[postgis-users] noding problem
Paul Ramsey pramsey at refractions.net
Mon Oct 29 09:11:08 PDT 2007
Yes, that's true. Hadn't thought of that one...
On 29-Oct-07, at 5:29 AM, Obe, Regina wrote:
> P,
> So does that mean you can create a more efficent st_dwithin that
> instead
> of doing this
> SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND
> ST_Distance($1, $2) < $3
> Does this
> _ST_DWithin($1, $2, $3)
> And the new _ST_Dwithin function would do exactly what distance does
> except it would return a boolean and kick out a true as soon as it
> finds
> a point set where the distance is < $3; no need to wait to reach 0.
> R
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Thursday, October 25, 2007 10:50 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] noding problem
> Yes, that is all the magic there is to the "distance is faster"
> assertion. Obviously it's only faster for cases where there are lots
> of fully contained candidates that return immediately on the first
> point test.
> P
> On 25-Oct-07, at 4:24 AM, Obe, Regina wrote:
>>  Am I safe in saying that distance treats the case of distance() ==
>> 0 as
>> a special case - e.g. you can't get lower than 0 for distance so
>> there
>> is no point in checking any further?
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
