[postgis-users] Geos broken
Gilles Bassière
gilles.bassiere at makina-corpus.com
Mon Oct 22 09:50:14 PDT 2007
I got no answer for the issue below. I also tried to post a message on
the geos-devel mailing list but it seems like nobody listen to it :/
I'm still having the issue and I don't know how to track down the problem.
Does anybody can help ?
Thanks in advance
Gilles
> Hi list,
> I try to repair some segmented road data. I found several older posts
> that helped me to build a query using LineMerge(). Unfortunately, when
> I try to run it, I get:
> server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> I investigated a little further and found out that my GEOS is broken.
> Indeed, when I run a 'make check' in the build tree, I get:
> Area of difference between obtained and expected: 4.98296e-05 -
> Tolerated diff: 495.66 (SUCCESS!)
> Area of difference between obtained and expected: 0 - Tolerated diff:
> 6.68967 (SUCCESS!)
> 3.14191 (SUCCESS!)
> ./testrunner: line 1: 12017 Segmentation fault (core dumped)
> ./XMLTester -v ./testLeaksBig.xml ./hexwkb.xml ./test.xml
> ./linemerge.xml ./TestInteriorPoint.xml ./TestCentroid.xml
> ./TestIsValid.xml ./TestValid.xml ./TestValid2.xml
> ./TestValid2-big.xml ./robustness.xml ./stmlf-cases-20061020.xml
> ./TestRobustOverlayFixed.xml ./fme.xml ./TestBufferExternal.xml
> ./heisenbugs.xml ./stmlf-cases-20070119.xml
> FAIL: testrunner
> I'm stuck now... How should I fix my GEOS ?
> My config is:
> - GEOS 3.0.0rc4 (compiled with "--enable-python" and
> "--disable-inline" options)
> - Ubuntu Feisty (7.04)
> - Postgres 8.2.5 (package Ubuntu)
> - PostGIS 1.3.1 (compiled)
> - Proc AMD64 (though I use a i386 distro)
> Regards,
> Gilles
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
