3435445929002,
-65.8291821289927 -48.3463785143611,
-65.832443042091 -48.3472528759257,
-65.8807774242457 -48.3631927654455,
-65.8841645764615 -48.363920784027,
-65.9342207512955 -48.3694904761249,
-65.9530980788161 -48.367768079896,
-65.9336624780477 -48.4101924884575,
-65.9222674974994 -48.4601291116589,
-65.921288912906 -48.5113399922474,
-65.9307678015212 -48.5616754925337,
-65.9503062757088 -48.6090227199591,
-65.9790841847504 -48.6513942182763,
-66.0158935416484 -48.6870113933919,
-66.0182515051199 -48.6888654116993,
-66.0501745520269 -48.7102135996383,
-66.0538975503387 -48.7123085892798,
-66.1108592735697 -48.7356639011755,
-66.1187092360166 -48.7377999034693,
-66.1681942265022 -48.7460483238264,
-66.2183297312929 -48.7442505804825,
-66.224532850933 -48.7433995239444,
-66.2755170917125 -48.7308385831837,
-66.3227531054233 -48.7079054401511,
-66.3641570885161 -48.6756117840449,
-66.3690780787201 -48.6708627653482,
-66.3902863772712 -48.6461482157039,
-66.4308760409817 -48.6602116531322,
-66.4802976997724 -48.6668607022947,
-66.5047805540189 -48.6676893763479,
-66.5145563513199 -48.6687902870033,
-66.5149119488382 -48.6688056303887,
-66.5432983914029 -48.6776378624061,
-66.5515072585615 -48.6792938582511,
-66.5525275791857 -48.6793834083721,
-66.5589836726166 -48.6848090504085,
-66.5921361708063 -48.7083508859771,
-66.628666423227 -48.7262071682395,
-66.6334165868582 -48.7280673231148,
-66.6407902710674 -48.7327758367319,
-66.6462176658752 -48.7358562121471,
-66.6596613773146 -48.747466137156,
-66.6678332802802 -48.7538972026527,
-66.6965762350032 -48.773442274541,
-66.7092172849187 -48.7808081820799,
-66.7374587103893 -48.7949549262038,
-66.7586837260121 -48.8039579954513,
-66.792692464958 -48.8145812981087,
-66.7978767817797 -48.8163296991418,
-66.8143730810707 -48.8221788530148,
-66.8213238249926 -48.825577886728,
-66.8217110925879 -48.8269445527317,
-66.8465440456173 -48.8736956823425,
-66.8482459826736 -48.8762138239836,
-66.8799357184602 -48.9143263341905,
-66.9185217510688 -48.9454377609664,
-66.9624873081392 -48.9683251500703,
-66.9676522620167 -48.9703921525372,
-67.0173739682363 -48.9845340846005,
-67.0421630825788 -48.9862711440854,
-67.0561498660558 -49.0014054986754,
-67.0644199881628 -49.0087226486836,
-67.1034446091061 -49.0370419160571,
-67.1155215150289 -49.0441369288676,
-67.1561743812617 -49.0633317730538,
-67.1724104629735 -49.0692786076226,
-67.2215304197258 -49.0817970798891,
-67.2284394821645 -49.0828270707254,
-67.2326546124402 -49.0859420591739,
-67.2450021088155 -49.1021421074635,
-67.2828559132751 -49.1352172586451,
-67.3047059757989 -49.1507313064541,
-67.3048981182334 -49.1508291086546,
-67.327699119181 -49.1756571089007,
-67.3370832716561 -49.1834120205656,
-67.345795248082 -49.1888905822091,
-67.3362334110297 -49.2354593593859,
-67.3359703787923 -49.2846707766276,
-67.3453525997229 -49.3329802653778,
-67.3640165190993 -49.3785158655869,
-67.3679939068248 -49.3860164589283,
-67.3681492394307 -49.386355691209,
-67.3693852881835 -49.3911176845748,
-67.3757106637756 -49.4117722388291,
-67.3905957922443 -49.4537992940951,
-67.4054837709346 -49.4876444212814,
-67.4063466329905 -49.48926826243,
-67.4138298610085 -49.5266116462276,
-67.4164545673946 -49.535881591552,
-67.4228768669792 -49.5705163848517,
-67.434030735845 -49.6012713574255,
-67.4360031914124 -49.6095039595543,
-67.4481794691016 -49.6454877303665,
-67.448930881684 -49.6613169231816,
-67.4500669145479 -49.6741199114664,
-67.4538178841769 -49.6915132160677,
-67.454019765596 -49.7044562873949,
-67.4558887456005 -49.720916266504,
-67.4611957328939 -49.749405982699,
-67.4624317488865 -49.7663495877492,
-67.4646747713198 -49.7846336617713,
-67.4725568934096 -49.8233032465101,
-67.4812309813397 -49.8534581070743,
-67.4924359568186 -49.8845218306123,
-67.5039187953544 -49.9107778489182,
-67.5349456134897 -49.9632003771971,
-67.5367367418474 -49.9655247376756,
-67.5369326913103 -49.9658659088349,
-67.5386107169361 -49.9725632233597,
-67.5407847395426 -49.9789562685437,
-67.5572259997991 -50.0167513508776,
-67.579653705936 -50.0513314215092,
-67.6074582609554 -50.0817565757015,
-67.6185052740541 -50.0920035780524,
-67.6382583986695 -50.108517839882,
-67.6642593640439 -50.1280718979626,
-67.6784711058007 -50.138007395794,
-67.6792828860632 -50.1385339705494,
-67.6988284935638 -50.155862695289,
-67.7091735390361 -50.1635878595796,
-67.711739871212 -50.1654789028367,
-67.7142428751359 -50.1672987732705,
-67.7156650268702 -50.1681464744273,
-67.7190712399696 -50.1707958051834,
-67.7227844976437 -50.1752469218548,
-67.7535929446511 -50.2018617757325,
-67.7699038348485 -50.2137788555257,
-67.7998178170967 -50.2325457881943,
-67.8087369248202 -50.2372986793302,
-67.8208190848983 -50.2417226406642,
-67.8320614582993 -50.2510054907731,
-67.843513493341 -50.2587155173466,
-67.879286418357 -50.2787466567344,
-67.8921344677532 -50.2846135782384,
-67.9290128784592 -50.298065632064,
-67.9375459775525 -50.2997296202002,
-67.9462981462032 -50.3043531154982,
-67.9462981462032 -50.3043531154981,
-67.9883183278985 -50.3218636508764,
-68.0180517589193 -50.3282785791531,
-68.029269639574 -50.333794286274,
-68.0432167576411 -50.3396383251824,
-68.0912498137215 -50.3542959120422,
-68.1190588561919 -50.3598049849543,
-68.1205420909198 -50.3600941631963,
-68.1329805978552 -50.3624802321814,
-68.1433040976498 -50.3647768692253,
-68.1677494058001 -50.3689550101619,
-68.1802163719687 -50.3704539961967,
-68.2068963753254 -50.3722217163419,
-68.2170293358241 -50.3723499775674,
-68.2489675301733 -50.3952344866929,
-68.2655155192657 -50.4037714550691,
-68.3046764067582 -50.4199350186106,
-68.3062925915008 -50.4204467004484,
-68.3275928844523 -50.4290295085514,
-68.3390678020896 -50.4330314985102,
-68.3729499230235 -50.4422370969922,
