[postgis-users] RE: postgis-users Digest, Vol 61, Issue 29
Gerry James gerry.james at carteryx.com
Wed Nov 28 13:26:59 PST 2007
Kevin, I added the extra brackets and it worked like a charm.  Thanks
-Gerry-
Message: 4
Date: Tue, 27 Nov 2007 14:53:26 -0800
Subject: Re: [postgis-users] Invalid Geometry Error
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <474C9FE6.10102 at refractions.net>
Content-Type: text/plain; charset=windows-1252; format=flowed
The WKT representation of a POLYGON contains two brackets, not one - an
outer ring and zero or more interior rings.
-- Kevin
Gerry James wrote:
> I am trying to create a polygon for the extents of each of a number of
> tables and use the geometries to populate an index table. The SQL I
> have been using is:
> INSERT INTO index_survey (tablename,the_geom) VALUES
> ('survey_20040812' ,GeometryFromText('POLYGON(455700 5609025, 462650
> 5609025, 462650 5613490, 455700 5613490, 455700 5609025)',26911));
> which throws out an invalid geometry error. To create the spatial
> table in the first place I used:
> CREATE TABLE index_survey (gid serial PRIMARY KEY, tablename varchar(25));
> SELECT
AddGeometryColumn('public','index_survey,'the_geom','26911','POLYGON',2);
> I have tried using this SQL both from pgAdmin and using ASP with no
> success.
> Does anyone have any suggestions?
> Thanks Gerry
> postgis-users mailing list
