[postgis-users] ERROR: GEOS difference() threw an error!
Obe, Regina
robe.dnd at cityofboston.gov
Wed Oct 10 07:21:31 PDT 2007
Andreas,
I'm not sure what causes the below problem you described, but just to help zooming in further on the location of the problem, can you try the following statements separately and let us know if any return an error and how many records you get from each.
SELECT ffh_id, st_geometrytype(ST_Union(the_geom)) As gtype
FROM test_natura_full
GROUP BY ffh_id
HAVING st_isvalid(ST_union(the_geom)) = false;
SELECT spa_id, st_geometrytype(ST_union(the_geom)) As
the_geom
GROUP BY spa_id
SELECT
ffh_singlerep.ffh_name,ffh_singlerep.ffh_land,ffh_singlerep.ffh,ffh_singlerep.ffh_id,
null as spa_name,null as spa_land,null as spa,null as spa_id,
ST_Difference(ffh_singlerep.the_geom, test_natura_full.the_geom) As
the_geom
FROM ffh_singlerep INNER JOIN (SELECT ffh_id, ST_union(the_geom) As
the_geom
FROM test_natura_full GROUP BY ffh_id) As test_natura_full ON
ffh_singlerep.ffh_id = test_natura_full.ffh_id
AND ST_Intersects(ffh_singlerep.the_geom, test_natura_full.the_geom)
WHERE ST_IsEmpty(ST_Difference(ffh_singlerep.the_geom,
test_natura_full.the_geom)) = false;
SELECT null as ffh_name,null as ffh_land,null as ffh,null as ffh_id,
spa_singlerep.spa_name,spa_singlerep.spa_land,spa_singlerep.spa,spa_singlerep.spa_id,
ST_Difference(spa_singlerep.the_geom, test_natura_full.the_geom) As
the_geom
FROM spa_singlerep INNER JOIN (SELECT spa_id, ST_union(the_geom) As
the_geom
FROM test_natura_full GROUP BY spa_id) As test_natura_full ON
spa_singlerep.spa_id = test_natura_full.spa_id
AND ST_Intersects(spa_singlerep.the_geom,test_natura_full.the_geom)
WHERE ST_IsEmpty(ST_Difference(spa_singlerep.the_geom,
Hope this helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
Sent: Tuesday, October 09, 2007 9:20 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ERROR: GEOS difference() threw an error!
Andreas Laggner schrieb:
> can someone tell me what causes this Error?
> SQL Status:XX000
More Informations from the postgresql Logfile:
NOTICE: TopologyException: found non-noded intersection between
3.81546e+06 5.4495e+06, 3.81559e+06 5.44944e+06 and 3.81546e+06
5.4495e+06, 3.81551e+06 5.44948e+06 3.81551e+06 5.44948e+06
> the query:
> INSERT INTO test_natura_full
> SELECT
> the_geom
> the_geom
> UNION
> the_geom
> the_geom
> I had no problems with a small dataset (15 and 4 polygons), here i
> have 28000 and 1500 rows. All geometries are valid and singlepart
> Polygons.
> Cheers Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
