[postgis-users] Holy cow are linestrings a problem
Per-Olof Norén
pelle at alma.nu
Thu Nov 29 01:20:03 PST 2007
phat-ass at thinkheavyindustries.com skrev:
> I've got geoserver up and running, and it's nice.
> I've got postgis talking to geoserver and that's nice.
> What I need to do is collect this awful .shp file of linestrings into something I can display properly. I can't seem to figure out the syntax for this.
> I'm lost in the world of duplicate labels!
Assuming you want to aggregate geometries based on a label column, you'd
be using a group by based aproach in conjunction with the st_union
functions.
example:
create table testdata (
id serial primary key,
label varchar(255),
the_geom geometry -- created using addgeometrycolumn
select
label,
st_union(the_geom)
from
testdata
group by
label;
OR:
you could play with a custom SLD in geoserver containing a
Textsymbolizer, naturally:
<TextSymbolizer>
<VendorOption name="group">yes</VendorOption>
</TextSymbolizer>
Grouping tries to reduce the number of times a label is written.
I'd suggest that you further consult at the geoserver-users mail list
regarding the SLD.
cheers,
Per-Olof
