[postgis-users] updating with askml function
Obe, Regina
robe.dnd at cityofboston.gov
Tue Sep 4 07:13:11 PDT 2007
The asKML function is part of the liblwgeom.dll so you really need to
upgrade postgis to use it.
Probably the easiest way to go is to bite the bullet and upgrade to 1.3
using one of the following windows binaries
http://postgis.refractions.net/download/windows/
and then run the Program
Files\PostgreSQL\8.2\share\contrib\postgis\lwpostgis_upgrade.sql
on your database.
I haven't run into any problems doing that aside from forcing everyone
off the PostgreSQL service before upgrading and the fact that the new
aggregate name functions don't get installed. This will not effect your
asKML use.
In most cases (unless you are running pre 8.0 and pre 1.0 - its about a
5-10 minute install process).
At anyrate, you should backup your database with pg_dump before hand.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of pere
roca
Sent: Monday, September 03, 2007 8:23 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] updating with askml function
me again...
I've just seen a message of Paul Ramsey on Jan 12, 2007: "The 1.2.1
release
of PostGIS is now available. This is a minor bug fix release...between
others, the New AsKML() function".
Should then find it in http://svn.refractions.net/postgis/tags/1.2.1/
(I
can't find it...) and then...
thanks,
Pere
pere roca wrote:
> hi everybody,
> I'm very interested to update my postGIS (1.2.1 for window$) adding
the
> asKml function.
> How and where can I get it? and the most important: how to
> integrate/import this function? is necessary to update all the PostGIS
> extension? (I'm afraid of losing data).
> Thanks in advance,
> Pere
View this message in context:
http://www.nabble.com/updating-with-askml-function-tf4371698.html#a12460
831
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
