[postgis-users] ST_Difference
Obe, Regina robe.dnd at cityofboston.gov
Wed Oct 24 14:22:13 PDT 2007
That doesn't quite look right.  What about
select pd.* from pandatestdata pd LEFT JOIN
(select p.id
from pandatestdata p, world2_12nm w
where st_contains(w.the_geom, p.the_geom)) as wd ON  pd.id = wd.id
WHERE wd.id IS NULL
Should give you all the pandatestdata points that is not in any of your world polygons.  Also I think using st_within(w.th
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 10/24/2007 5:01 PM
To: Richard.Heimann at nrl.navy.mil
Cc: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] ST_Difference
Oh, yeah, oops, I know. It's the join logic, its finding the things
not contained for each world feature, not for the full world set.
select pd.* from pandatestdata pd,
(select p.id
where st_contains(w.the_geom, p.the_geom)) as wd where pd.id <> wd.id;
Ugly, but probably effective: find all the things contained, then
just strip those out.
The trouble is that disjointness is not an easily spatially indexable
operation. If you're going to take this into operation with large
data volumes, a more effective data set would be ocean polygons, cut
up into smallish regular grid squares, then you can test containment
with relatively good index selectivity.
P.
On 24-Oct-07, at 1:53 PM, Richard Heimann [C] wrote:
> Thanks Paul for the response. I hadn't thought of this logic, it
> didn't work
> however. Strangely, it increased the number of features by eight
> times. Any
> thoughts?
> Vr
> Rich
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Wednesday, October 24, 2007 4:07 PM
> To: Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion
> select p.*
> where not st_contains(w.the_geom, p.the_geom);
> On 24-Oct-07, at 11:45 AM, Richard Heimann [C] wrote:
>> Thanks for your response W. I should have posted the sql query
>> earlier.
>> Anyway...its below.
>> My goal is to drop all features (points) that fall within my
>> polygon. In
>> this case, I have ship track data and want to filter it with world
>> country
>> buffers.
>> World2_12nm - my world country 12nm buffered polygon
>> Pandatestdata - track data (point)
>> Panda_diff2 - new table
>> CREATE TABLE panda_diff2 AS
>> SELECT AsText(Difference(world2_12nm.the_geom,
>> pandatestdata.the_geom)) FROM
>> world2_12nm, pandatestdata
>> Also attached are the astext versions of my data as well as a csv
>> of the
>> output from the above sql. Please debunk the mystery...
>> Thanks again
>> Rich
>> From: Webb Sprague [mailto:webb.sprague at gmail.com]
>> Sent: Wednesday, October 24, 2007 12:00 PM
>> You might get more useful help if you post an "astext()" version of
>> your data, the query, the result, and  a *desired* result.
>> I know the difference functions can be tricky and are sometiimes
>> defined in ways you might not expect.
>> Thx
>> W
>> On 10/24/07, Richard Heimann [C] <heimann at ait.nrl.navy.mil> wrote:
>>> All,
>>> I would appreciate help in constructing an SQL statement that
>>> performs a
>>> difference function on two datasets. My intersect function works but
>> cannot
>>> work out the kinks with st_difference. Thanks for your help.Im
>>> new to
>>> Postgis.
>>> Rich
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> <panda_diff2.csv>
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071024/fae0a2d1/attachment.html>
