[postgis-users] ST_Difference
Paul Ramsey
pramsey at refractions.net
Wed Oct 24 14:05:06 PDT 2007
On the flip side, if the number of "bad points" of ships-on-land is
small, the stripping operation is probably faster than the positive
containment test on all the ships-in-water points.
P
On 24-Oct-07, at 2:01 PM, Paul Ramsey wrote:
> Oh, yeah, oops, I know. It's the join logic, its finding the things
> not contained for each world feature, not for the full world set.
> select pd.* from pandatestdata pd,
> (select p.id
> from pandatestdata p, world2_12nm w
> where st_contains(w.the_geom, p.the_geom)) as wd where pd.id <> wd.id;
> Ugly, but probably effective: find all the things contained, then
> just strip those out.
> The trouble is that disjointness is not an easily spatially
> indexable operation. If you're going to take this into operation
> with large data volumes, a more effective data set would be ocean
> polygons, cut up into smallish regular grid squares, then you can
> test containment with relatively good index selectivity.
> P.
> On 24-Oct-07, at 1:53 PM, Richard Heimann [C] wrote:
>> Thanks Paul for the response. I hadn’t thought of this logic, it
>> didn’t work
>> however. Strangely, it increased the number of features by eight
>> times. Any
>> thoughts?
>> Vr
>> Rich
>> -----Original Message-----
>> From: Paul Ramsey [mailto:pramsey at refractions.net]
>> Sent: Wednesday, October 24, 2007 4:07 PM
>> To: Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion
>> Subject: Re: [postgis-users] ST_Difference
>> select p.*
>> where not st_contains(w.the_geom, p.the_geom);
>> On 24-Oct-07, at 11:45 AM, Richard Heimann [C] wrote:
>>> Thanks for your response W. I should have posted the sql query
>>> earlier.
>>> Anyway...its below.
>>> My goal is to drop all features (points) that fall within my
>>> polygon. In
>>> this case, I have ship track data and want to filter it with world
>>> country
>>> buffers.
>>> World2_12nm - my world country 12nm buffered polygon
>>> Pandatestdata - track data (point)
>>> Panda_diff2 - new table
>>> CREATE TABLE panda_diff2 AS
>>> SELECT AsText(Difference(world2_12nm.the_geom,
>>> pandatestdata.the_geom)) FROM
>>> world2_12nm, pandatestdata
>>> Also attached are the astext versions of my data as well as a csv
>>> of the
>>> output from the above sql. Please debunk the mystery...
>>> Thanks again
>>> Rich
>>> From: Webb Sprague [mailto:webb.sprague at gmail.com]
>>> Sent: Wednesday, October 24, 2007 12:00 PM
>>> You might get more useful help if you post an "astext()" version of
>>> your data, the query, the result, and a *desired* result.
>>> I know the difference functions can be tricky and are sometiimes
>>> defined in ways you might not expect.
>>> Thx
>>> W
>>> On 10/24/07, Richard Heimann [C] <heimann at ait.nrl.navy.mil> wrote:
>>>> All,
>>>> I would appreciate help in constructing an SQL statement that
>>>> performs a
>>>> difference function on two datasets. My intersect function works
>>>> but
>>> cannot
>>>> work out the kinks with st_difference. Thanks for your help.Im
>>>> new to
>>>> Postgis.
>>>> Rich
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> <panda_diff2.csv>