-68.3752238681103 -50.4426862522801,
-68.3917504771556 -50.4475153397433,
-68.3920403613803 -50.4465232675791,
-68.4207441331903 -50.4562658504942,
-68.4307542126663 -50.4582228404819,
-68.4501074066668 -50.461224789381,
-68.4529506615918 -50.4615523721118,
-68.4716695240182 -50.4684346505358,
-68.4851075528444 -50.4746339169109,
-68.492301488876 -50.4773007954237,
-68.5305807247032 -50.4871825094907,
-68.5381436911119 -50.4900469394222,
-68.5386179432688 -50.4901824307393,
-68.573756457543 -50.5037713360665,
-68.6102087682692 -50.5102499657965,
-68.6127866329978 -50.5111535941361,
-68.6271836580993 -50.5160096329724,
-68.6321164746692 -50.5169148015278,
-68.6508020740695 -50.5253319490781,
-68.6655800063786 -50.5304048445132,
-68.6852436127546 -50.5354751526012,
-68.6855148798516 -50.5356248502048,
-68.6931073919879 -50.5390879784353,
-68.7211991951054 -50.5651879315081,
-68.7647318220912 -50.5910775702353,
-68.7648843859968 -50.5913526661619,
-68.7682794591111 -50.5963345592743,
-68.7977460654783 -50.6319779073871,
-68.8159926556417 -50.6471831761361,
-68.8229381915966 -50.6555629631951,
-68.8365332750315 -50.6660754579901,
-68.8429666700534 -50.6733045138084,
-68.8449619688589 -50.6846581801738,
-68.8473588450107 -50.6912739895527,
-68.8536248363701 -50.720574602325,
-68.8688278577377 -50.7590466670545,
-68.873878750677 -50.7692626898913,
-68.880562931123 -50.7805530534628,
-68.8802824182466 -50.7826182566653,
-68.8798046975451 -50.7906063074137,
-68.879449219673 -50.7923341509515,
-68.8757423209081 -50.8160887780559,
-68.8736063186144 -50.8360318402625,
-68.8750230043072 -50.9002210239669,
-68.8783356733309 -50.922016850847,
-68.8807023134787 -50.9378855890997,
-68.8972960756857 -50.9925297522273,
-68.8939665127648 -51.0116068766293,
-68.8936765811419 -51.0150893484441,
-68.8935912703825 -51.0153059043091,
-68.8919972335657 -51.0210510199963,
-68.8867971977673 -51.0517541966048,
-68.8792639319296 -51.0716102969232,
-68.8786455656388 -51.0725862271798,
-68.8738711437709 -51.0789251225887,
-68.8529762115365 -51.1216222330213,
-68.8523650020736 -51.1232465577599,
-68.8401820629796 -51.1470074895317,
-68.8233917900505 -51.1885580302873,
-68.8209775660453 -51.1965236735255,
-68.8097944113835 -51.2228546396561,
-68.807045965458 -51.234034662697,
-68.8049341549408 -51.2370314022253,
-68.7847076156812 -51.2834363324515,
-68.7776571420152 -51.3168081365347,
-68.7702996145096 -51.3371505835892,
-68.7610667760437 -51.3522029465048,
-68.748757523103 -51.3781211137498,
-68.7455032253799 -51.3831132518922,
-68.7264043711991 -51.4182750011283,
-68.7255315015002 -51.4207634585991,
-68.7119471458901 -51.4456622704916,
-68.69792145657 -51.4877246592976,
-68.6915470194331 -51.5316032538986,
-68.6913180174567 -51.5357274017141,
-68.693406726003 -51.5814394923884,
-68.6720517621566 -51.6080971382952,
-68.6567732527799 -51.6258665830964,
-68.6276672727507 -51.6676800861423,
-68.6185843986853 -51.6840705846023,
-68.614531859148 -51.6898811112149,
-68.6115629819107 -51.6929021627618,
-68.5878430267738 -51.7267573962789,
-68.5837597259483 -51.7353061366299,
-68.5820063381475 -51.737762730822,
-68.5650733778301 -51.7662514486279,
-68.553219978022 -51.7842601589345,
-68.5304858471447 -51.8097242710549,
-68.5036538718302 -51.8389992249098,
-68.4891884573152 -51.8531123317765,
-68.4720749335122 -51.8715804129954,
-68.4571293008131 -51.8894340132532,
-68.4516394417356 -51.895627884675,
-68.4340435487221 -51.9113024424446,
-68.4303443333514 -51.9146646634719,
-68.4079694832772 -51.9354134520526,
-68.4019985786596 -51.9401219385744,
-68.3948264692998 -51.9459965801882,
-68.3871974119109 -51.9524855562539,
-68.3726221381983 -51.9675784377031,
-68.3555586948089 -51.9781463292527,
-68.3220576733198 -52.0029863069455,
-68.2931522174974 -52.0330498655553,
-68.287064474967 -52.0405434351988,
-68.2654522037597 -52.0599992708049,
-68.2645953828846 -52.0608843755913,
-68.263331397922 -52.0620394258112,
-68.237204820891 -52.0913754412062,
-68.2357244670315 -52.0926309870535,
-68.2189269848086 -52.110349904282,
-68.1966080174628 -52.1278274845665,
-68.1661933877561 -52.1623556394474,
-68.142621998327 -52.2018731391162,
-68.1397680105899 -52.2078472567799,
-68.1233261884405 -52.2529616263962,
-68.115812629147 -52.3003872132477,
-68.1149886796837 -52.3138911130391,
-68.1158212634588 -52.3545459276575,
-68.12323357144 -52.3945279841053,
-68.1260794622586 -52.4050259909284,
-68.1437669712931 -52.4514246542683,
-68.1702758504613 -52.4934123103213,
-68.1771879785265 -52.5022703391164,
-68.2252644908631 -52.5492053937728,
-68.2290693342887 -52.5520300000581,
-68.2307807996493 -52.5546176179195,
-68.2697021930655 -52.592306019962,
-68.3024156681654 -52.6124604217674
-64.1702886372118 -54.8734967718578,
-64.1681445379997 -54.8704716927132,
-64.1720356353795 -54.8662257390808,
-64.1826705857367 -54.8669467168637,
-64.1840975796052 -54.869037658046,
-64.1773685123052 -54.8741307957772,
-64.172553486121 -54.8749237657264,
-64.1736984960032 -54.846225822425,
-64.1709365667086 -54.8444826966966,
-64.1690975100984 -54.8426096682329,
-64.1696315546768 -54.841720767402,
-64.1718215951003 -54.8381047892298,
-64.1820145593214 -54.8392718016078,
-64.1897275782343 -54.8419758203334,
-64.1903605460339 -54.8440517998186,
-64.182647527121 -54.8466037372932,
-64.1743316398228 -54.8466267959088,
-64.3415835237497 -54.8376427368176,
-64.3340456447035 -54.8324357141681,
-64.3330615170707 -54.8296697364142,
-64.3368455943109 -54.8265568233063,
-64.3435135826826 -54.827399782926,
-64.3525235167088 -54.8340107408285,
-64.3527525186853 -54.8363037529323,
-64.3498224903226 -54.8385196682908,
-64.3386455744885 -54.7475127690813,
-64.3427195566136 -54.7457807326108,
-64.3445895927379 -54.7417107989449,
-64.3401334712655 -54.7269747593879,
-64.3461915504532 -54.7195738238756,
