[postgis-users] Except
George Pavlov
gpavlov at mynewplace.com
Wed Nov 28 06:05:07 PST 2007
this is a pure SQL question, not a postGIS one really. there is nothing like that in the SQL standard but you can come up with a generic SQL-generating code using the system tables. something along these lines (using psql as an example):
test=# \t
Showing only tuples.
test=# \a
Output format is unaligned.
test=# \o /tmp/test.sql
test=# select
test-# 'select ' ||
test-# array_to_string(array(
test-# select column_name::text from information_schema.columns c
test-# where c.table_name = t.table_name
test-# and column_name!='employee_id'
test-# ),', ') ||
test-# ' from ' || table_name
test-# from information_schema.tables t
test-# where table_schema = 'test' and table_name = 'employee';
test=# \o
test=# \i /tmp/test.sql
you get the idea. hope this helps.
george
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Matt Doughty
Sent: Wed 11/28/07 04:31 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Except
Is there a way of selecting all fields except one in particular? I'd
like to create a query that says something like: select * except
field01. The thing is the query needs to be valid for a number of
different tables, each with a different set of fields apart from one
(gid), which I don't want to select.
Cheers,
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071128/dde86407/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071128/dde86407/attachment.jpg>
