[postgis-users] Problem with loading postgis libs
Patrick Ouellet patrick.ouellet at groupealta.com
Thu Oct 11 04:45:03 PDT 2007
Haaa men... it had to be a stupid error...
Since im using CentOS instead of using ld.so.conf it uses a include to
include all .conf in ld.so.conf.d directory.
I had named my file postgis instead of postgis.conf so it didn't load my
added ld path.
I renamed postgis to postgis.conf then rerun ldconfig and voila!
Thanx Paul that what I needed to realize it!
Paul Ramsey wrote:
> This is the key line: have you installed libgeos? If not, do so.
> If so, make sure your library loader can find it, by ensuring the
> installation directory (usually /usr/local/lib) is in /etc/ld.so.conf
> and you have run /sbin/ldconfig as root.
> P
> Patrick Ouellet wrote:
>> "/usr/src/postgis-1.3.1/lwgeom/liblwgeom.so.1.3": libgeos_c.so.1:
>> cannot open shared object file: No such file or directory
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071011/2b3e3885/attachment.vcf>