-64.3514325449563 -54.7071267479632,
-64.3592224845946 -54.7029647558548,
-64.3635256447161 -54.7035257314881,
-64.3677064709608 -54.705676695479,
-64.3689875442772 -54.7098237258902,
-64.3663935380306 -54.7184487042496,
-64.3723674796743 -54.72864571693,
-64.3730085443923 -54.736205774492,
-64.3715364894123 -54.7512547775496,
-64.3608246183298 -54.7683787039724,
-64.3573374867731 -54.7783548115948,
-64.3596875293461 -54.7896077680544,
-64.3637845700868 -54.7931327439039,
-64.3881455574331 -54.800555681912,
-64.3911896467341 -54.7967416812775,
-64.3849185833869 -54.7849386624225,
-64.3886646403144 -54.7767987950908,
-64.3967585664348 -54.7573278184344,
-64.3963084833804 -54.7470317065128,
-64.3916775740813 -54.7400667724576,
-64.3926925052082 -54.7368927804214,
-64.3975985337151 -54.7344897558384,
-64.4054104758491 -54.7355847760502,
-64.4227905113233 -54.7410127037577,
-64.4245684890051 -54.743797691668,
-64.4235834812724 -54.7465166720908,
-64.4135975165319 -54.7538297736398,
-64.4117586359417 -54.7574468079318,
-64.4140315817693 -54.7643547115178,
-64.4166796261456 -54.7660177481615,
-64.420951630733 -54.7670288068492,
-64.4285204892934 -54.7660598169335,
-64.4397655248544 -54.7578586946534,
-64.4533535621898 -54.7554246905564,
-64.4690165228906 -54.7516627918319,
-64.4881745360465 -54.7486686922015,
-64.4991305468226 -54.750053793318,
-64.5024414823928 -54.7478447427382,
-64.5307234905133 -54.7208137085198,
-64.5452576351687 -54.7158777566186,
-64.5593795410626 -54.7111586613163,
-64.5675584848268 -54.7127078130416,
-64.5693896205385 -54.7148057950225,
-64.5695575435866 -54.7182346639703,
-64.5627746141768 -54.7251737230904,
-64.5528865165376 -54.7373007947038,
-64.5515135607988 -54.7459567525773,
-64.5462565484787 -54.753612741021,
-64.5320436402621 -54.7594717416266,
-64.5188446070527 -54.7619207074208,
-64.5062176387345 -54.7732967018369,
-64.5012896077319 -54.7818716905259,
-64.5022045595179 -54.7857777496029,
-64.510757545711 -54.7877958185191,
-64.530151601642 -54.7873117636111,
-64.5541996254878 -54.7880667132475,
-64.563919624059 -54.7903366667358,
-64.5748596170181 -54.7981186854755,
-64.5806575386953 -54.800071803024,
-64.5958024726345 -54.798110764577,
-64.6273345134168 -54.7814177350322,
-64.6403126415682 -54.7762066639234,
-64.6554945397005 -54.7735596756669,
-64.6661145283604 -54.7742387606978,
-64.6872786410748 -54.7767366600426,
-64.6941604937058 -54.7803077531234,
-64.680274630587 -54.7873348222267,
-64.6788405959198 -54.7911877232739,
-64.6798245475326 -54.7944067764216,
-64.6825106122217 -54.7956047683137,
-64.6915585665607 -54.7962526978105,
-64.7078935714936 -54.7940748027647,
-64.7134325678 -54.7939607418264,
-64.7196656108344 -54.7954597278613,
-64.7410506286068 -54.8134957897506,
-64.7482986027681 -54.8239247967469,
-64.7582856236285 -54.8348656698059,
-64.7557606172088 -54.8373297733172,
-64.7398836162288 -54.8381496743212,
-64.7296374939777 -54.8438837007505,
-64.720046518042 -54.8452878120235,
-64.7015225288054 -54.8442186667468,
-64.6859584913259 -54.8402407915235,
-64.6810985800503 -54.8419687795348,
-64.6770474805209 -54.8434827272668,
-64.6752475003432 -54.8468737519218,
-64.6806715556115 -54.8547557500026,
-64.6780925110621 -54.857902810984,
-64.6655885807005 -54.8615267100546,
-64.6500476018365 -54.8691976601956,
-64.6461184841439 -54.8748287149445,
-64.6503676061357 -54.8824577723333,
-64.6575245779743 -54.8880918194217,
-64.6663136069426 -54.8930737125341,
-64.6857756065807 -54.8982807351836,
-64.6875076430512 -54.9021987636184,
-64.6804965917648 -54.9063947275803,
-64.6708374961021 -54.9087067498405,
-64.6459736197114 -54.9072727151733,
-64.6374736155282 -54.9038968282354,
-64.6302186005682 -54.8998568179639,
-64.6181186360298 -54.8970867917507,
-64.6137385551829 -54.8974497449217,
-64.6050796049699 -54.9025187679175,
-64.5980226124722 -54.9014547272199,
-64.5891955631912 -54.8971517431184,
-64.5818704922846 -54.8883097321402,
-64.5758136452366 -54.8840678269671,
-64.5730665016192 -54.8778377762721,
-64.5647734969166 -54.8717158018366,
-64.554130625661 -54.871024747448,
-64.5425566087825 -54.8723718282518,
-64.5329205717353 -54.8685037894875,
-64.5173114731444 -54.8594776616244,
-64.5140765781997 -54.8488918208379,
-64.5180665988007 -54.8368687770249,
-64.5166776252449 -54.8340947023525,
-64.4930726436549 -54.8207706949669,
-64.4822386147156 -54.8173296806414,
-64.4794925272179 -54.8170397757565,
-64.4702984763067 -54.8184317416518,
-64.4660945914464 -54.8219947378141,
-64.4711986424155 -54.8282818189782,
-64.4971235671643 -54.8423458143031,
-64.5006786424281 -54.8481366951816,
-64.4976725734399 -54.8514977964423,
-64.4935535302034 -54.8539198311816,
-64.4814755681607 -54.8568496835243,
-64.4611815221409 -54.8527376810864,
-64.4467925939578 -54.8492127052369,
-64.4281086025717 -54.8391876640638,
-64.4033966314122 -54.8251377503362,
-64.392814487045 -54.8237496568803,
-64.3822025953035 -54.8228186872773,
-64.3560865128711 -54.8121527574061,
-64.3402485883236 -54.8069797066101,
-64.3311085755422 -54.8021926676006,
-64.3083196225169 -54.7787967977308,
-64.2984315248777 -54.7790187589085,
-64.2968135493454 -54.7794338139896,
-64.2925945267679 -54.7884787759891,
-64.2868884875133 -54.790855749617,
-64.2759555353528 -54.7837367980911,
-64.264488538614 -54.7731747200001,
-64.2563095948497 -54.7716026856792,
-64.2451245820972 -54.7891617334592,
-64.2549206212939 -54.8060878134397,
-64.2605205205088 -54.815822773708,
-64.2627635429421 -54.8334766962501,
-64.2608106014136 -54.8384587653824,
-64.2578816291707 -54.8406716884015,
-64.2509915036013 -54.8427927289981,
-64.2423015738742 -54.8373216763987,
-64.2274856212524 -54.8186757053254,
-64.2170566142561 -54.8207057435992,
-64.1930694933187 -54.8292576736726,
-64.1902845054084 -54.8294176758221,
-64.18922451317 -54.8277926594912,
