[postgis-users] ERROR: Out of memory
Andreas Laggner
andreas.laggner at fal.de
Tue Oct 9 00:20:22 PDT 2007
Moin Moin,
thanks for your tipps. I solved this problem yesterday evening by giving
the postgresql installation on the server more buffer memory.
cheers Andreas
Shane Spencer schrieb:
> I think you don't have enough memory. Atleast thats my first assumption :)
> What kind of computer system is this running on? What are the hardware
> specs? Do you have oodles of swap/paging memory available? Do you
> have enough disk space for Postgresql to create its own temporary
> files?
> Shane
> On 10/8/07, Andreas Laggner <andreas.laggner at fal.de> wrote:
>> Hi,
>> i tried to perform the "union approach" from Kevin
>> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
>> the first query worked fine:
>> CREATE TABLE all_lines AS
>> SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffhsinglerep
>> UNION ALL
>> SELECT St_ExteriorRing (the_geom) AS the_geom FROM spasinglerep;
>> but in the second one i get an error:
>> CREATE TABLE noded_lines AS
>> SELECT St_Union(the_geom) AS the_geom
>> FROM all_lines;
>> SQL Status:53200
>> Detail:Failed on request of size 20750552.
>> If anybody knows what may be behind this error......i have no idea!
>> Cheers Andreas
>> Dipl. Geoökologe Andreas Laggner
>> Institut für Ländliche Räume (LR)
>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>> Institute of Rural Studies
>> Federal Agricultural Research Centre (FAL)
>> Bundesallee 50
>> D-38116 Braunschweig
>> Tel.: (+49) (0)531 596 5515
>> Fax: (+49) (0)531 596 5599
>> E-mail: andreas.laggner at fal.de
>> Homepage: http://www.lr.fal.de/
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bundesallee 50
