[postgis-users] Problem with geodata storage
Emilio Ponce
yosoycore at gmail.com
Mon Oct 22 09:10:24 PDT 2007
Hi everyone, here Emilio from Barcelona,
I've found a problem with my postgresql+postgis under ubuntu. When I
tried to store a geometry worked well, but when I tried to get this
data with a select I found this strange numbers:
testgis=# select * from calles_geom;
id | name | geom
1 | Jeff Rd |
01020000000200000000000000005807410000000070AD0D4100000000205407410000000050B10D41
(1 fila)
I've done this to store the data:
CREATE TABLE CALLES_GEOM(
ID int4,
NAME varchar(25)
SELECT AddGeometryColumn('calles_db','calles_geom','geom','-1', 'LINESTRING',2);
BEGIN;
INSERT INTO CALLES_GEOM(ID,GEOM,NAME) VALUES (1,
GeometryFromText('LINESTRING(191232 243118,191108 243242)',-1),'Jeff
Rd');
END;
Then,anyone know why the geom column is not 'LINESTRING(191232
243118,191108 243242)'?
Thanks!
Emilio