-64.1935046146759 -54.8182986705571,
-64.1993484775643 -54.8143276601124,
-64.1932756126995 -54.8109778241296,
-64.1874234768726 -54.8099176558712,
-64.1727446438047 -54.8157266668063,
-64.1514055672436 -54.8103946699805,
-64.1452716234503 -54.807952744985,
-64.136588558502 -54.8077357123663,
-64.1339185116298 -54.81155376146,
-64.1403884775392 -54.8199467455036,
-64.1394194876235 -54.8222087780933,
-64.1202774922845 -54.8192097499038,
-64.1111064999889 -54.8150936990067,
-64.1050565177197 -54.8014526796614,
-64.0879975426645 -54.7820436620332,
-64.0807036272919 -54.7793387632077,
-64.0731425136101 -54.7800597409905,
-64.0717625170726 -54.7825396862988,
-64.0746615659211 -54.7908437802593,
-64.0737075377026 -54.7928768108726,
-64.0635605146927 -54.791244753743,
-64.0552215687788 -54.7917177193931,
-64.0507735442249 -54.7929727417544,
-64.0445405011905 -54.791896731699,
-64.0291975447889 -54.7860108000386,
-64.0086744967926 -54.7758716979272,
-63.9985545808575 -54.7740057102621,
-63.9943996295478 -54.7716107825976,
-63.9898185338992 -54.7696606573886,
-63.985198537838 -54.7681697682721,
-63.9789274744908 -54.7675436652512,
-63.975719510601 -54.7681467096565,
-63.9771005632583 -54.7802998322249,
-63.9802856445525 -54.7897566809461,
-63.9787864824976 -54.793605709554,
-63.9711266216146 -54.7954597278613,
-63.9689675607053 -54.7976877885975,
-63.9750066297366 -54.8060797165213,
-63.9735984700044 -54.8087847913667,
-63.9656335665194 -54.8094897513326,
-63.9597705174546 -54.808646791713,
-63.9423904819805 -54.8036117405707,
-63.9352685381152 -54.7988467040571,
-63.9253315069253 -54.7898938005,
-63.9180104844778 -54.7828368080023,
-63.9124336438786 -54.78337472502,
-63.9045636151556 -54.7877347395907,
-63.8955265740545 -54.7918317803314,
-63.8845026195714 -54.7913056566514,
-63.872428529968 -54.7891467717621,
-63.8652226245787 -54.7855226966714,
-63.8540075124119 -54.777896807642,
-63.8468554691323 -54.7690127278918,
-63.8330345573812 -54.7549137045936,
-63.8238755344433 -54.7418556633774,
-63.8137814934433 -54.7351727133085,
-63.8114775681016 -54.7344207560116,
-63.8089525616818 -54.731605668687,
-63.8069615998405 -54.7272067537037,
-63.8083114969638 -54.7206156860574,
-63.816669629054 -54.7151296717609,
-63.8205874814687 -54.715465693877,
-63.8584136442138 -54.7396047200455,
-63.8714065580424 -54.7447628091444,
-63.8838045243842 -54.7476157407617,
-63.8858685345116 -54.7465288174685,
-63.8862306075827 -54.7421946778329,
-63.879436588915 -54.7289768104871,
-63.8818125064231 -54.7194367043217,
-63.8878556239136 -54.713199788848,
-63.8902736101937 -54.7125777342863,
-63.9010166368103 -54.7114987318916,
-63.9248805437711 -54.7139737486408,
-63.9407195244384 -54.7180558276844,
-63.9536786424334 -54.7188607669912,
-63.9609524915298 -54.7215686581562,
-63.9725794904182 -54.724166712862,
-63.9949144879499 -54.726127751309,
-64.0128326164617 -54.7291148101408,
-64.0312495855586 -54.7307357780125,
-64.0410915659665 -54.7360227137269,
-64.0451815659085 -54.7441326576643,
-64.051887574593 -54.7541348162417,
-64.0578845748523 -54.7581786989525,
-64.0634235711587 -54.7580906889693,
-64.0669406261097 -54.7536086925618,
-64.0747376065467 -54.7298048084096,
-64.0791095904751 -54.724429686692,
-64.0903166057234 -54.7174036737084,
-64.0942156240017 -54.7179607769024,
-64.1006774929926 -54.7210956925061,
-64.1130825001331 -54.7289578003307,
-64.1187434782763 -54.732299715415,
-64.1280214907115 -54.7348217294953,
-64.137618627346 -54.7332347334772,
-64.1426925789009 -54.7287907573825,
-64.1424024979961 -54.7223816943815,
-64.1451184860795 -54.7178806878177,
-64.15216051688 -54.7134817728344,
-64.1620024972879 -54.7137297849672,
-64.1783146196252 -54.7171097203643,
-64.1803965837892 -54.720817756979,
-64.1765054864093 -54.725291656468,
-64.1666034831928 -54.7309917110438,
-64.1675715930086 -54.7337568086979,
-64.1599346147213 -54.740653799046,
-64.1572415092335 -54.7449307321925,
-64.1601715375962 -54.7530058241765,
-64.1624295217267 -54.7544328180451,
-64.1671825888826 -54.7543217494462,
-64.1908185499868 -54.7446248094906,
-64.2050626137375 -54.7337758188542,
-64.2153096160884 -54.7287676987668,
-64.2232745195734 -54.7225647551467,
-64.230468631625 -54.7213667632546,
-64.2516635478335 -54.7280578102419,
-64.2580036110075 -54.7277527676399,
-64.2941206198777 -54.7194828215529,
-64.3056946367562 -54.7177007954119,
-64.3099976208577 -54.7182617710452,
-64.3164366072529 -54.7218437773638,
-64.3239366420063 -54.7380217724866,
-64.328170626281 -54.7449796657432,
-64.3331065781821 -54.7476116923025,
-64.2498855701516 -54.6956447895272,
-64.2510835620438 -54.6912228159283,
-64.2532505438516 -54.6870617039198,
-64.2542116128688 -54.6877747608041,
-64.2584154977292 -54.6908797530135,
-64.2595295280973 -54.6932297955865,
-64.2608945629376 -54.6961017373603,
-64.2542184776475 -54.6980627758072,
-64.2656405892949 -54.6768147015689,
-64.2641144961851 -54.6740267213192,
-64.2618635528533 -54.6704096870272,
-64.2705156382876 -54.6661227207426,
-64.2786785642349 -54.6679647696922,
-64.2799525967526 -54.6711996646369,
-64.2811666064617 -54.6752317540099,
-64.2779385762957 -54.6781156651414,
-64.2717285918769 -54.6790506832035,
-64.2836685542658 -54.6687088060907,
-64.2780075761225 -54.6653707634456,
-64.2736435130926 -54.6604657910586,
-64.2706455410229 -54.654685823418,
-64.2795715135251 -54.6601528275581,
-64.2826006411289 -54.6618237851003,
-64.2912976116546 -54.666835777627,
-64.2911075100908 -54.6693458223495,
-64.1288524809734 -54.6454357981575,
-64.1307374787949 -54.6446567337857,
-64.134979559988 -54.6429056871587,
-64.1430666213298 -54.6408848019231,
-64.1471406034548 -54.6394116908233,
-64.1536176101628 -54.6397248303438,
-64.1613086265799 -54.6420247072263,
-64.1676634754312 -54.6435967415473,
-64.1682665198365 -54.6477277541415,
