[postgis-users] ERROR: Out of memory
    Kevin Neufeld
    kneufeld at refractions.net
    Mon Oct  8 15:34:57 PDT 2007
What happens if you use ST_MemUnion(...) instead?
-- Kevin
Andreas Laggner wrote:
> Hi,
> i tried to perform the "union approach" from Kevin
> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
> the first query worked fine:
> CREATE TABLE all_lines AS
>   SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffhsinglerep
>   UNION ALL
>   SELECT St_ExteriorRing (the_geom) AS the_geom FROM spasinglerep;
> but in the second one i get an error:
> CREATE TABLE noded_lines AS
>   SELECT St_Union(the_geom) AS the_geom
>   FROM all_lines;
> SQL Status:53200
> Detail:Failed on request of size 20750552.
> If anybody knows what may be behind this error......i have no idea!
> Cheers      Andreas
