[postgis-users] postgis tuning parameters
Henry Holland
hholland at gmail.com
Tue Oct 9 22:49:51 PDT 2007
Would it be a problem if I posted this thread on a (tangentially related)
forum (http://forum.manifold.net/Site/Default.aspx)? A couple of similar
queries have popped up there and this is such a useful reply.
Henry Holland
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Dylan Beaudette
> Sent: 09 October 2007 22:12 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] postgis tuning parameters
> On Thursday 27 September 2007, Kevin Neufeld wrote:
> > Hi Dylan,
> > As a developer on a stand-alone postgresql box, I have the following
> > suggestions:
> > shared_buffers - This memory, of course as the name implies, is the
> > amount of memory shared between concurrent database connections.
> > Typically this should be about 50-75% of available RAM you have
> > dedicated to postgresql on your box. So, a little math is
> involved...
> > take your total memory, subtract that needed by the OS, subtract
> > anything else needed by other applications, and use 75% of the
> > remainder. This parameter is set on startup. I've seen web-server
> > boxes with 16GB of RAM configured such that shared_buffers consume
> > about 12GB. The idea here is simple: disks are slow,
> memory is fast.
> > The more data that will slowly float up into RAM the better.
> > work-mem - This memory is the amount of RAM used by PostgreSQL when
> > performing sort or hash join operations before being forced
> to disk.
> > This memory is a per-connection allocation, hence, it is tightly
> > coupled with max_connections (the number of concurrent
> connections on
> > your database). The default value is 1MB. In my opinion, this is
> > far, far too low to do anything useful in a database ... in
> a timely
> > manner. For a web-service database with hundreds of concurrent
> > connections, each using 1MB of ram, I suppose this makes
> sense. But
> > for me, a developer on a small team hitting a development
> box with 4GB
> > of ram, I have this set to about 150MB or 200MB. But since this
> > variable can be set at run time, before I run a complex
> one-time query
> > (and no one else is using the box) I often set this to about 1.4GB
> > using "SET work_mem TO 1400000;" before running my query.
> > maintenance_work_mem - This memory is the amount of RAM used by
> > PostgreSQL when performing maintenance operations like VACUUM,
> > ANALYZE, CREATE INDEX, etc... before being forced to disk. The
> > default value of 32MB is again far too low. I often have
> this set to
> > about 250MB on a 4GB box with 3 or 4 developers since it is
> unlikely
> > that every developer will be creating an index all at the
> same time.
> > Since this variable can also be set at run time, if the box is
> > relatively idle from other developers, I often can create a large
> > index quickly by issuing the command "SET maintenance_work_mem to
> > 1400000;".
> > You will have to strike some sort of balance. shared_buffers makes
> > sense with many concurrent connections, but not so much on a single
> > developer box. I would say, for you, set shared_buffers to
> about 50%
> > of availble postgres RAM and juggle the rest between work_mem and
> > maintenance_work_mem. Remember you can always set the last
> two on the
> > fly!
> > Also, the others are right, you will have to play with your
> SHMMAX and
> > SHMMIN settings to achieve these recommended settings.
> > Hope this helps,
> > Kevin
> Thanks Kevin, this list is a tremendous resource.
> cheers,
> Dylan
> > Phone: (250) 383-3022
> > Email: kneufeld at refractions.net
> > Dylan Beaudette wrote:
> > > Hi,
> > > I have looked over a couple documents on tuning a postgis server:
> > > 1.
> >http://postgis.refractions.net/pipermail/postgis-users/2006-March/011
> > >539.
> > >html
> > > 2. http://www.powerpostgresql.com/Downloads/annotated_conf_80.html
> > > When performing complex queries, with thousands of records and
> > > geometries I am noticing that the postmaster process
> never exceeds
> > > 1% of my system's memory (2Gb). I have tried setting the
> > > shared_buffers parameter to values > 2000 ... but this
> only leads to
> > > an error when the postgres server is restarted: cannot
> allocate this
> > > much mem, check the SHMMAX kernel parameter.
> > > Perhaps some answers on are this page:
> >http://www.redhat.com/docs/manuals/database/RHDB-2.1-Manual/admin_use
> > >r/ke
> > >rnel-resources.html
> > > or in the minds of people on the list. The machine in question is
> > > mostly used for such queries and I would like postgis to
> be able to
> > > better utilize the resources available.
> > > Cheers,
> > > Dylan
> > > Dylan Beaudette
> > > Soils and Biogeochemistry Graduate Group
> > > University of California at Davis
> > > 530.754.7341
> > > _______________________________________________
> > > postgis-users mailing list postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Dylan Beaudette
> Soil Resource Laboratory http://casoilresource.lawr.ucdavis.edu/
> 530.754.7341