-64.1678614978935 -54.651946776719,
-64.1666034831928 -54.6539768149929,
-64.1662595401782 -54.6545258212684,
-64.1608506226271 -54.6572117099376,
-64.1549145252762 -54.6617127165014,
-64.1497425305999 -54.6601787024932,
-64.1426466376896 -54.6578937873078,
-64.1400985726543 -54.6555287830377,
-64.1392285059598 -54.6521907403926,
-64.1383205949725 -54.6490746589253,
-64.1381834754186 -54.6486087340739,
-64.1369854835265 -54.6486478105065,
-64.1326596168293 -54.648776657122,
-69.0197525997317 -51.5898706994388,
-69.0210576117635 -51.5855027639696,
-69.0261005838042 -51.5826838042058,
-69.0315705802838 -51.5819167091917,
-69.035354481504 -51.5850637701731,
-69.0325545318966 -51.5887637098693,
-69.023094514816 -51.5909657196505,
-69.1956095717618 -50.9496536935349,
-69.1916355689777 -50.9478716673939,
-69.1867145787737 -50.9467236651723,
-69.1884615769414 -50.941772751574,
-69.1903835389559 -50.9411237659574,
-69.1954265109966 -50.9453507094334,
-69.1994784906259 -50.9489747845241,
-69.199577589867 -50.9514316712167,
-67.1942595601001 -48.787635824794,
-67.1901325959651 -48.783061769944,
-67.1884236181101 -48.7789457190469,
-67.1894686486514 -48.776889805838,
-67.1960215199649 -48.7780378080596,
-67.2018815766903 -48.7814717815864,
-67.2053144940973 -48.7867317862459,
-67.2001264816041 -48.7894706569249,
-67.0553745259175 -48.7362218007335,
-67.0536725888612 -48.7337036590924,
-67.0568006396862 -48.7298238269904,
-67.0643995976608 -48.7293857132938,
-67.0702515574677 -48.7312277622434,
-67.0736695131776 -48.7360308190698,
-67.0702056162565 -48.737853681843,
-67.066070555203 -48.7369308091586,
-67.0605394797951 -48.7382888032003,
-66.1764985601492 -48.4944347900439,
-66.1727755618373 -48.4923398004024,
-66.1704175983658 -48.4904857820951,
-66.1773686268437 -48.4873577312701,
-66.1869816052752 -48.4872287086346,
-66.1917725167239 -48.4879648241346,
-66.1954726324401 -48.4909707171028,
-66.1905516422361 -48.4957197357995,
-66.184348522596 -48.4965707923376,
-66.1968306264818 -48.2551917959305,
-66.1945036425244 -48.2524258181766,
-66.1966095454038 -48.2501597371277,
-66.2041704830657 -48.2484097466205,
-66.2119364839885 -48.2523726601468,
-66.2135465386222 -48.2565006804016,
-66.2097395787864 -48.2582897473413,
-66.2032395134627 -48.2586827999265,
-66.0675965910435 -48.1313517163462,
-66.0714795915049 -48.1263698232339,
-66.0759504986545 -48.125049673485,
-66.0806736424161 -48.1267017968907,
-66.0802306001603 -48.1305807488929,
-66.0767445247234 -48.1335107772556,
-66.0692295282729 -48.1341097732016,
-66.4997636291607 -45.1836548214699,
-66.4950176028034 -45.1803776817332,
-66.5006255989367 -45.176803772333,
-66.5044784999838 -45.1777768107079,
-66.505676491876 -45.1807707343184,
-66.5035624920781 -45.1862298175601,
-66.5003055946376 -45.1870956597754,
-65.9414135096848 -45.1175807984778,
-65.9442136353122 -45.1123737758283,
-65.943405527646 -45.1084666606315,
-65.9531855490257 -45.106376775569,
-65.9588465271689 -45.1021427912943,
-65.9614106100212 -45.1026497287979,
-65.9596255915407 -45.1067348001809,
-65.9543075002923 -45.1105197575209,
-65.9553145105207 -45.1174047785113,
-65.9536435529786 -45.1187437623966,
-65.945602608868 -45.1178967543178,
-65.9426495218897 -45.1189806852716,
-65.4251935931754 -45.1034317855091,
-65.4208675504583 -45.0994297955504,
-65.4228975887322 -45.0976486495092,
-65.4300616013695 -45.0964547060763,
-65.4345245876206 -45.0977097284375,
-65.4369585917176 -45.1007457208201,
-65.4329226299053 -45.1038517691493,
-65.9997864831217 -45.0880817883089,
-66.0110095161869 -45.0818938063859,
-66.0146335912776 -45.0881456835567,
-66.0137255042703 -45.0947647383777,
-66.00952161941 -45.1029246719856,
-66.003906582478 -45.1060176948373,
-65.9951626146212 -45.1065297369199,
-65.9905086467064 -45.1098707719044,
-65.9796445183529 -45.1069067716882,
-65.9672166286168 -45.1107786828917,
-65.9650646085062 -45.107990702642,
-65.9690706469242 -45.1048658201764,
-65.9804385444219 -45.1032598140019,
-65.9851145148325 -45.0994648235237,
-65.9855885366023 -45.0958097689189,
-65.9824985060901 -45.0923157725835,
-65.9865265470039 -45.0885047642884,
-65.9904255652822 -45.0878946790845,
-65.9932635352024 -45.0895536672689,
-65.8990405751846 -45.0727657629621,
-65.8978725066868 -45.0697626863134,
-65.9088665377756 -45.0615237197405,
-65.9216005262335 -45.0659027444676,
-65.9236905873159 -45.0698397830587,
-65.9136736430613 -45.0778728062707,
-65.7650224930763 -45.081130759831,
-65.7595215170827 -45.0741427671602,
-65.7487415262731 -45.069785744929,
-65.7476725570165 -45.0647237627318,
-65.7503206013928 -45.0560838226752,
-65.7545855651815 -45.0543477377455,
-65.7577975775306 -45.0619738027949,
-65.7689054935377 -45.0663338173656,
-65.7703856454362 -45.0766677735799,
-65.7688296289322 -45.0825876770939,
-65.7036436266712 -45.0605427604671,
-65.7070695032796 -45.0560417539032,
-65.7176365099296 -45.0507847415832,
-65.7198186294546 -45.0524328165297,
-65.7202305161762 -45.0577086629862,
-65.7051464851454 -45.0628656959653,
-65.5935214871577 -45.0548207033955,
-65.592063513775 -45.0515828161114,
-65.5938105119427 -45.0486487392895,
-65.6049045223725 -45.0461577047233,
-65.6167985435501 -45.0471187737405,
-65.6211854891757 -45.0499687130184,
-65.6223445806552 -45.0527417315709,
-65.6189046224495 -45.0572437942546,
-65.6093066057152 -45.0622867662954,
-65.6041414758176 -45.0623927303152,
-65.4955524702124 -45.0188408140793,
-65.494361519119 -45.0167507529968,
-65.5096895138234 -45.0065877121699,
-65.5154645529049 -45.0071826596568,
-65.5225905452295 -45.0133097386713,
-65.5234296324099 -45.0158467144488,
-65.5194705913229 -45.0178107452352,
-65.4993895294626 -45.0193898203548,
-65.5306776065712 -44.892387718092,
-65.5303345436565 -44.8861956877098,
-65.5322116205794 -44.8805156994102,
-65.5355146352512 -44.8787646527832,
