[postgis-users] Making links
Per-Olof Norén
pelle at alma.nu
Wed Oct 24 04:35:57 PDT 2007
Gustavo Ces skrev:
> Hi all,
> I´ve got a railway linestring table and a railstation point table. Some linestring´s nodes are stations, and others aren´t. I have to extract a links table from the linestring one, with this structure
> link StartStation EndStation
> I´m trying to do it with ogr&python, but perhaps there is an easiest way to achive this in PostGis. Any help?
> Thanks in advance,
> Gus
Given your description I assume you intend to split a larger (railway)
linestring into smaller segments (the links) using the station table to
mark each point as station?
You could possibly write a procedure in pl/pgsql using containing functions:
st_numpoints(geometry) - number of points in linestring
st_pointn(geometry) - extracs point from linestring
st_touches(geometry, geometry) - check if points overlap (station and
railwaypoint)
Hope this gives you some ideas, at least.
Regards,
Per-Olof
