[postgis-users] ERROR: Out of memory
Andreas Laggner andreas.laggner at fal.de
Tue Oct 9 00:29:13 PDT 2007
Moin Mark,
the result from the explain:
"Aggregate  (cost=4354.35..4354.36 rows=1 width=32)"
"  ->  Seq Scan on all_lines  (cost=0.00..3826.68 rows=211068 width=32)"
adios      Andreas
Mark Cave-Ayland schrieb:
> On Mon, 2007-10-08 at 10:24 +0200, Andreas Laggner wrote:
>> Hi,
>> i tried to perform the "union approach" from Kevin
>> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
>> the first query worked fine:
>>  CREATE TABLE all_lines AS
>>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffhsinglerep
>>    UNION ALL
>>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM spasinglerep;
>> but in the second one i get an error:
>> CREATE TABLE noded_lines AS
>>    SELECT St_Union(the_geom) AS the_geom
>>    FROM all_lines;
>> SQL Status:53200
>> Detail:Failed on request of size 20750552.
>> If anybody knows what may be behind this error......i have no idea!
>> Cheers      Andreas
> Aggregates shouldn't run out of memory in general; the only time I have
> seen this discussed is if a Hash Aggregate plan is chosen for a large
> number of rows due to incorrect ANALYZE estimates. What does the output
> of "EXPLAIN SELECT St_Union(the_geom) AS the_geom FROM all_lines;" show?
> ATB,
> Mark.
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