-65.5396655381016 -44.8795507579537,
-65.5407404920372 -44.8839267903413,
-65.5375284796881 -44.8904877585734,
-65.533859519506 -44.8931507646469,
-65.6503606226062 -44.7816276822197,
-65.641860618423 -44.7777666842541,
-65.640052541327 -44.7752077059809,
-65.6430205900024 -44.7736736919727,
-65.654930628997 -44.7730328032746,
-65.6598285605853 -44.7713127361618,
-65.6655425207385 -44.7728157706559,
-65.6682585088219 -44.7765428174269,
-65.6648636117276 -44.7805867001377,
-65.6596145203061 -44.7829856762614,
-63.5920676237157 -42.374564673209,
-63.5897945018681 -42.3680496461882,
-63.5892984776024 -42.3506046593464,
-63.5910495242293 -42.3440327778765,
-63.5941085752275 -42.3443908024884,
-63.596813474053 -42.3493197135909,
-63.5991246162134 -42.3592757549371,
-63.5996706301495 -42.3721347175712,
-63.5972135674369 -42.3759267157099,
-62.2155305826278 -40.5241047855063,
-62.2010914887543 -40.5182457849008,
-62.1940684681101 -40.5102807053958,
-62.1681975814911 -40.4712146580066,
-62.1667825569802 -40.4642567647501,
-62.1691095409376 -40.4588886838311,
-62.1753885251833 -40.4560357522138,
-62.189395490039 -40.4538538087088,
-62.194957544961 -40.449126792508,
-62.199794573641 -40.4487117374269,
-62.2031136061297 -40.4546318169608,
-62.2046775435322 -40.4687157025419,
-62.205188529495 -40.473315808347,
-62.2307925698448 -40.5091476648713,
-62.2313426322402 -40.5158267425009,
-62.228057571605 -40.5218316636587,
-62.2245065448005 -40.5243837771533,
-62.126712491702 -40.3812747918341,
-62.1285325381558 -40.374961659715,
-62.1336635201798 -40.3745687831497,
-62.1394505286191 -40.3948438190132,
-62.1373514905183 -40.4009136915386,
-62.1323625566073 -40.4029157426378,
-62.1567194954943 -40.380702726943,
-62.1594006316243 -40.3687057340849,
-62.1636506337159 -40.3650517355999,
-62.1674994863039 -40.3655016426344,
-62.1708486182068 -40.3679847563021,
-62.1776315476166 -40.3791887792109,
-62.1783215458854 -40.3803286845141,
-62.1981505471537 -40.4256976548644,
-62.1965176099243 -40.4331667101037,
-62.1945305205223 -40.4351196516323,
-62.1868555219221 -40.4369736699396,
-62.1784625378786 -40.4369587082425,
-62.1636164858424 -40.4324416838616,
-62.1464846385211 -40.4177096927638,
-62.1448216018774 -40.4102786578373,
-62.1464615799055 -40.4057887405313,
-62.1502835014385 -40.4034848151896,
-62.1546855847812 -40.4044266980304,
-62.1562155503302 -40.4010736936882,
-62.1457745739762 -40.3823657635866,
-62.1460875374766 -40.3791768098532,
-62.1474376106198 -40.377647724404,
-62.151374473191 -40.3771856719919,
-62.154865477187 -40.3812827127326,
-62.3453136243417 -40.2874946980521,
-62.3490714746069 -40.2888488196545,
-62.3517115980847 -40.3247678060624,
-62.3525925780172 -40.3367118169105,
-62.3512305355162 -40.3478656741289,
-62.3488695797053 -40.347507649517,
-62.344055609641 -40.3415106492577,
-62.335906589271 -40.3422046959857,
-62.3325465441301 -40.3335376488543,
-62.3344114756754 -40.3265376868257,
-62.3224834826442 -40.3167076757755,
-62.3242875112811 -40.3103906712171,
-62.321643515364 -40.3035966525494,
-62.3243755212643 -40.3000797736183,
-62.3299256068287 -40.2983287269914,
-62.3331985220861 -40.2891117934845,
-62.3430556402112 -40.2892036759071,
-62.36871759113 -40.258311819743,
-62.3671265466526 -40.2561606797322,
-62.365894582907 -40.2439457741556,
-62.3698506316545 -40.2400437635378,
-62.3772654727441 -40.2374728159068,
-62.3810425091857 -40.2385977595128,
-62.3792995594772 -40.2538527059312,
-62.3785935433915 -40.2581706517299,
-62.3739816442487 -40.2595217809929,
-62.1012765504202 -40.2090417188747,
-62.1071124924101 -40.1983796614428,
-62.1059076357393 -40.1863897093834,
-62.1119155492365 -40.170924771145,
-62.1135446140267 -40.1604767539923,
-62.1091075027106 -40.1359256650822,
-62.1119805006042 -40.1340297540228,
-62.1167566263757 -40.1400337950808,
-62.1240885620611 -40.1564976466292,
-62.1267695221711 -40.1646957765698,
-62.1277575222432 -40.1677127587959,
-62.130050534347 -40.1868667234926,
-62.1222956226821 -40.2079616603602,
-62.1131975026527 -40.2214206750601,
-62.1107525853177 -40.2219658088964,
-62.27913258121 -39.9999997025568,
-62.2999995722209 -39.9999997025568,
-62.3007205500038 -39.9999997025568,
-62.2998656210264 -40.00082365202,
-62.2907636285577 -40.0026056781611,
-62.2607685941231 -40.0080147717322,
-62.2620655092364 -39.9999997025568,
-62.2703856210138 -39.9999997025568,
-62.2699276170609 -40.002574698647,
-62.2676696329304 -40.0074886480523,
-62.2626454950261 -40.0101858019993,
-62.1515086004055 -39.8926697677721,
-62.1529736145868 -39.8897707189235,
-62.1592406294748 -39.8864516864348,
-62.1627884879199 -39.8866497088971,
-62.164428641968 -39.8913307838868,
-62.1625825445591 -39.8951227820255,
-62.1596644855541 -39.8945007274638,
-62.1559186046467 -39.8963547457711,
-62.1527484850496 -39.8952597255594,
-62.2255285167261 -39.8711247478502,
-62.2345585170285 -39.8668097943909,
-62.2603836384563 -39.867324652793,
-62.2606966019568 -39.8703228008827,
-62.2577135915842 -39.8735957161402,
-62.253082506265 -39.8754046733361,
-62.2488286317342 -39.8795247726924,
-62.2398266186065 -39.8804017041656,
-62.2292066299465 -39.8857727774239,
-62.2226755851088 -39.8856386502095,
-62.2112235500671 -39.8840866821647,
-62.2078626248263 -39.8818357388328,
-62.2061656163291 -39.8746337058827,
-62.2075845132792 -39.8721887885478,
-62.2144815036274 -39.8684467800795,
-62.2188686252729 -39.8723607600551,
-62.1136894784591 -39.8712766530813,
-62.1122515713526 -39.8645477618012,
-62.1140555999895 -39.8612097191561,
-62.120140610232 -39.8691218166511,
-62.1352695263543 -39.8789138073886,
-62.1301535060275 -39.8857347571112,
-62.127448607202 -39.8860397997132,
-62.2643924931938 -39.3315547266622,
-62.2650185962147 -39.3343427069119,
-62.2515256096612 -39.3365707676481,
-62.2500766132968 -39.3362616765869,
