[postgis-users] noding problem
Obe, Regina
robe.dnd at cityofboston.gov
Mon Oct 29 05:29:14 PDT 2007
P,
So does that mean you can create a more efficent st_dwithin that instead
of doing this
SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND
ST_Distance($1, $2) < $3
Does this
_ST_DWithin($1, $2, $3)
And the new _ST_Dwithin function would do exactly what distance does
except it would return a boolean and kick out a true as soon as it finds
a point set where the distance is < $3; no need to wait to reach 0.
R
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Thursday, October 25, 2007 10:50 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] noding problem
Yes, that is all the magic there is to the "distance is faster"
assertion. Obviously it's only faster for cases where there are lots
of fully contained candidates that return immediately on the first
point test.
P
On 25-Oct-07, at 4:24 AM, Obe, Regina wrote:
> Am I safe in saying that distance treats the case of distance() ==
> 0 as
> a special case - e.g. you can't get lower than 0 for distance so there
> is no point in checking any further?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
