[postgis-users] Problem with loading postgis libs
Paul Ramsey
pramsey at refractions.net
Wed Oct 10 12:29:04 PDT 2007
This is the key line: have you installed libgeos? If not, do so.
If so, make sure your library loader can find it, by ensuring the
installation directory (usually /usr/local/lib) is in /etc/ld.so.conf
and you have run /sbin/ldconfig as root.
P
Patrick Ouellet wrote:
> "/usr/src/postgis-1.3.1/lwgeom/liblwgeom.so.1.3": libgeos_c.so.1: cannot
> open shared object file: No such file or directory
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
