[postgis-users] Help Mapserver and Postgis
Jose Gregorio Campos
josecamposl at gmail.com
Fri Sep 7 05:48:59 PDT 2007
Hola MILO
Before thanks
I have already consulted the documentation (
http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub
) and apparently I follow well the variable instructions and single use in
expressions DATA,
I use (MS4W)
Windows XP
Apache 2.2.4
PHP 5.2.3
Mapserver 4.10.2
My mapfile generates it with the aid of MAPLAP 2.2.1
2007/9/6, Milo van der Linden <mlinden at zeelandnet.nl>:
> Hola Jose!
> I believe that variables in the Mapfile are limited to a couple of
> options:
> - In CONNECTION
> - IN DATA (as you use it)
> - In EXPRESSION when you use classes (I use it there a lot)
> - Mapserver Has to be CGI
> Is the link something like:
> http://www.yourserver.com/cgi-bin/maserv?map=x&var=5000&...&... ? Than it
> should work If all above is ok.
> As described here:
> Kind regards,
> Milo van der Linden
> www.3dsite.nl
> Jose Gregorio Campos schreef:
> I have a problem with the Substitution of Variable in MAPSERVER %var%
> Tengo problema con la Sustitucion de Variable en MAPSERVER %var%
> DATA "the_geom from (SELECT * FROM parcelas WHERE gid > '%var%') as foo
> using srid=32619 using unique gid"
> I execute and the IMAGE as LINK Broken
> Ejecuto y queda la IMAGEN como ENLACE (LINK) Roto
> Change to prove
> Cambio para probar
> DATA "the_geom from (SELECT * FROM parcelas WHERE gid > 5000) as foo using
> and everything is well
> y todo resulta bien
> THAT I MUST REVIEW
> QUE DEBO REVISAR
> Thanks and excuse my English badly
> Gracias y disculpen mi mal Ingles
> postgis-users mailing list
> postgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
> Milo van der Linden
> skype: milovanderlinden
> milovanderlinden at gmail.com
> milo at 3dsite.nl
> http://www.3dsite.nl
> De informatie in dit bericht reflecteert mijn persoonlijke mening en niet
> die van een bedrijf of instantie. Aan de informatie kunnen geen rechten
> worden ontleend. Indien dit bericht onderdeel is van een forum, mailing-list
> of community dan gelden automatisch de bij het betreffende medium behorende
> voorwaarden. The information in this message reflects my personal opinion
> and not that of a company or public body. All rights reserved.If this
> message is contained in a mailing-list or community, the rights on the
> medium are automatically adapted.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070907/8bf2626c/attachment.html>
