[postgis-users] Hibernate Tools and PostGIS
Dave Potts
dave.potts at pinan.co.uk
Wed Sep 5 14:06:39 PDT 2007
Norman Barker wrote:
> Hi,
> I have extended the postgis hibernate tools so that now when you reverse
> engineer a postgis database the entity pojos are marked up with custom
> geometry annotation (hibernate mapping) - this really wasn't hard and
> just amended an existing patch - this will go into Hibernate shortly.
> However I really need some direction now!
> We have in the spatial domain
> 1) Geometry persistence and table generation
> 2) Hibernate criteria queries
> 3) spatial dialect (so spatial object queries)
> The next logical step is to follow the JBoss seam generator examples and
> auto-generate a web app as this is similar to the existing toolset in
> hibernate tools.
> However I need to know what you want (if at all you are interested), is
> generating a web app (a la Rails) of use, or would you prefer a WFS /
> GeoJSON generator or ANOther use for the entities mapped from a
> database? Perhaps a UML modeler which creates the pojos that then
> creates the PostGIS db would be of interest?
> I don't really use this for work, so some real direction from the
> community would be appreciated (cc'd Chris Hodgson as I know he uses
> hibernate in this way (but not this codebase)).
> Thanks,
> Norman
> postgis-users mailing list
VERY nice bit of work, but I think you need an example with the postgis
term in the where clause, I have just spent several hours trying to
work this out.
eg something like might help
select distinct dist from DistanceDTO as dist, DistanceDTO as src where
spatial.Contains(dist.osNGR,src.osNGR)='t';
Granted the dianostics from Hibernate are rather unclear.
Dave.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070905/4f0bdaf5/attachment.vcf>