-62.2510874959645 -39.3317296905089,
-62.2586825814998 -39.3326106704413,
-62.0100445216735 -39.2650297405159,
-61.9999995902441 -39.2554708002142,
-62.0000346182175 -39.2434496926207,
-62.005199572095 -39.2417988013547,
-62.0137935709404 -39.2413788177146,
-62.0261915372821 -39.2381937364204,
-62.035781633118 -39.2458608141221,
-62.0326495338338 -39.2477458119435,
-62.0292014787096 -39.2560388166461,
-62.0236434722468 -39.2616846570722,
-62.0146066071657 -39.2666707746638,
-62.0697784814914 -39.2512588184353,
-62.0670086312983 -39.2462807977622,
-62.0763325849448 -39.2351118028267,
-62.0822415752208 -39.2349887648701,
-62.081504579621 -39.2303576795509,
-62.0872576162067 -39.2256398163883,
-62.1224665380696 -39.2088277973462,
-62.1521304789472 -39.2006497336817,
-62.1598244877037 -39.1971817883014,
-62.1597825949517 -39.2070466513049,
-62.1579555076992 -39.2113647731236,
-62.1486206408148 -39.2222477356135,
-62.1298065706735 -39.2372437566611,
-62.1167715880728 -39.2440757956416,
-62.0977825540848 -39.2514837719525,
-62.0866434825435 -39.2538297660663,
-62.2276954985339 -39.2058296492564,
-62.2285234964564 -39.2001376915991,
-62.2359165110702 -39.1840327447624,
-62.240165633062 -39.1858747937121,
-62.2426716293253 -39.1906048022524,
-62.2346535678104 -39.2039258172986,
-62.2323874867615 -39.2060927991064,
-62.0787926399968 -39.0759737352764,
-62.0889166043912 -39.0747187129151,
-62.090042604117 -39.0752407881358,
-62.0881155375235 -39.0831637988688,
-62.0904574831781 -39.0894966452242,
-62.0898855943068 -39.0924456837433,
-62.0841904682901 -39.093498811203,
-62.085647561573 -39.1029887516779,
-62.073760581194 -39.1165387687005,
-62.0735435485753 -39.1250187066075,
-62.0701785748753 -39.1294177976108,
-62.0694005666233 -39.1298258118932,
-62.0642894748555 -39.132518741361,
-62.0633125640413 -39.1365967719453,
-62.0747265787703 -39.1342657395287,
-62.0766675509411 -39.1355248103492,
-62.0779796037715 -39.1434057523101,
-62.0753095568994 -39.1528897081062,
-62.0666386373287 -39.1542278118917,
-62.0644494770051 -39.1524966555209,
-62.0610086386995 -39.1422007196193,
-62.0462725991425 -39.1206967123496,
-62.0413774838736 -39.1194957281181,
-62.0346755236484 -39.1218647808475,
-62.018653482216 -39.1200178033388,
-62.0187075203457 -39.1225466821978,
-62.0240175146757 -39.1285936721276,
-62.0256425310066 -39.1400647173256,
-62.0259516220678 -39.1422466608306,
-62.0314525980614 -39.1432536710591,
-62.0322915092219 -39.1313666906801,
-62.0362964915201 -39.1295316825291,
-62.0412785606524 -39.1236226922531,
-62.041622503667 -39.1241836678864,
-62.043315639725 -39.1269528139997,
-62.0419155769113 -39.132381797827,
-62.0440295767091 -39.1380077479969,
-62.0521655716016 -39.1391677195762,
-62.0560146002095 -39.1451266995228,
-62.0580634726198 -39.1576387268029,
-62.056232512928 -39.161433717281,
-62.0481334822286 -39.1598206703078,
-62.0288846427699 -39.1669727135874,
-62.0214196359898 -39.1649358105349,
-62.0148356091422 -39.1721308026863,
-62.008285554148 -39.175880732053,
-62.0035786042234 -39.175838663281,
-61.9999995902441 -39.1734766513503,
-61.9919084804431 -39.1755137304228,
-61.9866525242429 -39.1772917081047,
-61.9777605235942 -39.1837116843435,
-61.9653625572525 -39.1816707328317,
-61.9595225668033 -39.1830597063875,
-61.9290586151779 -39.2054747930039,
-61.9220426353324 -39.2088237488869,
-61.9131395454258 -39.2094727345035,
-61.9091076320728 -39.2097666878476,
-61.9034616156267 -39.2132487148252,
-61.904106552784 -39.226093771882,
-61.9016605793293 -39.2289738105742,
-61.8845405253457 -39.237533661546,
-61.8820494907795 -39.2311326954635,
-61.8757175245239 -39.2243076972817,
-61.8725166014328 -39.224910741687,
-61.8691065666214 -39.2291107541081,
-61.8675465016581 -39.2357447706263,
-61.8619156229292 -39.2364807101063,
-61.8602566347447 -39.2331967055909,
-61.860423501673 -39.2203097557822,
-61.8571245354605 -39.2050817404187,
-61.8578756126576 -39.198497713571,
-61.8613815783508 -39.1953427316912,
-61.8671455281744 -39.1931227678734,
-61.8714634739731 -39.1940268064215,
-61.8735084739441 -39.1944536548403,
-61.8780365875828 -39.1935658101291,
-61.8777655168344 -39.190627684848,
-61.8679694776377 -39.1814647894709,
-61.8661955484151 -39.1739658108373,
-61.8734896398077 -39.1471637785953,
-61.8746376420293 -39.1361238062952,
-61.8829155090148 -39.1229897244535,
-61.8895945866443 -39.1160696754897,
-61.8906744691389 -39.1189646758791,
-61.8815914868266 -39.1350977859104,
-61.8892055825183 -39.1412167680065,
-61.8919636393737 -39.1505627241488,
-61.896015619003 -39.1532898014901,
-61.8987316070864 -39.1533466559393,
-61.9018515609929 -39.1519047003735,
-61.9031185527119 -39.14803278917,
-61.9008595124616 -39.1411937093909,
-61.9022595752753 -39.1358337253904,
-61.9065745287346 -39.1326366747385,
-61.9087445028818 -39.1268116459865,
-61.9166865237712 -39.1335447617458,
-61.9207876129711 -39.130988775812,
-61.9274026193329 -39.1234357590486,
-61.9260636354475 -39.1119008186027,
-61.9293555608614 -39.1123466771779,
-61.9355234765082 -39.1174887484598,
-61.9394795252557 -39.111015790211,
-61.9414025433899 -39.1078646807704,
-61.9476355864243 -39.102020641862,
-61.9572186414615 -39.1002116846661,
-61.9679185431863 -39.0958027365447,
-61.984764534082 -39.0963207633062,
-61.9973635152255 -39.092010738406,
-61.9999995902441 -39.0941356514418,
-62.0042835641893 -39.0948568052447,
-62.0152015546525 -39.0945697166793,
-62.0166774820718 -39.1068226425686,
-62.0187944742091 -39.1062548021566,
-62.0295755211385 -39.0904006837723,
-62.0337486025047 -39.0915106656811,
-62.0359226251112 -39.09645876296,
-62.0387426409948 -39.0977667673312,
-62.0403826190229 -39.0960276900619,
-62.0390165280627 -39.0918157082831,
-62.0496674962368 -39.085086817003,
-62.0676155481429 -39.0790026868603,
-62.0752215469161 -39.079440800557,
