[postgis-users] Making links
Gustavo Ces
g.ces at pettra.es
Wed Oct 24 07:20:05 PDT 2007
Points are all over the net ( the linestrings) because they were
extracted from them. The problem is just to classify the linestring points
in two groups ( stations and not-stations) and then split the net into
smallest lines with stations as start and end points ( because i need the
not-stations data too).
So there is two problems :
1- classify nodes in two groups
2. split linestrings in smallest links using another point table.
I started with python and org, so i´m searching a solution with funcions
diferent to ogr's ones. In other words, is there any PostGis funcions to
make this split-action? But, algorithmic solutions will be welcomed, too :)
Gus