-62.1261935848407 -39.0164837391321,
-62.1285056071009 -39.0106467410223,
-62.1323315770932 -39.0106356517644,
-62.1343915387613 -39.0137367715346,
-62.1349834939087 -39.0199657661097,
-62.140712591779 -39.0184597392762,
-62.139587472153 -39.0241318066773,
-62.1448096325197 -39.0248867563137,
-62.1470146346403 -39.0296056755961,
-62.1468356223343 -39.0346447751976,
-62.1438175839884 -39.0386046963844,
-62.136180605701 -39.0416107653726,
-62.1308785322695 -39.0385547067139,
-62.1269265319813 -39.0305246758413,
-62.2899935412042 -39.0259516771112,
-62.2838895208052 -39.0251537786029,
-62.2805894984729 -39.0226747133945,
-62.2746815643167 -39.0133937086198,
-62.2684406003838 -39.0077667023301,
-62.2685275542472 -39.0036386820753,
-62.3019106209974 -39.0146827028346,
-62.3008846006126 -39.019443690889,
-62.2958446209112 -39.0262797783287,
-62.0888484846641 -38.9916188066216,
-62.0952145987932 -38.9926758065206,
-62.1186755960507 -38.9995266796375,
-62.1248325984595 -39.0028606738233,
-62.1274295970456 -39.0064546494997,
-62.1183626325502 -39.0215457213292,
-62.1101535893716 -39.0213047499951,
-62.1056254757329 -39.0256346651515,
-62.099731623174 -39.0257566469883,
-62.0904465699401 -39.0213237601514,
-62.0858616018523 -39.0169297737272,
-62.0794065976401 -39.016788781734,
-62.0742375953033 -39.0123597673365,
-62.0677715018332 -39.0154307876923,
-62.0628434708305 -39.0146867512939,
-62.0609774831655 -39.0164377979208,
-62.0579985212521 -39.0192296506098,
-62.0662874774955 -39.0217706748464,
-62.066547635006 -39.0252306993283,
-62.0614544972748 -39.0292967605549,
-62.0596194891238 -39.0330966795921,
-62.0467564780305 -39.0415347247471,
-62.0418286230478 -39.0407906883486,
-62.0359805356802 -39.0342557710716,
-62.0339165255528 -39.0373496740231,
-62.0328176329018 -39.0457797982796,
-62.0268595330551 -39.0465817452471,
-62.0307655921321 -39.0518567116037,
-62.0287936404472 -39.0540386551087,
-62.0161555828711 -39.0569797727293,
-61.9999995902441 -39.0556296995861,
-61.9975625938077 -39.0565258172356,
-61.9769216124338 -39.0587577504111,
-61.9666974926785 -39.0565948170625,
-61.965091486504 -39.0393717913985,
-61.9674336081785 -39.0354388012666,
-61.974060583898 -39.0310478071818,
-61.9772226065766 -39.024322788341,
-61.9816055037429 -39.0219607764103,
-61.9856036212624 -39.0213087984543,
-61.9882625788766 -39.0236928128808,
-61.9935875349038 -39.0227548024792,
-61.9999995902441 -39.017661664748,
-62.0061185723402 -39.0173758083224,
-62.0125235868819 -39.0149917938958,
-62.0266454927758 -39.0057107891212,
-62.0337825743582 -39.007961732453,
-62.0530544724325 -39.0001218031443,
-62.0569645799688 -38.992999683259,
-62.0631786128468 -38.993488666726,
-62.0791436238101 -38.9947357681888,
-62.3015555887249 -39.0057107891212,
-62.2973175559911 -38.9974436593537,
-62.2917445878311 -38.9941487416004,
-62.2812765044022 -38.992873652963,
-62.2793385245709 -38.9884067942726,
-62.2928735798964 -38.9882427436638,
-62.3011855947553 -38.9905436766661,
-62.3036495222466 -38.9989437015084,
-62.308158625729 -39.0042417264806,
-62.3041034777403 -39.0067707813596,
-62.2758825485482 -38.9716877137727,
-62.2796245570165 -38.9661598067242,
-62.2878306078556 -38.9696006450297,
-62.2959326308945 -38.9709697283293,
-62.2948645417377 -38.9729767079876,
-62.2900195921592 -38.9745446938493,
-62.1441425168466 -38.9663198088738,
-62.1500245760678 -38.9599957635167,
-62.1572456191742 -38.9613266504835,
-62.1645465753455 -38.9649547740334,
-62.163513514162 -38.969714705968,
-62.156894635361 -38.9776037448475,
-62.1567724775042 -38.9851727794277,
-62.1490135173801 -38.9895518041548,
-62.1462176162319 -38.9974246491973,
-62.1383136156553 -39.0001867545119,
-62.1310195242627 -38.9933438022935,
-62.1290326108807 -38.9863466565845,
-62.1186375757379 -38.9843747048995,
-62.1173135535497 -38.9797096477269,
-62.1207165475625 -38.9716377241023,
-62.1321215852731 -38.9628787945483,
-62.1411095168035 -38.9672926712287,
-62.2875635855664 -38.9629287842188,
-62.3007626187758 -38.9535676903594,
-62.3047065221456 -38.9650346870982,
-62.3025555581547 -38.9660607074831,
-62.2866136058071 -38.9477266437904,
-62.2653655315687 -38.9391977723327,
-62.2581096365088 -38.9286877961518,
-62.2752914735007 -38.9271277311885,
-62.2844504964385 -38.929706775738,
-62.2906875879322 -38.9353337820277,
-62.2956504708882 -38.9484638154102,
-62.2887575289993 -38.9531286965629,
-62.3159594786052 -38.8743097718751,
-62.3189424889778 -38.8673587433972,
-62.3270754915308 -38.8746947275419,
-62.32655359233 -38.8771936830065,
-62.3244056206786 -38.8782197033914,
-62.2443806071802 -38.835868771387,
-62.2550815650248 -38.8279767401681,
-62.2605436406058 -38.8292046554546,
-62.2703935419123 -38.8400837455052,
-62.256610474454 -38.8432156687695,
-62.2490995264626 -38.8483007095823,
-62.2451665363307 -38.859100766668,
-62.2387655702483 -38.8585088115206,
-62.2354505862188 -38.8562587482886,
-62.2282985429392 -38.8574597325201,
-62.3371235913195 -38.8256758071658,
-62.3321835909592 -38.8187407965049,
-62.3200985881179 -38.8130187394333,
-62.3217045942924 -38.8115047917013,
-62.3303105624954 -38.8103747435162,
-62.3445435369882 -38.8054277023572,
-62.347709608126 -38.8060606701568,
-62.3497736182534 -38.812373802276,
-62.3469425131119 -38.817725689358,
-62.3422925936563 -38.8204536467991,
-62.3411715224896 -38.8263587646359,
-62.3557774832913 -38.8140827801309,
-62.3671914980203 -38.8046146661318,
-62.3677366318566 -38.8083186542873,
-62.364280479814 -38.8140947494886,
-62.3563615175403 -38.8173296444333,
-62.2639005173873 -38.8245696976962,
-62.2613866002255 -38.8200686911323,
-62.2724415342228 -38.8050767185439,
-62.2770495609262 -38.8028108135149,
-62.2810475024258 -38.8039517749379,
-62.280273542633 -38.8124047817901,
-62.2765345265042 -38.8211476935271,
-62.269695622745 -38.8253558028666,
